  4. Suggestion: display road closures on map
12 Posts 6 Posters 191 Views 1 Watching
  • lasironayahoo.com
    lasironayahoo.com
    lasironayahoo.com
    I think this would be a really useful feature in planning as well. Here's a good example from California...
    Here's a planned route from SF Bay Area to Santa Barbara in MRA:
    Then, if you look at the same section in Google Maps with traffic:
    Those red dots are road closures until December 2023.
    iPhone 14 Pro
      You can switch on Traffic in the planning app (under maps) to see also road closure with black lines.
        If known closures, the app will display them.
        Routeplanner might not as planning isn’t as time based.
        richtea999 1 Reply Last reply
        • lasironayahoo.com
          lasironayahoo.com
          lasironayahoo.com
          Ok, I see what you mean. I would have to walk the path prior to setting my next waypoint. Otherwise, the planned route is black and the road closure indicator is black. Although not optimum, it works. Is there a way to change the color of the planned route? I know there's a transparency setting, but I don't remember seeing colors
          iPhone 14 Pro
          • lasironayahoo.com
            lasironayahoo.com
            lasironayahoo.com
            You can disregard... After spending some time with the traffic setting, I noticed that every other status isn't black. I can use that as an indicator.
            I typically just let routelab set the route unless there's something about the area I want to see. That's why I was curious, so I wouldn't have to walk the routes ahead of time not knowing which route the routelab was actually going to use.
            iPhone 14 Pro
              @Corjan-Meijerink said in Suggestion: display road closures on map:
              Thanks Corjan, is there an example screenshot so I know what the closures will look like next time? (I didnt see anything, but I have, on other occasions, seen a lighter route line, which I guess is the 'original route' mentioned by Jörgen.)
              • richtea999 richtea999
                @richtea999 it’s a dashed red line.
                Cannot find one either at this point and I’ll definitely forget replying later - sorry 🙂
                • richtea999 richtea999 referenced this topic on
                  Like this 🙂
                  Which is different from the red delay line:
                  Arno 0 1 Reply Last reply
                    Like this 🙂
                    Arno 0
                    Arno 0
                    Arno 0
                    @Corjan-Meijerink the examples given are pictures from the navigation app and these make very clear that the road is blocked. However, when creating a route in the planner it's not so clear because then a small black line is shown which you only see when you zoom in. Maybe something to improve when updating the planner 🙂
                    • Arno 0
                      Arno 0
                      Arno 0
                      wrote on last edited by Arno 0
                      Another thing I forgot to mention is that when you select "disable seasonal closures" in the toolkit in the planner, you will not only not see the mountain passes that are closed during winter period but will also not see any road blocks. Therefore it might be good to change the name of the toolkit function in future.
                      Arno 0
                      Arno 0
                      lasironayahoo.com
                      lasironayahoo.com
                      • Help please, new user
                        Bull Tahr
                        Bull Tahr
                      • My Routeapp Stays questions
