  3. [App-Beta] Announcements
  4. New Beta! (v4.0.4)
New Beta! (v4.0.4)
49 Posts 22 Posters 453 Views 7 Watching
    Just in time for the weekend! 🎉
    The previous Beta had some awesome new features and we try to continue on the same pace. The update might not contain the biggest changes but nonetheless enough good stuff to start releasing it to the public 😉
    Detailed lane assistance
    Where applicable (mostly highways), you can now enable the app to show a detailed image of the lanes you should use.
    This information is only available on the primary roads. Within the screen layout settings, you can configure the lane instruction to be off / simple / detailed. The simple setting represents the lane instructions as you are used too 😉
    Spoken waypoint information
    In the previous update, we changed the layout of presenting waypoint information.
    In the the audio settings of the app, you can choose between waypoint notifications off / via / all.
    • Off: never spoken
    • Via: only viapoints are mentioned
    • All: both via- and shapingpoints are mentioned
    In the previous app version, this would just be a generic notification about approaching a waypoint. In the update, a feature unique for MRA is added. The title and possible description of the waypoint are actually read to you! 😏
    Note: if the title of a waypoint is merely an address and no description is present, we do not read it to you. If you truly want a waypoint to be read to you; either ensure no numbers are present in the name or add a description.
    Improved warnings for motorhomes
    To ensure y'all do not crash your motorhomes into tunnels, we enhanced the warnings specifically for your vehicle dimensions.
    If you exceed (or are very close to) the dimensions of the upcoming road, you receive an audio / visual warning. We also added the applicable restrictions as icons to the map.
    Note: these are only displayed when driving a motorhome route. Ensure you set your vehicle dimensions correctly
    Voice prompt configuration
    Quite some people were annoyed with the amount of voice prompts you would get for each instruction. You can now select an amount between 1 and 4 voice prompts per instruction.
    The lower the number, the less instructions you receive.
    Note: 0 is not available because if you do not want any voice prompts, just turn it off 😉
    Automatically start tracking
    Do you often forget starting a tracklog? Simply turn on this setting! 🎉 When driving a (scenic) route, the tracklog will automatically start.
    Note: AB routes won't be recorded automatically
    Updated settings
    More settings as described above are available. These are the updated settings.
    Automatic resuming and recenter camera
    Ever had a brake and forgot to resume your tracklog?
    Did you had a drop of rain messing with your screen?
    Issues of the past! When we detect you are moving, a paused tracklog will automatically resume and the camera will refocus on your position after 5 seconds of continuous movement.
    Note: only works while navigating and cannot be turned off
    Fixed issues
    • Grey screen (mostly Android) when resuming navigation
    • Audio channel configuration iOS - this should solve the volume issues / radio interrupt you were experiencing
    • Some Android Auto stability improvements
    Minor changes
    • Account screen can be used when not logged in - allowing users to change settings or view their downloads even when not logged in.
    • After editing a route and going back to the app, the app refreshes the information about that route
    • Improved adding favorites - you can now immediately edit a saved favorite
    That's it 💪
    So what is coming up?
    • Still investigating and working on a solution for battery usage with HERE
    • Android Auto & CarPlay stability
    • Android Auto & CarPlay features
    • Next update will contain nearby fuel stops! 🎉
    Have an awesome weekend. Looking forward to the feeback.
    Cheers,
    Corjan
    @Corjan-Meijerink said in New Beta! (v4.0.4):
    How is the spacing of the voice prompts determined if you select a lower number? I have chosen '2' but I seem to be only receiving one very late announcement. Screenshot_20230831-162944.png
    At motorway speeds, this announcement is also very late. Furthermore with the times I do receive the first announcement of the 2, this tends to be just, "continue on the route.......". I had thought that I may get an initial 0.5mile out warning and then one before I need to turn. Grateful if you could clarify how the variable announcements are determined with distance and moreover, speed.
    I will do some more testing with a more complicated route and not just an A to B. Good work.
    Ducati Multistrada V4 Rally
    iPhone 18 Pro
    CHIGEE AIO-6 LTE
    Google Pixel 6 Pro
    • Dave J 0 Dave J 0
      #22
      @Dave-J-0 thanks! Ofcourse I can elaborate 🙂
      1: The actual action (eg. Turn left now)
      2: Furthest possible notification (eg. Turn left in 5km)
      3: Distance reminder (eg. Turn left in 500m)
      4: General reminder (eg. Turn left in 2km)
      Each number includes the preceding numbers so to say 😉
      The first is the only one guaranteed to exist.
      Dave J 0 Drabslab 2 Replies Last reply
        @Corjan-Meijerink ok. That makes sense. For me, I would prefer if the number 2 was number 4 and then 3 and 4 became 2 and 3 repaectively. Useful to know what others think and will go with the flow. 😀. Btw, the grey screen problem on resume does seem to be cured despite my best efforts to break it. 😂 Great job.
        iPhone 18 Pro
        CHIGEE AIO-6 LTE
        Google Pixel 6 Pro
        Lynchy67 1 Reply Last reply
          wrote on last edited by Drabslab
          #24
          Wow, this is difficult to decide on when starting to think about it.
          I would probably want to turn it around:
          1: The actual action (eg. Turn left now), I always want to hear
          3: Distance reminder (eg. Turn left in 500m), I always want to hear as it is useful at any speed and any road
          4: General reminder (eg. Turn left in 2km) i want to hear sometimes depending whether I go fast or not
          2: Furthest possible notification (eg. Turn left in 5km) I maybe don't need as I am never racing and will already have forgotten the instruction by the time I get to the turning point. 🙂
          Corjan Meijerink Stefan Hummelink 2 Replies Last reply
            @Nick-Carthew no need to delete, new download will replace the old one 😉
            @Corjan-Meijerink yes. This works a treat. Brilliant.
            iPhone 18 Pro
            CHIGEE AIO-6 LTE
            Google Pixel 6 Pro
              • Off: never spoken
              Updated settings
              Fixed issues
              Minor changes
              That's it 💪
              Cheers,
              Corjan
              @Corjan-Meijerink thnkx 4 a great job done
              May the testing begin👍😁
              • Drabslab Drabslab
                @Drabslab @Dave-J-0 Thanks for the feedback! This is exactly what the Beta is for. More than happy to change it if that’s preferred 🙂
                • Drabslab Drabslab
                  @Drabslab said in New Beta! (v4.0.4):
                  +1 !
                  Skellum 1 Reply Last reply
                    +1 !
                    Skellum
                    Skellum
                    Skellum
                    @StefanHummelink said in New Beta! (v4.0.4):
                    +1 !
                    and me! and well done again Corjan 👍
                    • Dave J 0 Dave J 0
                      @Dave-J-0
                      Same here, I spent 30 minutes on a bus loading routes with not a single grey screen in sight.
                      @Corjan-Meijerink 👍
                      • richtea999
                        #31
                        @Corjan-Meijerink I have to admit I assumed the extra prompts would push them further out. The order surprised me (and no-one could guess it, I reckon!)
                        I had already set mine to 2 expecting the 500m and 'Now' prompts. I'm glad you explained it, but I recommend the options extend in distance with increasing number, since that's more logical - and you won't have to keep explaining it.
                        Then people who navigate by mostly audio will probably pick option 3 or 4.
                        And those who navigate mostly by the map will probably pick 1 or 2 (me) - or switch the audio off.
                        I've now gone back to 3. That is, until you change it. 😁
                        Dave J 0 1 Reply Last reply
                          • Off: never spoken
                          Updated settings
                          Fixed issues
                          Minor changes
                          That's it 💪
                          Cheers,
                          Corjan
                          Inge Bakermans
                          Inge Bakermans
                          Inge Bakermans
                          @Corjan-Meijerink I am loving this update especially the lane and audio (reading the added info)
                            • Off: never spoken
                            Updated settings
                            Fixed issues
                            Minor changes
                            That's it 💪
                            Cheers,
                            Corjan
                            #33
                            Gread work Team 👍
                            • richtea999 richtea999
                              @richtea999 totally agree with you. I was curious when I tried the new version which is why I asked the question. I hope it will be changed to what people are saying here as I had assumed the same.
                              iPhone 18 Pro
                              CHIGEE AIO-6 LTE
                              Google Pixel 6 Pro
                              • cvlmtg
                                cvlmtg
                                cvlmtg
                                @Corjan-Meijerink any update on offline usage? are you planning on improving at least the route downloads?
                                Dave J 0 Corjan Meijerink 2 Replies Last reply
                                • cvlmtg cvlmtg
                                  @cvlmtg said in New Beta! (v4.0.4):
                                  Curious. What do you mean by this?
                                  iPhone 18 Pro
                                  CHIGEE AIO-6 LTE
                                  Google Pixel 6 Pro
                                  cvlmtg 1 Reply Last reply
                                  • Dave J 0 Dave J 0
                                    cvlmtg
                                    cvlmtg
                                    cvlmtg
                                    @Dave-J-0 currently if you want to download your routes, so you can use them with no internet connection, you have to download them one by one, and to see which one are downloaded you have to go to a completely different section of the app. This is one of the main reasons I'm still using mapy instead of myroute-app.
                                    • cvlmtg cvlmtg
                                      @cvlmtg no, not yet 😞
                                      • Dikke Wim
                                        Dikke Wim
                                        Dikke Wim
                                        Great new features! Compliment again for the MRA team!
                                        Any idea when the iOS version will be available?
                                        Can't wait to test the new version 🙂
                                        • Ruud Schouten
                                          Ruud Schouten
                                          Ruud Schouten
                                          Great! Looking forward to test v4.0.4 🙂 Thanks for the hard work.
                                          Òscar
                                          Òscar
                                          Skellum
                                          Skellum
                                          Dikke Wim
                                          Dikke Wim
                                          Ruud Schouten
                                          Ruud Schouten
                                          Inge Bakermans
                                          Inge Bakermans
                                          cvlmtg
                                          cvlmtg
                                          Steve Lynch
                                          Steve Lynch
                                          Ian foster 0
                                          Ian foster 0
                                          Koen VH
                                          Koen VH
                                          • Hide warnings on the map
                                          • Map Layers
                                            Martin White
                                            Martin White
                                            Michael 2v
                                            Michael 2v
                                          • Bollard trouble
                                          • Library: Folders at the Top of the Menu
