  4. Position delay/lag quick fix - which app works, which do not?
navigationnextpositiondelay
36 Posts 10 Posters 20.2k Views 4 Watching
  • Stefan Hummelink Offline
    Hi All,
    As is quite familiar by know, several users are bothered by a position delay of the cursor/flyer in relation to the actual position the road. I was one of the first users here to confirm (back in spring 2023 or so) that running another GPS app, such as Flitsmeister in parallel to MRA Navigation Next almost completely solves this issue. At the time I was already relieved to find that FM worked a charm and did not look any further.
    Since this issue has by now been identified to be caused by the HERE SDK, I've checked whether or not FM is the only app that shows improvements to the position delay.
    I would like to ask all users that are familiar with this use, that is: they are still bothered with it, to check whether or not other GPS apps are also effective in signficantly reducing the position delay/lag.
    These results may aid Corjan and HERE in finding the root cause.
    Phone characteristics:
    • Brand: OnePlus
    • Type: OnePlus 6 (ONEPLUS A6003)
    • OS version: Android 11, OxygenOS 11.1.2.2
    • OS Build nr: ONEPLUS A6003_22_211125
    I checked the following apps:
    • Flitsmeister: delay gone
    • Waze: delay gone
    • TomTom MyDrive: no effect
    • Google Maps: no effect
    On behalf of us all: thanks 😁
    Con Hennekens 4 Replies Last reply
      Hi All,
      • Brand: OnePlus
      • Waze: delay gone
      @Stefan-Hummelink, I thought it made no difference as to which other app you have running, as long as they use the Google location service? I'll gather some info.
        @Con-Hennekens said in Position delay/lag quick fix - which app works, which do not?:
        This on its own would be contradicted by the fact that running GMaps in parallel did nothing at all for the delay on my OP6. 😄
          Hi All,
          • Brand: OnePlus
          • Waze: delay gone
          @Stefan-Hummelink,
          First case is in, my wife 😉
          • Brand: Oppo
          • Type: A72 (CPH2067)
          • OS version: Android 11, ColorOS 11.1
          FlitsMeister seems to help, but we have to check again.
            Hi All,
            • Brand: OnePlus
            • Waze: delay gone
            @Stefan-Hummelink,
            Second case in, my son 😉
            • Brand: Motorola
            • Type: G73 (XT2237-2)
            • OS version: Android 13
            Flitsmeister active in background does not help.
              Hi All,
              • Brand: OnePlus
              • Waze: delay gone
              @Stefan-Hummelink,
              Third case in, a friend 😉
              • Brand: Oppo
              • Type: A5 (CPH1931)
              • OS version: Android 10, ColorOS7.1
              GMaps seems to help a bit, Flitmeister not tried yet.
                @Stefan-Hummelink, I think the devices chipset could be a big deal for this problem. But that is more difficult to ask for.
                  devices chipset
                  Indeed, if the HERE dev's think that may be a good to know, they can extract it based on our provided model info :).
                    devices chipset
                    @Stefan-Hummelink, exactly.
                    • RetiredWingMan Offline
                      FM is not available in my area, j found that running a Speedometer app in the background fixes the issue.
                      Samsung Galaxy S20 5G. Android 13 UI 5.1
                        @RetiredWingMan Thanks for reporting! 😄
                        • Jörgen Offline
                          Jörgen Offline
                          iPhone 12
                          iOS 17.4.1
                          MRA 4.1.2 303
                          No other GPS tool running
                          No delay
                            iPhone 12
                            iOS 17.4.1
                            MRA 4.1.2 303
                            No delay
                            @Jörgen said in Position delay/lag quick fix - which app works, which do not?:
                            No delay
                            Hahahaha Although it was the idea to post the phones that do have a delay, your response is always welcome 😁...
                            Jörgen 1 Reply Last reply
                            • Stefan Hummelink Stefan Hummelink referenced this topic on
                            • M. Schrijver Offline
                              The GPS receiver is in most cases a part of the phones SOC.
                              The cause is probably the SOC software together with Here software
                              You need to build a large database with Phones specs and which has the problem or not. From there Here needs to do some fixes.
                              Sadly there are to much different phones in use to build a proper database on this forum.
                              My Input:
                              I use Android Auto which uses the Goldwings GPS receiver.
                              This one is most of the time a bit behind. How much?
                              Mostly 20-50 meters but sometimes up to 200 meters.
                                My Input:
                                @M-Schrijver said in Position delay/lag quick fix - which app works, which do not?:
                                Haha ya, for sure. This was an initial attempt. 😊
                                • Peter Verweij Offline
                                  Peter Verweij
                                  Here also on both an iPhone SE 2020 and a Google Pixel 7, there is a significant delay and therefore worthless to start and promote use in our Oldtimer Club.
                                  If there is a solution please do, because this makes all other great solutions within MRA unusable.
                                    No delay
                                    Jörgen Offline
                                    Jörgen Offline
                                    @Stefan-Hummelink said in Position delay/lag quick fix - which app works, which do not?:
                                    No delay
                                    Ok, ok,
                                    Today with
                                    Oukitel tablet RT3
                                    Android 12,
                                    MRA 4.1.2 V 303
                                    Big delay (20-30m)
                                    With Altimeter App runing in the background
                                    No or acceptable delay.
                                      No delay
                                      Ok, ok,
                                      Today with
                                      Oukitel tablet RT3
                                      Android 12,
                                      MRA 4.1.2 V 303
                                      Big delay (20-30m)
                                      Awesome! This is the kind of information that may be useful for @Corjan-Meijerink to feedback to HERE, or HERE can read this forum thread haha.
                                      • GEORGIOS PANTELIDIS 0 GEORGIOS PANTELIDIS 0 referenced this topic on
                                      • Corjan Meijerink Corjan Meijerink moved this topic from [Beta] Problems, Bugs and other Issues on
                                      • Corjan Meijerink Offline
                                        With genuine enthusiasm I can announce that the position delay will be fixed in the upcoming 4.1.3 update! 🎉
                                        Thanks for testing @Stefan-Hummelink ❤
                                        He had an Android device that displayed the issue consistently and now that is gone! 😃 Therefore I can only conclude that our efforts were not in vain!
                                        Stefan Hummelink RetiredWingMan 2 Replies Last reply
                                          @Corjan-Meijerink said in Position delay/lag quick fix - which app works, which do not?:
                                          So glad and proud that I was able to contribute to your solution! 😎
                                          Tom Brady
                                          Tom Brady
                                          Yannick R
                                          Yannick R
                                          Peter Verweij
                                          Peter Verweij
                                            12.5k
                                          • HERE maps updates
                                          • Latest version of the App?
                                            1.4k
                                            Alfred Schrittwieser
                                            Bruno 7
                                            Bruno 7
