  3. [App-Beta] Announcements
  4. New Beta! (v4.0.4)
New Beta! (v4.0.4)
49 Posts 22 Posters 453 Views 7 Watching
    Just in time for the weekend! 🎉
    The previous Beta had some awesome new features and we try to continue on the same pace. The update might not contain the biggest changes but nonetheless enough good stuff to start releasing it to the public 😉
    Detailed lane assistance
    Where applicable (mostly highways), you can now enable the app to show a detailed image of the lanes you should use.
    This information is only available on the primary roads. Within the screen layout settings, you can configure the lane instruction to be off / simple / detailed. The simple setting represents the lane instructions as you are used too 😉
    Spoken waypoint information
    In the previous update, we changed the layout of presenting waypoint information.
    In the the audio settings of the app, you can choose between waypoint notifications off / via / all.
    • Off: never spoken
    • Via: only viapoints are mentioned
    • All: both via- and shapingpoints are mentioned
    In the previous app version, this would just be a generic notification about approaching a waypoint. In the update, a feature unique for MRA is added. The title and possible description of the waypoint are actually read to you! 😏
    Note: if the title of a waypoint is merely an address and no description is present, we do not read it to you. If you truly want a waypoint to be read to you; either ensure no numbers are present in the name or add a description.
    Improved warnings for motorhomes
    To ensure y'all do not crash your motorhomes into tunnels, we enhanced the warnings specifically for your vehicle dimensions.
    If you exceed (or are very close to) the dimensions of the upcoming road, you receive an audio / visual warning. We also added the applicable restrictions as icons to the map.
    Note: these are only displayed when driving a motorhome route. Ensure you set your vehicle dimensions correctly
    Voice prompt configuration
    Quite some people were annoyed with the amount of voice prompts you would get for each instruction. You can now select an amount between 1 and 4 voice prompts per instruction.
    The lower the number, the less instructions you receive.
    Note: 0 is not available because if you do not want any voice prompts, just turn it off 😉
    Automatically start tracking
    Do you often forget starting a tracklog? Simply turn on this setting! 🎉 When driving a (scenic) route, the tracklog will automatically start.
    Note: AB routes won't be recorded automatically
    Updated settings
    More settings as described above are available. These are the updated settings.
    Automatic resuming and recenter camera
    Ever had a brake and forgot to resume your tracklog?
    Did you had a drop of rain messing with your screen?
    Issues of the past! When we detect you are moving, a paused tracklog will automatically resume and the camera will refocus on your position after 5 seconds of continuous movement.
    Note: only works while navigating and cannot be turned off
    Fixed issues
    • Grey screen (mostly Android) when resuming navigation
    • Audio channel configuration iOS - this should solve the volume issues / radio interrupt you were experiencing
    • Some Android Auto stability improvements
    Minor changes
    • Account screen can be used when not logged in - allowing users to change settings or view their downloads even when not logged in.
    • After editing a route and going back to the app, the app refreshes the information about that route
    • Improved adding favorites - you can now immediately edit a saved favorite
    That's it 💪
    So what is coming up?
    • Still investigating and working on a solution for battery usage with HERE
    • Android Auto & CarPlay stability
    • Android Auto & CarPlay features
    • Next update will contain nearby fuel stops! 🎉
    Have an awesome weekend. Looking forward to the feeback.
    Cheers,
    Corjan
    Inge Bakermans
    Inge Bakermans
    Inge Bakermans
    @Corjan-Meijerink I am loving this update especially the lane and audio (reading the added info)
      • Off: never spoken
      Updated settings
      Fixed issues
      Minor changes
      That's it 💪
      Cheers,
      Corjan
      #33
      Gread work Team 👍
      • richtea999 richtea999
        @Corjan-Meijerink I have to admit I assumed the extra prompts would push them further out. The order surprised me (and no-one could guess it, I reckon!)
        I had already set mine to 2 expecting the 500m and 'Now' prompts. I'm glad you explained it, but I recommend the options extend in distance with increasing number, since that's more logical - and you won't have to keep explaining it.
        Then people who navigate by mostly audio will probably pick option 3 or 4.
        And those who navigate mostly by the map will probably pick 1 or 2 (me) - or switch the audio off.
        I've now gone back to 3. That is, until you change it. 😁
        @richtea999 totally agree with you. I was curious when I tried the new version which is why I asked the question. I hope it will be changed to what people are saying here as I had assumed the same.
        Ducati Multistrada V4 Rally
        iPhone 18 Pro
        CHIGEE AIO-6 LTE
        Google Pixel 6 Pro
        • cvlmtg
          cvlmtg
          cvlmtg
          @Corjan-Meijerink any update on offline usage? are you planning on improving at least the route downloads?
          Dave J 0 Corjan Meijerink 2 Replies Last reply
          • cvlmtg cvlmtg
            @cvlmtg said in New Beta! (v4.0.4):
            Curious. What do you mean by this?
            iPhone 18 Pro
            CHIGEE AIO-6 LTE
            Google Pixel 6 Pro
            cvlmtg 1 Reply Last reply
            • Dave J 0 Dave J 0
              cvlmtg
              cvlmtg
              cvlmtg
              @Dave-J-0 currently if you want to download your routes, so you can use them with no internet connection, you have to download them one by one, and to see which one are downloaded you have to go to a completely different section of the app. This is one of the main reasons I'm still using mapy instead of myroute-app.
              • cvlmtg cvlmtg
                @cvlmtg no, not yet 😞
                • Dikke Wim
                  Dikke Wim
                  Dikke Wim
                  Great new features! Compliment again for the MRA team!
                  Any idea when the iOS version will be available?
                  Can't wait to test the new version 🙂
                  • Ruud Schouten
                    Ruud Schouten
                    Ruud Schouten
                    Great! Looking forward to test v4.0.4 🙂 Thanks for the hard work.
                    • Ruud Schouten
                      Ruud Schouten
                      Ruud Schouten
                      v4.0.4 not available for IOS yet....?
                      Corjan Meijerink Dikke Wim richtea999 3 Replies Last reply
                      • Ruud Schouten Ruud Schouten
                        @Ruud-Schouten they take their time 🙂
                        Koen VH 1 Reply Last reply
                          Koen VH
                          Koen VH
                          Koen VH
                          @Corjan-Meijerink Again a nice upgrade, testing can start 😉
                          iPhone SE (2020) - Outikel RT3 (Android 12)
                          • CD130
                            Wow, what an amazing update again! Really! I have one small request though. I would really appreciate it if the tracklog also starts automatically during A to B navigation. I'd also love to be able to use the app to create a tracklog when I'm following someone without a predefined route, in the yet-to-be-existing "freeride mode," which has also received many requests for speed camera alerts. Then, I can happily remove my current tracklog recording app, and the MRA-app would truly be an all-in-one solution for me.
                            Keep up the great work!! Thank you 🙂
                              Dikke Wim
                              Dikke Wim
                              Dikke Wim
                              @Ruud-Schouten
                              Now available for iOS!
                              Ruud Schouten 1 Reply Last reply
                                #46
                                • Dikke Wim Dikke Wim
                                  @Ruud-Schouten
                                  Ruud Schouten
                                  Ruud Schouten
                                  Ruud Schouten
                                  @Dikke-Wim Thanks, I saw it this morning 🙂
                                  • Stanisław
                                    New lane assist is impressive! 🙂 I would prefer a little bigger font with the distance to the crossroads on the picture, would be possible?
                                    Staszek
                                    • Stanisław Stanisław
                                      @Stanisław yes, it is!
                                      Òscar
                                      Òscar
                                      Skellum
                                      Skellum
                                      Dikke Wim
                                      Dikke Wim
                                      Ruud Schouten
                                      Ruud Schouten
                                      Inge Bakermans
                                      Inge Bakermans
                                      cvlmtg
                                      cvlmtg
                                      Steve Lynch
                                      Steve Lynch
                                      Ian foster 0
                                      Ian foster 0
                                      Koen VH
                                      Koen VH
                                      • Hide warnings on the map
                                      • Map Layers
                                        Martin White
                                        Martin White
                                        Michael 2v
                                        Michael 2v
                                      • Bollard trouble
