  4. Position delay/lag quick fix - which app works, which do not?
navigationnextpositiondelay
36 Posts 10 Posters 22.7k Views 4 Watching
    Hi All,
    As is quite familiar by know, several users are bothered by a position delay of the cursor/flyer in relation to the actual position the road. I was one of the first users here to confirm (back in spring 2023 or so) that running another GPS app, such as Flitsmeister in parallel to MRA Navigation Next almost completely solves this issue. At the time I was already relieved to find that FM worked a charm and did not look any further.
    Since this issue has by now been identified to be caused by the HERE SDK, I've checked whether or not FM is the only app that shows improvements to the position delay.
    I would like to ask all users that are familiar with this use, that is: they are still bothered with it, to check whether or not other GPS apps are also effective in signficantly reducing the position delay/lag.
    These results may aid Corjan and HERE in finding the root cause.
    Phone characteristics:
    • Brand: OnePlus
    • Type: OnePlus 6 (ONEPLUS A6003)
    • OS version: Android 11, OxygenOS 11.1.2.2
    • OS Build nr: ONEPLUS A6003_22_211125
    I checked the following apps:
    • Flitsmeister: delay gone
    • Waze: delay gone
    • TomTom MyDrive: no effect
    • Google Maps: no effect
    On behalf of us all: thanks ๐Ÿ˜
    @Stefan-Hummelink,
    Third case in, a friend ๐Ÿ˜‰
    • Brand: Oppo
    • Type: A5 (CPH1931)
    • OS version: Android 10, ColorOS7.1
    GMaps seems to help a bit, Flitmeister not tried yet.
      @Con-Hennekens said in Position delay/lag quick fix - which app works, which do not?:
      Google location servic
      This on its own would be contradicted by the fact that running GMaps in parallel did nothing at all for the delay on my OP6. ๐Ÿ˜„
      @Stefan-Hummelink, I think the devices chipset could be a big deal for this problem. But that is more difficult to ask for.
        devices chipset
        Indeed, if the HERE dev's think that may be a good to know, they can extract it based on our provided model info :).
          devices chipset
          @Stefan-Hummelink, exactly.
          • RetiredWingMan
            FM is not available in my area, j found that running a Speedometer app in the background fixes the issue.
            Samsung Galaxy S20 5G. Android 13 UI 5.1
              @RetiredWingMan Thanks for reporting! ๐Ÿ˜„
              • Jรถrgen
                Jรถrgen
                Jรถrgen
                iPhone 12
                iOS 17.4.1
                MRA 4.1.2 303
                No other GPS tool running
                No delay
                • Jรถrgen Jรถrgen
                  iPhone 12
                  iOS 17.4.1
                  MRA 4.1.2 303
                  No delay
                  @Jรถrgen said in Position delay/lag quick fix - which app works, which do not?:
                  No delay
                  Hahahaha Although it was the idea to post the phones that do have a delay, your response is always welcome ๐Ÿ˜...
                  Jรถrgen 1 Reply Last reply
                  • Stefan Hummelink Stefan Hummelink referenced this topic on
                    The GPS receiver is in most cases a part of the phones SOC.
                    The cause is probably the SOC software together with Here software
                    You need to build a large database with Phones specs and which has the problem or not. From there Here needs to do some fixes.
                    Sadly there are to much different phones in use to build a proper database on this forum.
                    My Input:
                    I use Android Auto which uses the Goldwings GPS receiver.
                    This one is most of the time a bit behind. How much?
                    Mostly 20-50 meters but sometimes up to 200 meters.
                      My Input:
                      @M-Schrijver said in Position delay/lag quick fix - which app works, which do not?:
                      Haha ya, for sure. This was an initial attempt. ๐Ÿ˜Š
                      • Peter Verweij
                        Peter Verweij
                        Peter Verweij
                        Here also on both an iPhone SE 2020 and a Google Pixel 7, there is a significant delay and therefore worthless to start and promote use in our Oldtimer Club.
                        If there is a solution please do, because this makes all other great solutions within MRA unusable.
                          No delay
                          Jรถrgen
                          Jรถrgen
                          Jรถrgen
                          @Stefan-Hummelink said in Position delay/lag quick fix - which app works, which do not?:
                          No delay
                          Ok, ok,
                          Today with
                          Oukitel tablet RT3
                          Android 12,
                          MRA 4.1.2 V 303
                          Big delay (20-30m)
                          With Altimeter App runing in the background
                          No or acceptable delay.
                          • Jรถrgen Jรถrgen
                            No delay
                            Ok, ok,
                            Today with
                            Oukitel tablet RT3
                            Android 12,
                            MRA 4.1.2 V 303
                            Big delay (20-30m)
                            Awesome! This is the kind of information that may be useful for @Corjan-Meijerink to feedback to HERE, or HERE can read this forum thread haha.
                            • GEORGIOS PANTELIDIS 0 GEORGIOS PANTELIDIS 0 referenced this topic on
                            • Corjan Meijerink Corjan Meijerink moved this topic from [App-Beta] Problems, Bugs and other Issues on
                              With genuine enthusiasm I can announce that the position delay will be fixed in the upcoming 4.1.3 update! ๐ŸŽ‰
                              Thanks for testing @Stefan-Hummelink โค
                              He had an Android device that displayed the issue consistently and now that is gone! ๐Ÿ˜ƒ Therefore I can only conclude that our efforts were not in vain!
                              Stefan Hummelink RetiredWingMan 2 Replies Last reply
                                @Corjan-Meijerink said in Position delay/lag quick fix - which app works, which do not?:
                                So glad and proud that I was able to contribute to your solution! ๐Ÿ˜Ž
                                  @Corjan-Meijerink Great news ! One more step towards a solid reliable app. I plan to stay away from AA and CP for the foreseeable future. ๐Ÿ˜€
                                  • Yannick R
                                    Yannick R
                                    Yannick R
                                    wrote on last edited by Yannick R
                                    #22
                                    Same problem here!
                                    Brand: Oppo
                                    Type: Reno 6pro
                                    OS version: Android 13.1
                                    Waze: delay gone
                                    My friend has the same problem with:
                                    Brand: Oppo
                                    Type: Reno 10 pro
                                    Waze: delay gone
                                    • Yannick R Yannick R
                                      Same problem here!
                                      Brand: Oppo
                                      Type: Reno 6pro
                                      Waze: delay gone
                                      Brand: Oppo
                                      Type: Reno 10 pro
                                      Waze: delay gone
                                      @Yannick-b Thanks for your response!
                                      Luckily for us, the dev's managed to fix this delay issue in total in the latest Beta release. This version will eventually become the public release but you'll have to wait a bit๐Ÿ˜„
                                      I can confirm that the latest Beta solved the delay issue for me!
                                      Yannick R 1 Reply Last reply
                                        Yannick R
                                        Yannick R
                                        Yannick R
                                        @Stefan-Hummelink i am an beta user
                                        my last update was on 9-5.
                                        That day i still had the delay
                                          @Yannick-b Can you please tell us which beta version you were actually running during that treft in 9-5?
                                          Jรถrgen
                                          Jรถrgen
                                          Tom Brady
                                          Tom Brady
                                          Yannick R
                                          Yannick R
                                          Peter Verweij
                                          Peter Verweij
                                          • F038 Keeping track โ€“ knowing where everything is โ€“ shared and linked R/T
                                          • Online map settings
                                            MartinW
                                            MartinW
                                            1.0k
                                          • Webapp-icoon
