  3. [App] Announcements
  4. New update! (4.2.0) In-app MRA Routeplanner
45 Posts 19 Posters 30.9k Views 8 Watching
    @versluis correct, de downloads die je had dienen even opnieuw gedownload te worden.
    Vanaf de volgende update zal het hele downloaden / synchroniseren worden aangepakt. Helaas zijn bestaande downloads niet compatibel met deze app versie.
    versluis
    versluis
    versluis
    @Corjan-Meijerink duidelijk thnx
      Good morning MyRoute-app users!
      We are proud to announce the upcoming release of the in-app MRA Routeplanner ๐ŸŽ‰
      After elaborate testing by the Alpha and Beta testers, we are confident that this will be an epic release ๐Ÿ’ฅ With pride we present the in-app MRA Routeplanner to you!
      With this routeplanner you can edit your high quality MRA routes with an interface it deserves.
      • Edit any existing route! ๐Ÿ’ช
      • Create a new route from scratch
      • Change routes from others
      • All this can even be done offline! ๐ŸŽ‰
      The Routeplanner offers many features to help you in building lovely routes.
      Quickly keep adding waypoints to your route to shape the route to your preference.
      • Yellow button starts the adding process and keep tapping it to continuously add waypoints
      • Click add to add a new waypoint and stop adding more
      • Cancel, dismiss what you are doing
      If you make a mistake, no problem! Simply use the undo / redo buttons like you are used to in the website ๐Ÿ˜‰
      Do you want to add information to waypoints? Ofcourse you can do so! ๐ŸŽ‰
      Change the colour, type, note, title, pause duration or even the icon of the waypoint! ๐Ÿ˜ฎ
      Do you want to add a waypoint somewhere along the route? Obviously that's possible too!
      • Tap somewhere along the line to add a waypoint there in order of the route
      • Long press and drag a line to immediately move the marker you are adding in that leg
      Do you need to move a waypoint precisely? Simply use the advanced move interface to place the waypoint exactly where you want. Long pressing and dragging the waypoint works too but that is less precise ๐Ÿ™‚
      Then we also allow you to change any of the other settings.
      • Edit the name / description of the route.
      • Alter the privacy / travel mode
      • Avoid specific type of roads
      • View all the waypoints
      Talking about waypoints! Did you know you can drag the waypoints shown in the list to reorder them? ๐Ÿ˜ When you've opened a waypoint you can also swipe left / right to jump to the previous / next waypoint ๐Ÿ˜ฎ
      That's it really!
      So in short:
      • Create new routes from scratch
      • Edit any route
      • Access to our unique MRA Routeplanner features in-app
      • Modify waypoints
      • Change route information / details / options
      Feel free to discover all other features yourself ๐Ÿ˜‰
      Isn't this an amazing update??? We have put a lot of focus in the visual appearance and user experience of this planner so we hope you are satisfied.
      In the upcoming update we will rework your route library to enable easy syncing of all your routes. Meaning that offline created routes will be synced to the website when online again, you can automatically sync routes / your entire library between website and app! ๐ŸŽ‰ But that's for later ๐Ÿ˜‰
      If you got any feedback, feel free to share it on this forum ๐Ÿ™‚
      Best,
      Corjan
      Team MRA โค
      Tom Grzelinski
      Tom Grzelinski
      Tom Grzelinski
      wrote on last edited by Tom Grzelinski
      @Corjan-Meijerink Fantastic, thank you so much for this update ๐Ÿ‘
      Porsche 911 and VW Transporter T6.1 running CarPlay.
      iPhone 17 Pro running Waze and MRA.
      MRA Routeplanner on web via Mac
      • Ruurt Visser
        Ruurt Visser
        Ruurt Visser
        Waar kan ik instellen dat dit 'gewoon' in het Nederlands te lezen is zodat ik er ook wat van snap?
        Con Hennekens Corjan Meijerink 2 Replies Last reply
          That's it really!
          So in short:
          • Edit any route
          • Modify waypoints
          Best,
          Corjan
          Team MRA โค
          Stuart Greer
          Stuart Greer
          Stuart Greer
          @Corjan-Meijerink i like the new capabilty. as an XT user, when modifying or creating a route offline is there a way to export a gpx file.
          • versluis versluis
            @Corjan-Meijerink na de update ben ik al mijn routes kwijt
            En hij staat ze ook niet meer op in mijn downloads
            Hier ben ik echt niet blij mee ๐Ÿ˜ž
            @versluis je routes blijven gewoon beschikbaar
            Ik zag dat je wel ff moet schakelen met vrienden en weer terug dan zie je de routes weer
            versluis 1 Reply Last reply
              versluis
              versluis
              versluis
              @Marinus-van-Deudekom thnx maar het gaat hier over de download map deze is leeg.
              • Cookie On Tour
                Cookie On Tour
                Cookie On Tour
                Thank you, can't wait to try it out!
                Joerg
                (Cookie-On-Tour.de)
                Duster Laurรฉate SCe 115 LPG 4x2 ยท Everest Minicamp by Niewiadow (B1300)
                Carpuride W701 Pro ยท iPhone 15 Pro Max
                • Ruurt Visser Ruurt Visser
                  @Ruurt-Visser said in New update! (4.2.0) In-app MRA Routeplanner:
                  Probeer eens de tool van deepl.com:
                  Vertalingen van en naar alle talen die maar wil (nou ja, veel in elk geval).
                    @Ruurt-Visser forum aankondigingen doe ik altijd in het Engels. De mailing over deze update en de bijbehorende info paginaโ€™s zijn ook Nederlands ๐Ÿ™‚
                    Ruurt Visser 1 Reply Last reply
                    • Stuart Greer Stuart Greer
                      @Stuart-Greer not yet! That is only possible when accessing it online as the file is created by our website rather than by the app itself.
                      Stuart Greer 1 Reply Last reply
                        Stuart Greer
                        Stuart Greer
                        Stuart Greer
                        @Corjan-Meijerink thats good news Corjan, great work on the route planner.
                          Ruurt Visser
                          Ruurt Visser
                          Ruurt Visser
                          @Corjan-Meijerink Dank je wel. Ik ga beter kijken.
                          • Cookie On Tour
                            Cookie On Tour
                            Cookie On Tour
                            I love the new options and I can't wait to see a true sync coming, so no manual downloads are needed.
                            QQ: Has the app received any other fixes to bugs or enhancements regarding sound for example? Is there a full release note somewhere?
                            Joerg
                            (Cookie-On-Tour.de)
                            • Cookie On Tour Cookie On Tour
                              @Cookie-On-Tour, These ARE the release notes ๐Ÿ˜‰
                              Cookie On Tour 1 Reply Last reply
                                Cookie On Tour
                                Cookie On Tour
                                Cookie On Tour
                                @Con-Hennekens said in New update! (4.2.0) In-app MRA Routeplanner:
                                LOL okay, so no improvements or fixes to the sound issues....
                                Joerg
                                (Cookie-On-Tour.de)
                                  @Cookie-On-Tour correct ๐Ÿ˜‰
                                    That's it really!
                                    So in short:
                                    • Edit any route
                                    • Modify waypoints
                                    Best,
                                    Corjan
                                    Team MRA โค
                                    marc van der heijden
                                    @Corjan-Meijerink ik had anders meteen problemen, app liep vast nadat ik wilde proberen ( weet niet of het รผberhaupt kan ) route overslaan functie, app crashte en kon helemaal opnieuw beginnen want zelfs de route werd niet opgeslagen zoals dat normaliter wel het geval was
                                    Marinus van Deudekom Corjan Meijerink Con Hennekens 3 Replies Last reply
                                    • paul69
                                      hi @Corjan-Meijerink
                                      i managed to use the in-app routeplanner while touring recently due to a road closure, i had to re-plan the next day's ride and i must report that it worked extremely well, and it was very easy to use, excellent bit of work MRA gang
                                      to achieve, we must first attempt โœŒ๏ธ
                                      K1600 GTL
                                      Oukitel RT3
                                      iPhone 13 Pro, carpuride 702b
                                      • marc van der heijden marc van der heijden
                                        @marc-van-der-heijden jammer dat de app vastliep. Je moet bij de in app planner de route wel opslaan anders dan in de web versie. Die stap heb je niet kunnen doen dus ook niks opgeslagen.
                                          @marc-van-der-heijden dat kan ook gewoon gebeuren hoor ๐Ÿ˜‰ Gaat vaker goed dan fout en foutjes zijn op te lossen. Heb je bij je andere bericht al gevraagd of het te reproduceren is.
                                          Tom Grzelinski
                                          Tom Grzelinski
                                          JP d
                                          JP d
                                          Cookie On Tour
                                          Cookie On Tour
                                          Ruurt Visser
                                          Ruurt Visser
                                          Richard 18
                                          Richard 18
                                          Marius Gross
                                          Marius Gross
                                          Paulusma
                                          Paulusma
                                          versluis
                                          versluis
                                          Dirk Kevin K.
                                          Dirk Kevin K.
                                          Benny Van de Velde
                                          Benny Van de Velde
                                          Stuart Greer
                                          Stuart Greer
                                          • A12 Group Trip โ€“ How Does It Work? ... Beta Planner and Next App
                                          • Missing info from CarPlay
                                            Jรถrgen
                                            Jรถrgen
                                          • Routenplaner on iPad
                                          • File en omrijden
                                            Robineke
                                            Robineke
