  4. Battery drain when navigating
57 Posts 22 Posters 1.0k Views 8 Watching
    @Rolf-Aalders That indeed really should not be the case!
    Flat Twin Therapy
    Flat Twin Therapy
    Flat Twin Therapy
    @Corjan-Meijerink Any progress on this topic? 🤞 🤞 🤞
    Since January 2024 I started recording some of my rides commuting and touring the R1200RT in The Netherlands:
    https://youtube.com/@FlatTwinTherapy
      @Rolf-Aalders Not really! See the changelog for the new update: https://forum.myrouteapp.com/topic/3392/new-beta-v3-2-9
      This is the last known real critical issue 🙂
      Flat Twin Therapy 1 Reply Last reply
        Flat Twin Therapy
        Flat Twin Therapy
        Flat Twin Therapy
        @Corjan-Meijerink Thanks for pointing me to that post!
        Maarten v 1 Reply Last reply
          Maarten v
          Maarten v
          Maarten v
          @Rolf-Aalders Today riding with the MyRoute-app,battery was 88% and my iPhone 13 mini in the usb socket for voltage…….2 hours later the battery was 35% procent and still dropping…. So with the Navigation on the battery is draining verg fast even in usb socket . Than i turned Navigation off and close the app and battery was in 1,5 hour back at 80 % …..my conclusion that i can,t use the app because of battery drainage…..
          Maarten v Flat Twin Therapy 2 Replies Last reply
          • Maarten v Maarten v
            Maarten v
            Maarten v
            Maarten v
            @Maarten-v . I use the version 3.2.9-154
              Flat Twin Therapy
              Flat Twin Therapy
              Flat Twin Therapy
              wrote on last edited by Flat Twin Therapy
              #28
              @Maarten-v
              I have indeed the same. I cannot use navigation because of the battery drain...
              To be honest... Battery drain.. + the Android app just crashes very, very (very!) often, of which I cannot recover safely due to gloves on, while riding motorcycle...
              This makes the app actually useless... ;( ;(
              I'm only using it for trips I already know, to test if these 2 issues are solved yet, so that I can actually start using it.
              @Corjan-Meijerink any updates on the battery drain and the crashes (android)? Is there perhaps anything that I can help? Perhaps sharing logsfiles, if that is possible?
                @Maarten-v
                @Rolf-Aalders both will be more intensively investigated after the CarPlay update
                • Jure Sirena 0
                  Jure Sirena 0
                  Jure Sirena 0
                  We are all reporting same issue to guys they know it. We have to stop using app to save battery even if charged. What is interesting (at least what I’ve noticed) that almost all reported issues are on iphone 13….mine is iphone 13 pro, ios 16.3.1
                  Just an observation
                    No, also noticed with iPhone X.
                    The little 12-5Volt converter plug does not supply enough power to compensate for the consumption, the iPhone was empty after 1 hour (start at 45% battery charge).
                    But because this is known, I'm sure it will be solved soon. 👍
                    • Nick Carthew
                      I will add my findings to this debate. Yesterday I used the app to navigate and track a route of about 120 miles. I stopped several times and paused the tracking. The original route was 66 miles and when I reached the destination I chose to edit the route and I added several route points to take me back home. The first of these new route points was RP7 so when I opened the newly edited route I gave a long press on RP7 to set as the start point. Everything worked perfectly as it should have.
                      My phone is an iPhone 11 and it's mounted on a Quadlock handlebar mount. I had it plugged into a 12v supply via a usb cable. My phone had about 80% battery when I started and when I got home the battery was at 100%. I also noticed that there was no significant heat despite the phone being within the Quadlock case. I had no other apps open while navigating.
                      • RetiredWingMan
                        I also find battery usage to be excessive - Older Samsung Galaxy S7 - MRA Mobile Next app 3.2.9. Battery usage was so bad during one hour of navigating I had to stop it. The phone was connected for fast charging. The phone was hot. I'm hoping that once I can download maps to my SD Card and run offline that battery usage will be significantly reduced. That is how I currently run with MRA Navigation - GPS and WIFI only. No cellular service.
                        • Mopetenpit Mopetenpit
                          My contribution to the topic "battery charging". I drove a short distance today with the bike and Navigation Next. At the start I had a battery charge of 73%, at the finish was 64%. The route is 3.4 km long and of course only takes a few minutes. Equipment: iPhone 13 pro, iOS version 16.3.
                          Ad Koppenol
                          Ad Koppenol
                          Ad Koppenol
                          @Mopetenpit said in Battery drain when navigating:
                          Ook de batterij op mijn iPhone 13 Pro, iOS 16.3.1 loopt snel leeg. Tijdens een rit van een uur verloor de accu 2% aan volume, terwijl hij aan de USB-oplader 12V van de auto was aangesloten. De iPhone werd ook erg warm. Zo durf ik geen gebruik te maken van de app tijdens de lange ritten in de vakantie.
                          Flat Twin Therapy CD130 2 Replies Last reply
                          • Ad Koppenol Ad Koppenol
                            Flat Twin Therapy
                            Flat Twin Therapy
                            Flat Twin Therapy
                            Can you give a status update on the battery performance while navigating on Android? Has that been fixed?
                            Thanks!
                              Thanks!
                              @Rolf-Aalders actively in progress. We are working closely with HERE to improve the performance.
                                  Flat Twin Therapy
                                  Flat Twin Therapy
                                  Flat Twin Therapy
                                  Oh that is really good to hear. Thanks!
                                  This is the only issue preventing me from actively using it.
                                  • Rob Verhoeff
                                    Today I took a drive with connected iPhone 13 to the USB port via cable. I have no idea if the phone became too hot (you can't feel it with gloves on 😁 ), but the battery logging indicates that charging stopped at 85%. The iPhone has an internal safeguard to protect the battery. I have complete confidence that everything will be fine.
                                    • Karl Mumford
                                      Karl Mumford
                                      Karl Mumford
                                      I have just returned from a trip to Ireland where I tried to use the new MyRoute app to navigate with my Android 10 Ulefone Armour X7 Pro. I found that even with the phone on charge with a 1.5A charger it was draining the battery enough to not be able to last the day.
                                      I switched back to using the MRA Navigator stand-alone app because that is able to allow the phone to charge up even when in use.
                                      MyRoute app version 4.0.1 - 194
                                      MRA Navigation version v1.6.12
                                      CD130 Karl Mumford 2 Replies Last reply
                                      • Karl Mumford Karl Mumford
                                        @Karl-Mumford are you able to try a 2.4A or 3.0A charger? The 3.0A charger works fine with my iPhone 12.
                                        Karl Mumford 1 Reply Last reply
                                          Karl Mumford
                                          Karl Mumford
                                          Karl Mumford
                                          @Karl-Mumford I have just see that MyRoute-app on my phone updated itself automatically yesterday so I would have been using the previous version while in Ireland
                                          Stephen Rowland
                                          Stephen Rowland
                                          Maarten v
                                          Maarten v
                                          Mopetenpit
                                          Mopetenpit
                                          Arno 0
                                          Arno 0
                                          infoevertkuiken.nl
                                          infoevertkuiken.nl
                                          M PRP
                                          M PRP
                                          Paul 41
                                          Paul 41
                                          Ad Koppenol
                                          Ad Koppenol
                                          Flat Twin Therapy
                                          Flat Twin Therapy
                                          Jure Sirena 0
                                          Jure Sirena 0
                                          Simannjo
                                          Simannjo
                                          Karl Mumford
                                          Karl Mumford
                                          Willy DEOM
                                          Willy DEOM
                                            Glenn.B
                                            Glenn.B
                                            3.6k
                                            Robineke
                                            Robineke
                                            Reinhard Grossmann h 0
                                          • Overlay Routes like the App does and waypoints without routes
                                            Rob Kelley
                                            Rob Kelley
                                          • Route Breakdown
                                            Scarecrow
                                            Scarecrow
                                          • Brittany routes
                                            Tony 13
                                            Tony 13
                                          • Vergrendel scherm zet alles op z'n kop
