  4. MRA Routeplanner Improvement: suppress viapoints
10 Posts 6 Posters 3.3k Views 2 Watching
  • Gerard Wullink Offline
    Gerard Wullink
    We plan routes for members of our MC and hand them some documentation regarding the route: places where you can shorten the route etc. I know this can be done by adding info to the via-points, but not all gps devices do understand this format and some even give a failure at import.
    It would be handy to have a clean overview of the route, but the route in editmode shows al the shaping- and via-points which makes it less readable.
    Suggested improvent: Add a possibility to suppres the shaping-points (only these, not the vai-points!) to get a clean view of all the important point on the map.2023-08-01_22h00_53.jpg
    In the picture are two via-points in red which are hardly visible.
    Tip: In the pdf export a picture is created which only shows Start and Finish point, so there seems to be a bit code available, but taht is low-res and not showing the via-points (hard-points)
    Nick Carthew Bart De Medts 2 Replies Last reply
    • Gerard Wullink Gerard Wullink
      Nick Carthew Online
      Nick Carthew Online
      @Gerard-Wullink Why do you need so many route points?
      Jörgen 1 Reply Last reply
        Jörgen Offline
        Jörgen Offline
        @Nick-Carthew said in MRA Routeplanner Improvement: suppress viapoints:
        That was also my first question. A third or less will do it.
        But I agree to the idea to switch off waypoints just to make the route more or better visible.
        Drabslab 1 Reply Last reply
          Drabslab Offline
          Drabslab Offline
          @Jörgen said in MRA Routeplanner Improvement: suppress viapoints:
          Similar to a conversation in another post on yellow track line vs visibility of the blue route line, the via points should always be shown on top of the shaping points, and not be hidden under them.
            Bart De Medts Offline
            @Gerard-Wullink Maybe it would help you to make a track of the route? This will give you a better overview of the route.
            Jack van Tilburg Gerard Wullink 2 Replies Last reply
            • Bart De Medts Bart De Medts
              Jack van Tilburg Offline
              Jack van Tilburg
              @Bart-DM but you can't edit it and that's what this is about
                @Jack-van-Tilburg yes I know, it was just a suggestion to get a better overall view of the route 😀.
                • Corjan Meijerink Corjan Meijerink moved this topic from General Discussion on
                  Gerard Wullink
                  wrote on last edited by Gerard Wullink
                  @Bart-DM We mostly start by genarting a gpx-track which we import (from a magazine, a track genarator (MRA, Kurviger, TomTom etc).
                  This is than converted to a route on OSM. We check the route against HERE and TomTom and add points to make the route 100% same for all systems. Now you
                  In this example I used the function Increase points to test that. It is a bit much, I agree.
                  But it may be oldschool, but after every turn we place a viapoint to make sure that even someone who has selected something else as fastest of shortest as his favorite routecalculation, go the way we planned. That requires some more points to be on the safe side.
                  TomTom has the behaviour to cut corners in villages (riding through living area's) whereas Garmin uses the crossing in center-village to make the turn.
                  We had compliments from users that the routes are not different anymore. So that works.
                  Exporting the track would mean I have to import it again. A track does not show the must-visit/hard points or does it?
                    Jack van Tilburg
                    @Gerard-Wullink said in MRA Routeplanner Improvement: suppress viapoints:
                    I'm old school! And fully understand your working method. Especially if you share the routes with several participants.
                    At the same time, you can use the "Compare" function (and you do) to see whether there are unnecessary routepoints in your route.
                    Less is okay, but too little is not 🙂 .
                    And I fully sympathize with your proposal to a possibility to suppress the shaping-points.
                    Kudos to you!
                    Gerard Wullink 1 Reply Last reply
                      Kudos to you!
                      Gerard Wullink
                      @Jack-van-Tilburg Thanx! I will try to use less points, there is a good reason for that.
                      Gerard Wullink
                      Gerard Wullink
                      Jack van Tilburg
                      Jack van Tilburg
                        3.0k
                      • Export to BMW CRN
                      • Update 5.2.2 - Quick fix
                      • Suggestion about making routes visible in a folder
                        Barteld Hartstra
                        Barteld Hartstra
