  4. Via-punt niet herkend - te kleine marge
29 Posts 10 Posters 11.9k Views 2 Watching
    @Stefan-Hummelink @Con-Hennekens As someone who has zero knowledge of any of the technical matters that you two are discussing, I find myself becoming slightly aroused with your conversation 😁
    @Nick-Carthew, I am glad for you that you reach such a state on written words alone 😉 I am the first to admit my knowledge on the subject is rather slim. I am just trying to wrap my head around the problem at hand.
    @Stefan-Hummelink, yes I am aware that the app itself does not talk directly to the hardware. But if devs want to solve this, they first must know what to solve. In my imagination, while the hardware switches from antenna to antenna, there will be a short moment of "no data" while the signal strength is high. The problem is that switching antennas can happen literally ANY time. implementing an internet connection bandwidth test will NOT prevent the hardware from switching towers, resulting in a short "no data" phase. If we know that, for example, the "no data" phase of such a switch is 20ms, dev could perhaps implement a second calculation event 50ms after the first one fails. Probably enough to overcome a no data phase, and little enough for anyone to notice. All completely hypothetical of course.
    @Nick-Carthew, are you okay? 😉
      @Con-Hennekens said in Via-punt niet herkend - te kleine marge:
      I'm lying back now and having a cigarette 😉
        @Nick-Carthew said in Via-punt niet herkend - te kleine marge:
        • reinier.beenengmail.com
          Today I drove on the A12 near Gouda and saw 2 times that the app was going offline for a moment. Just a few seconds and than it was back again. That’s a problem I’ve never had before. This must be a bug in the MRA-app.
          • Tom Cat
            Tom Cat
            Tom Cat
            I experienced the same issue as the OP this week. At first I thought maybe my waypoint was off the road. I knew where I was going so it didn't matter but when I got home and checked the route, the waypoint was on the road.
            It also happened at the end of two different routes with my endpoint. I rode through the final waypoint and it kept trying to route me back to it. I am using a Pixel 7 and this happened once on my phone and twice through Android Auto.
            • Tom Cat Tom Cat
              @Tom-Cat said in Via-punt niet herkend - te kleine marge:
              This is by design. If you pass the finish, it will keep calculating to it, in case you need the assistance.
              Tom Cat 1 Reply Last reply
                Tom Cat
                Tom Cat
                Tom Cat
                This is a bit unusual. I've never seen that in a navigation app before.
                • Tom Cat Tom Cat
                  @Tom-Cat I prefer it that way though!
                  • TorqueRider
                    I find it inconvenient. Extra work and annoying.
                    • TorqueRider TorqueRider
                      @Jack-van-Tilburg, it's ideal. You don't have to restart the route of you need to go around the block. It's VERY convenient. About what extra work are you talking?
                      Thereby, it has been discussed before. It's by design, so it is what it is.
                        So no further reaction is necessary.
                        Arno 0
                        Arno 0
                        Vincent Curren
                        Vincent Curren
                        Tom Cat
                        Tom Cat
                          MartinW
                          MartinW
                        • Béta to no-béta
