  3. [App] Announcements
  4. New update! (4.2.0) In-app MRA Routeplanner
45 Posts 19 Posters 31.7k Views 8 Watching
    Good morning MyRoute-app users!
    We are proud to announce the upcoming release of the in-app MRA Routeplanner ๐ŸŽ‰
    After elaborate testing by the Alpha and Beta testers, we are confident that this will be an epic release ๐Ÿ’ฅ With pride we present the in-app MRA Routeplanner to you!
    With this routeplanner you can edit your high quality MRA routes with an interface it deserves.
    • Edit any existing route! ๐Ÿ’ช
    • Create a new route from scratch
    • Change routes from others
    • All this can even be done offline! ๐ŸŽ‰
    The Routeplanner offers many features to help you in building lovely routes.
    Quickly keep adding waypoints to your route to shape the route to your preference.
    • Yellow button starts the adding process and keep tapping it to continuously add waypoints
    • Click add to add a new waypoint and stop adding more
    • Cancel, dismiss what you are doing
    If you make a mistake, no problem! Simply use the undo / redo buttons like you are used to in the website ๐Ÿ˜‰
    Do you want to add information to waypoints? Ofcourse you can do so! ๐ŸŽ‰
    Change the colour, type, note, title, pause duration or even the icon of the waypoint! ๐Ÿ˜ฎ
    Do you want to add a waypoint somewhere along the route? Obviously that's possible too!
    • Tap somewhere along the line to add a waypoint there in order of the route
    • Long press and drag a line to immediately move the marker you are adding in that leg
    Do you need to move a waypoint precisely? Simply use the advanced move interface to place the waypoint exactly where you want. Long pressing and dragging the waypoint works too but that is less precise ๐Ÿ™‚
    Then we also allow you to change any of the other settings.
    • Edit the name / description of the route.
    • Alter the privacy / travel mode
    • Avoid specific type of roads
    • View all the waypoints
    Talking about waypoints! Did you know you can drag the waypoints shown in the list to reorder them? ๐Ÿ˜ When you've opened a waypoint you can also swipe left / right to jump to the previous / next waypoint ๐Ÿ˜ฎ
    That's it really!
    So in short:
    • Create new routes from scratch
    • Edit any route
    • Access to our unique MRA Routeplanner features in-app
    • Modify waypoints
    • Change route information / details / options
    Feel free to discover all other features yourself ๐Ÿ˜‰
    Isn't this an amazing update??? We have put a lot of focus in the visual appearance and user experience of this planner so we hope you are satisfied.
    In the upcoming update we will rework your route library to enable easy syncing of all your routes. Meaning that offline created routes will be synced to the website when online again, you can automatically sync routes / your entire library between website and app! ๐ŸŽ‰ But that's for later ๐Ÿ˜‰
    If you got any feedback, feel free to share it on this forum ๐Ÿ™‚
    Best,
    Corjan
    Team MRA โค
    Tom Grzelinski
    Tom Grzelinski
    Tom Grzelinski
    wrote on last edited by Tom Grzelinski
    @Corjan-Meijerink Fantastic, thank you so much for this update ๐Ÿ‘
    Porsche 911 and VW Transporter T6.1 running CarPlay.
    iPhone 17 Pro running Waze and MRA.
    MRA Routeplanner on web via Mac
    • Ruurt Visser
      Ruurt Visser
      Ruurt Visser
      Waar kan ik instellen dat dit 'gewoon' in het Nederlands te lezen is zodat ik er ook wat van snap?
      MotoCon Corjan Meijerink 2 Replies Last reply
        That's it really!
        So in short:
        • Edit any route
        • Modify waypoints
        Best,
        Corjan
        Team MRA โค
        Stuart Greer
        Stuart Greer
        Stuart Greer
        @Corjan-Meijerink i like the new capabilty. as an XT user, when modifying or creating a route offline is there a way to export a gpx file.
        • versluis versluis
          @Corjan-Meijerink na de update ben ik al mijn routes kwijt
          En hij staat ze ook niet meer op in mijn downloads
          Hier ben ik echt niet blij mee ๐Ÿ˜ž
          @versluis je routes blijven gewoon beschikbaar
          Ik zag dat je wel ff moet schakelen met vrienden en weer terug dan zie je de routes weer
          versluis 1 Reply Last reply
            versluis
            versluis
            versluis
            @Marinus-van-Deudekom thnx maar het gaat hier over de download map deze is leeg.
            • Cookie On Tour
              Cookie On Tour
              Cookie On Tour
              Thank you, can't wait to try it out!
              Joerg
              (Cookie-On-Tour.de)
              Duster Laurรฉate SCe 115 LPG 4x2 ยท Everest Minicamp by Niewiadow (B1300)
              Carpuride W701 Pro ยท iPhone 15 Pro Max
              • Ruurt Visser Ruurt Visser
                @Ruurt-Visser said in New update! (4.2.0) In-app MRA Routeplanner:
                Probeer eens de tool van deepl.com:
                Vertalingen van en naar alle talen die maar wil (nou ja, veel in elk geval).
                  @Ruurt-Visser forum aankondigingen doe ik altijd in het Engels. De mailing over deze update en de bijbehorende info paginaโ€™s zijn ook Nederlands ๐Ÿ™‚
                  Ruurt Visser 1 Reply Last reply
                  • Stuart Greer Stuart Greer
                    @Stuart-Greer not yet! That is only possible when accessing it online as the file is created by our website rather than by the app itself.
                    Stuart Greer 1 Reply Last reply
                      Stuart Greer
                      Stuart Greer
                      Stuart Greer
                      @Corjan-Meijerink thats good news Corjan, great work on the route planner.
                        Ruurt Visser
                        Ruurt Visser
                        Ruurt Visser
                        @Corjan-Meijerink Dank je wel. Ik ga beter kijken.
                        • Cookie On Tour
                          Cookie On Tour
                          Cookie On Tour
                          I love the new options and I can't wait to see a true sync coming, so no manual downloads are needed.
                          QQ: Has the app received any other fixes to bugs or enhancements regarding sound for example? Is there a full release note somewhere?
                          Joerg
                          (Cookie-On-Tour.de)
                          • Cookie On Tour Cookie On Tour
                            @Cookie-On-Tour, These ARE the release notes ๐Ÿ˜‰
                            Cookie On Tour 1 Reply Last reply
                              Cookie On Tour
                              Cookie On Tour
                              Cookie On Tour
                              @Con-Hennekens said in New update! (4.2.0) In-app MRA Routeplanner:
                              LOL okay, so no improvements or fixes to the sound issues....
                              Joerg
                              (Cookie-On-Tour.de)
                                @Cookie-On-Tour correct ๐Ÿ˜‰
                                  That's it really!
                                  So in short:
                                  • Edit any route
                                  • Modify waypoints
                                  Best,
                                  Corjan
                                  Team MRA โค
                                  marc van der heijden
                                  @Corjan-Meijerink ik had anders meteen problemen, app liep vast nadat ik wilde proberen ( weet niet of het รผberhaupt kan ) route overslaan functie, app crashte en kon helemaal opnieuw beginnen want zelfs de route werd niet opgeslagen zoals dat normaliter wel het geval was
                                  Marinus van Deudekom Corjan Meijerink MotoCon 3 Replies Last reply
                                  • paul69
                                    hi @Corjan-Meijerink
                                    i managed to use the in-app routeplanner while touring recently due to a road closure, i had to re-plan the next day's ride and i must report that it worked extremely well, and it was very easy to use, excellent bit of work MRA gang
                                    to achieve, we must first attemptโœŒ๏ธ
                                    K1600 GTL
                                    iPhone 13 Pro, carpuride 702b
                                    • marc van der heijden marc van der heijden
                                      @marc-van-der-heijden jammer dat de app vastliep. Je moet bij de in app planner de route wel opslaan anders dan in de web versie. Die stap heb je niet kunnen doen dus ook niks opgeslagen.
                                        @marc-van-der-heijden dat kan ook gewoon gebeuren hoor ๐Ÿ˜‰ Gaat vaker goed dan fout en foutjes zijn op te lossen. Heb je bij je andere bericht al gevraagd of het te reproduceren is.
                                        • paul69 paul69
                                          @paul69 awesome! ๐Ÿ™‚
                                          JP d
                                          JP d
                                          Tom Grzelinski
                                          Tom Grzelinski
                                          Stuart Greer
                                          Stuart Greer
                                          Cookie On Tour
                                          Cookie On Tour
                                          Ruurt Visser
                                          Ruurt Visser
                                          Richard 18
                                          Richard 18
                                          Marius Gross
                                          Marius Gross
                                          Paulusma
                                          Paulusma
                                          versluis
                                          versluis
                                          Dirk Kevin K.
                                          Dirk Kevin K.
                                          Benny Van de Velde
                                          Benny Van de Velde
                                            Nick Elsom 0
                                            Nick Elsom 0
                                          • 0 van 15 klaar
                                            Mark Vroomen
                                            Mark Vroomen
                                            Bart van de Griendt
                                            Bart van de Griendt
                                          • Routelijn transparantie
                                            Mark Vroomen
                                            Mark Vroomen
