  3. [App-Beta] Announcements
  4. New Beta! (v4.0.4)
New Beta! (v4.0.4)
49 Posts 22 Posters 453 Views 7 Watching
    Just in time for the weekend! 🎉
    The previous Beta had some awesome new features and we try to continue on the same pace. The update might not contain the biggest changes but nonetheless enough good stuff to start releasing it to the public 😉
    Detailed lane assistance
    Where applicable (mostly highways), you can now enable the app to show a detailed image of the lanes you should use.
    This information is only available on the primary roads. Within the screen layout settings, you can configure the lane instruction to be off / simple / detailed. The simple setting represents the lane instructions as you are used too 😉
    Spoken waypoint information
    In the previous update, we changed the layout of presenting waypoint information.
    In the the audio settings of the app, you can choose between waypoint notifications off / via / all.
    • Off: never spoken
    • Via: only viapoints are mentioned
    • All: both via- and shapingpoints are mentioned
    In the previous app version, this would just be a generic notification about approaching a waypoint. In the update, a feature unique for MRA is added. The title and possible description of the waypoint are actually read to you! 😏
    Note: if the title of a waypoint is merely an address and no description is present, we do not read it to you. If you truly want a waypoint to be read to you; either ensure no numbers are present in the name or add a description.
    Improved warnings for motorhomes
    To ensure y'all do not crash your motorhomes into tunnels, we enhanced the warnings specifically for your vehicle dimensions.
    If you exceed (or are very close to) the dimensions of the upcoming road, you receive an audio / visual warning. We also added the applicable restrictions as icons to the map.
    Note: these are only displayed when driving a motorhome route. Ensure you set your vehicle dimensions correctly
    Voice prompt configuration
    Quite some people were annoyed with the amount of voice prompts you would get for each instruction. You can now select an amount between 1 and 4 voice prompts per instruction.
    The lower the number, the less instructions you receive.
    Note: 0 is not available because if you do not want any voice prompts, just turn it off 😉
    Automatically start tracking
    Do you often forget starting a tracklog? Simply turn on this setting! 🎉 When driving a (scenic) route, the tracklog will automatically start.
    Note: AB routes won't be recorded automatically
    Updated settings
    More settings as described above are available. These are the updated settings.
    Automatic resuming and recenter camera
    Ever had a brake and forgot to resume your tracklog?
    Did you had a drop of rain messing with your screen?
    Issues of the past! When we detect you are moving, a paused tracklog will automatically resume and the camera will refocus on your position after 5 seconds of continuous movement.
    Note: only works while navigating and cannot be turned off
    Fixed issues
    • Grey screen (mostly Android) when resuming navigation
    • Audio channel configuration iOS - this should solve the volume issues / radio interrupt you were experiencing
    • Some Android Auto stability improvements
    Minor changes
    • Account screen can be used when not logged in - allowing users to change settings or view their downloads even when not logged in.
    • After editing a route and going back to the app, the app refreshes the information about that route
    • Improved adding favorites - you can now immediately edit a saved favorite
    That's it 💪
    So what is coming up?
    • Still investigating and working on a solution for battery usage with HERE
    • Android Auto & CarPlay stability
    • Android Auto & CarPlay features
    • Next update will contain nearby fuel stops! 🎉
    Have an awesome weekend. Looking forward to the feeback.
    Cheers,
    Corjan
    Bart De Medts Stanisław Ian foster 0 Steve Lynch Nick Carthew 10 Replies Last reply
      • Off: never spoken
      Updated settings
      Fixed issues
      Minor changes
      That's it 💪
      Cheers,
      Corjan
      @Corjan-Meijerink Great work (again!!) 🙂
        • Off: never spoken
        Updated settings
        Fixed issues
        Minor changes
        That's it 💪
        Cheers,
        Corjan
        @Corjan-Meijerink by "Note: AB routes won't be recorded automatically" you mean route created directly in the navigation app or also routes started from the MRA planned routes but without any VIA/shaping point?
        Anyway great news, waiting for possibility to test it!
        Staszek
          • Off: never spoken
          Updated settings
          Fixed issues
          Minor changes
          That's it 💪
          Cheers,
          Corjan
          Ian foster 0
          Ian foster 0
          Ian foster 0
          @Corjan-Meijerink Looks like a great update yet again thanks 👍
            • Off: never spoken
            Updated settings
            Fixed issues
            Minor changes
            That's it 💪
            Cheers,
            Corjan
            Steve Lynch
            Steve Lynch
            Steve Lynch
            Simply and beautifully awesome.
            You are the man!!!
            • b0hd1
              "We're going to try it out!!"
              • https://t.me/MRa_by_b0hd1
              • YouTube: @demco17
              • Stanisław Stanisław
                @Stanisław yeah, AB routes are routes that are generated by app using the fastest option.
                Example: search for an address (keep it to fastest) and go - that's AB.
                Lynchy67 2 Replies Last reply
                  This update is so good I had to post with both my accounts.
                  You really are the man!
                  • Lynchy67 Lynchy67
                    @Lynchy67, may I ask for the reason for double accounts?
                    Nick Carthew Lynchy67 2 Replies Last reply
                      @Con-Hennekens said in New Beta! (v4.0.4):
                      It’s known as a burner account, it can’t be traced if you’re caught speeding. Don’t you have one 😏
                        • Off: never spoken
                        Updated settings
                        Fixed issues
                        Minor changes
                        That's it 💪
                        Cheers,
                        Corjan
                        @Corjan-Meijerink Great work again mate. 👏
                          Android is available to download.
                          iOS still in review 😉
                          Dave J 0 1 Reply Last reply
                            @Corjan-Meijerink just downloaded the Android version. Great job and just in time for a big ride in a couple of days. 😀
                            Ducati Multistrada V4 Rally
                            iPhone 18 Pro
                            CHIGEE AIO-6 LTE
                              Android is available now.
                                • Off: never spoken
                                Updated settings
                                Fixed issues
                                Minor changes
                                That's it 💪
                                Cheers,
                                Corjan
                                @Corjan-Meijerink said in New Beta! (v4.0.4):
                                Does this apply to files in the 'Downloads' file?
                                iPhone 18 Pro
                                CHIGEE AIO-6 LTE
                                Nick Carthew Corjan Meijerink 2 Replies Last reply
                                • Dave J 0 Dave J 0
                                  @Dave-J-0 said in New Beta! (v4.0.4):
                                  Great question.
                                  If you edit a previously download route, does the link in the downloads folder change to the edited version?
                                  • Dave J 0 Dave J 0
                                    @Dave-J-0 @Nick-Carthew No 🙂
                                    Only the behavior that when you opened a route, click the pencil icon (edit), change stuff and close the browser: you will see the route refreshing.
                                      @Corjan-Meijerink Understood. So delete previous downloaded version and re-download the edited version for use off-line. 👍
                                        Of course you can ask!
                                        For a long time I had iPhones and only a single iOS MRA Account.
                                        Then I simply got fed up and bored with iOS and decided to try an android phone.
                                        First i bought a second hand S10 5G and more recently upgraded to a second hand Samsung S21+
                                        I will never buy a brand new phone again!
                                        Yes I have paid twice for the full MRA Navigation experience.
                                        For me its a navigation device first and secondly a phone that I rarely use to make calls.
                                        Also I have an 9" iPad and a 12" iPad Pro so in theory I can test iOS as well.
                                        Maybe one day iOS will wooh me back into their fold!
                                          @Nick-Carthew no need to delete, new download will replace the old one 😉
                                          Dikke Wim
                                          Dikke Wim
                                          Skellum
                                          Skellum
                                          Inge Bakermans
                                          Inge Bakermans
                                          Ruud Schouten
                                          Ruud Schouten
                                          cvlmtg
                                          cvlmtg
                                          Steve Lynch
                                          Steve Lynch
                                          Ian foster 0
                                          Ian foster 0
                                          Koen VH
                                          Koen VH
                                          • Strange translation
                                          • Crazy routing
                                          • Undo/Redo tool is hidden
                                          • Shared toggle switch
