  4. Waypoint skipping on planned route
20 Posts 9 Posters 374 Views 2 Watching
  • Jon Edwardsundefined Offline
    Jon Edwards
    My last two planned routes have encountered waypoints being skipped for no reason, 2 waypoints yesterday and again today, this means I have to stop the route reload it, then skip forward to the required “missed” waypoint is this a known issue?
    Thanks
    • Jon Edwardsundefined Jon Edwards
      Thanks
      @Jon-Edwards, Is that reproducible? Could you share the route and indicate on a screenshot where the skipping took place?
      Jon Edwardsundefined 1 Reply Last reply
        Jon Edwards
        @Con-Hennekens said in Waypoint skipping on planned route:
        I don’t think that would be possible but I have another route planned for tomorrow and will keep a close eye on when and where the waypoints are skipped if it happens again, the routes I encountered problems with are in rural Wales.
        I’ll report back tomorrow.
          @Jon-Edwards Fully zoom into each route point by using the magnifying glass 🔎 Check the accuracy and adjust if necessary. Then move onto the next RP by using the right arrow > and do the same.
          You may have had one or two wayward RPs in your previous route.
            Jon Edwards
            wrote on last edited by Jon Edwards
            More skipping fun on my route today:IMG_2355.png
            Picture shows me leaving waypoint 2 but top right waypoint is indicated as number 4IMG_2356.png
            Second picture shows waypoint 3 clearly on the route but its been skippedIMG_2357.png
            3rd picture shows zoomed in waypoint 3. Waypoint 2 is slightly off the main highway but is in fact a long driveway that I had to drive up.
            Later on in my route I chose to skip waypoint number 11 the app skipped to waypoint 13 Picture shows me approaching waypoint 11 and position of waypoint 12IMG_2363.png ? It wouldn't be such an issue if I could go back to a previous waypoint in the app but as things are I have to stop the route, reload it, and then skip the waypoints until I'm back to the "missed" waypoint which is time consuming and a pita. What am I doing wrong? Last picture shows position of waypoint number 12!IMG_2367.png
            Nick Carthewundefined RetiredWingManundefined 2 Replies Last reply
              @Jon-Edwards Is route point 3 on a private road? Maybe the HERE map and therefore the app doesn’t recognise the road as usable which is why it chose to skip RP3
                Jon Edwards
                @Nick-Carthew All waypoints are on public roads, waypoint number 3 is here:Screen Shot 2023-06-16 at 15.16.37.png I visit far more out of the way places than this one, up farm tracks etc and won't encounter the problem, the two incidents today were both on public roads accessible to all.
                  I have also had many occurances of waypoints being skipped before I reach them. Happens in both online and offline. It seems that the app frequently does a quick recalculation, why and for what reason I don't know. Perhaps this has something to do with the issue. All my waypoints are on proper roads.
                    @Jon-Edwards to return to a previous waypoint use the menu to display the route (or the waypoint list) and do a long press on the waypoint you wish to navigate to. Same thing works to skip multiple waypoints.
                      Jon Edwards
                      @Doug-Robinson said in Waypoint skipping on planned route:
                      Thanks Doug thats really helpful👍 , I didn't know you could do that🙄 . It will certainly help next time I encounter the problem.
                      Just for the record on my route yesterday the app skipped one waypoint, as per previous times there was no reason for it, it just skipped waypoint 9 in a 14 waypoint planned route. At least it seems I'm not the only one to encounter this issue so that at least makes me think the problem perhaps lies with the app and not me?.
                      • Bas Greveundefined Offline
                        Bas Greve
                        Just returned from a stay in Iceland and I have had the same problem. One waypoint was set on a place where I should sleep that night but the system kept skipping this point.
                        I made my route in the MRA routeplanner so I supposed that all the waypoints I set there would be valid waypoints in the Myroute App. But that is not the case. Strange.....
                          Jon Edwards
                          Continuing problems with waypoints automatically being skipped, happened again today, point 7 and point 10 on my planned route were skipped. Not such a problem when I'm in an area I know but it will be a major problem if it does it in areas I don't know.... Starting loose faith.
                            Jon Edwards
                            It would be good to hear from the team if this issue is going to be looked at?. I see another post now with others experiencing the same issue, the advice by Doug Robinson makes things easier to rectify when a waypoint is skipped but as things stand I'm constantly watching the waypoint marker to make sure the next waypoint is correct as it can be skipped at any time.
                            To clarify, my route waypoints represent house calls, so if a waypoint gets skipped it can lead to me missing an appointment and then having to double back on myself which is time consuming and frustrating . Later in the year I have a tour of France/Spain(for leisure) planned with the route already prepared but I'm very reluctant to use MyRoute-app for this trip given the current issue. I appreciate the replies on this thread, they have been very helpful but this part of the forum(or at least this post) has gone very quiet recently, I would just like to know if there is a chance of this issue being solved or if its just going to get forgotten about?
                            Stefan Hummelinkundefined Con Hennekensundefined 2 Replies Last reply
                              @Jon-Edwards If you really have MUST stop or reach certain waypoints, make them a via point (✋ symbol). Via points are NOT automatically skipped, never! You can however manually skip these.
                                Or turn off the auto skip feature 🙂
                                  @Jon-Edwards, It is really nice to see people using the app for things other than what it really was intended for (scenic routes). Could you share a typical route so we can see what it looks like? I am guessing that a house-call route can be very zig-zag in style. Devvers might be able to deduct an alteration to the skipping algorithm, that prevents the incorrect skipping. We could all benefit from that. We have been riding 850Km in Eifel last weekend, and the app did not once skip incorrectly. But improvement is always good!
                                  In the meantime @StefanHummelink and @Corjan-Meijerink mentioned two possible methods to prevent skipping WP at all.
                                  • Dave J 0undefined Online
                                    I have had the odd skip with the latest build (194 on Android 13) when I was on the route showing and I had not deviated. The skip appeared to happen when I did a large direction change on the route. Might be due to GPS lock or the quick direction change but I have had it previously on small roundabouts where I have been able to take the third or fourth exit at a reasonable pace. Not sure although it has happened less with the last build (194) - I do use all the methods described previously. Nonetheless, I will be doing some more testing over the next few days.
                                    Ducati Multistrada V4 Rally
                                    iPhone 15 Pro
                                    CHIGEE AIO-6 LTE
                                    CHIGEE AIO-5 Play
                                      Jon Edwards
                                      Thank you for the suggestions, auto skip is now turned off, and I will plan future routes using via points.
                                      Thank you for the input, I will report back after my next outing.
                                        Jon Edwards
                                        @Jon-Edwards Still not without the odd skip but above suggestions have certainly helped.
                                        • Nico 10undefined Offline
                                          Nico 10
                                          Had the same problem a few times. Yesterday it was skipping to waypoint 8 while I still had to reach 6. It looked like it was continuing skipping 2 waypoints ahead but i reloaded the route. For now I have disabled automaticly skipping waypoints.
                                          Dave J 0undefined
                                          Nico 10undefined
                                          Nico 10
                                          Jon Edwards
                                          Bas Greveundefined
                                          Bas Greve
                                          • How to do this
                                            BertMundefined
                                            Lex.Kloet.RXundefined
                                            Lex.Kloet.RX
                                          • route wil niet over zandwegen die wel gewoon toegankelijk zijn
                                            Wim Peetersundefined
                                            Wim Peeters
                                          • Routepunten
                                            Corrado Miniati 0undefined
                                            Corrado Miniati 0
                                            1.2k
                                          • impossibile tracciare itinerari a piedi o in bicicletta
                                          • Have a Track available along with the Route
                                          • "Show next waypoint information" - another hidden UI filter!
