  4. Routing difference between web and Tomtom Rider 550
12 Posts 6 Posters 1.5k Views 1 Watching
  • Lukas 6undefined Offline
    Lukas 6
    wrote on last edited by Lukas 6
    I am planning a route on the web-planner. I want to go to a certain spot, where you can stop on the side of the road (no official parking space, atleast not on the tomtom map), stop there, have a look around and then leave in the same direction I came from. This section of my planned route is shown below.
    When I copy this route (I tried .itn and gpx 1.1) to my TomTom Rider 550, the route changes, as the navigation device seems to think that turning around on this road is not possible. It then routes me approx. 30km further ahead until there is a small town where it can turn around.
    I tried all tricks I know (putting another waypoint close by, making the connections offroad) but to no avail. Does anybody have a suggestion how I could achieve correct routing on the device? The current result is, that the route shows as way longer than it really will be, resulting in wrong arrival times
    Second picture shows the routing on the tomtom device:
    Con Hennekensundefined Nick Carthewundefined 2 Replies Last reply
    • Lukas 6undefined Lukas 6
      @Lukas-6, First thought is that the waypoint is not set specifically on the road, but a bit next to the road?
      Lukas 6undefined 1 Reply Last reply
        Lukas 6
        @Con-Hennekens Thank you for your suggestion. To be 100% sure I checked the planed route and the points are all exactly on the road. I tried to move them slightly (100-200m) on the road to see if that resolves the rpouting issue, but no luck.
          Nick Carthewundefined Online
          @Lukas-6 Have you tried positioning another route point to the south of your route point 2 to try and force your Rider 550 to turn around sooner?
          I noticed similar things when I used to use a Rider 500.
          Your 550 will re-adjust itself after you turn at your route point 2.
            Lukas 6
            @Nick-Carthew Thanks for the tip. I tried this, but the Tomtom still wants to drive far north before turning. Even with multiple waypoints south. It's kinda amazing how stubborn it is..
            My workaround is to split this route into multiple routes. If I set my endpoint, where currently Point 2 is. it obviously stops there and does not ant to drive onwards. But I now hae three routes for one driving day instead of one. (have another point on the same day where the same issue exists)
              @Lukas-6 I seem to remember Tomtom having an option for no u-turns. Is it possible that is causing the issue? Tomtom is looking for a place to reverse your route without doing a u-turn.
              Con Hennekensundefined Lukas 6undefined 2 Replies Last reply
                @RetiredWingMan, I think you nailed it... 😉
                  Lukas 6
                  @RetiredWingMan Thanks for your tip. I cannot for the life of me find such an option. I have scoured the options of my rider 550 forward and backwards as well as read through the (very boring) user manual.
                  If you or anybody could point me to where I can find this option and deactivate it, it would be much appreciated
                    @Lukas-6 I think this may have been an option for earlier models but it’s not available on the latest.
                    • Tony 13undefined Offline
                      Tony 13
                      I have had this problem with Tom Tom, but unhelpfully no solution.
                      We had taken a wrong turn and I thought Tom Tom had calculated a new route. It was 5 miles up a narrow lane before I realised it was just taking me to somewhere it knew I could turn around.😠
                        M. Schrijverundefined Offline
                        If you know you need to turn around at this point. Just turn around when you are there. TomTom will follow pretty quickly.
                        There are sometimes situations which you can not fix in advance
                          Lukas 6
                          Thank you all again for your suggestions. I am splitting the affected routes, which allows for accurate time of arrival calculation. The issue is resolved with this workaround. Until tomtom implements a u-turn option in the rider 550 or changes the navi‘s routing calculation there is no other way and I am pretty certain, that the error is not to be found within the myroute planner.
                          Tony 13undefined
                          Tony 13
                          Lukas 6undefined
                          Lukas 6
                          • POI
                            Martin Garandundefined
                            Martin Garand
                          • 5.0.0 (420) MRA Route Planner - Waypoint Placement Behaviour
                          • Maken van routes als TomTom gebruiker
                          • Multiple users to edit route
                            Martin Garand
                          • Creating and populating Events should be renewed too!
                          • change time incorrect
                            Nick Carthew RouteXpert Seniorundefined
                          • 5.0.0 (420) on Android Tablet
                          • 5.0 420 Android app does not start after closing with back button
