  4. Route always crashes
12 Posts 6 Posters 196 Views 1 Watching
  • RetiredWingMan
    Hello, this route always crashes when I try to open it in MRA Mobile. Most of the time I can open for navigation. I'm also able to open for edit. Using a Samsung Tab A7.
    Route:
    https://www.myrouteapp.com/en/social/route/6982505?mode=share
    Steve Lynch Nick Carthew Corjan Meijerink 3 Replies Last reply
      Route:
      Steve Lynch
      Steve Lynch
      Steve Lynch
      @Doug-Robinson
      That's the first time i've seen a Crash in the iOS Beta.!
      It's a very long route that probably needs splitting into day routes maybe.
      There are many here far more experienced than me at solving problems like this so I'll leave to them.
        Route:
        @Doug-Robinson It’s over 3000 miles and several route points are quite a distance from the road. I suggest shortening the route, perhaps split it into daily rides and check the positioning of all route points.
          Route:
          @Doug-Robinson Thanks for sharing! Honestly, it’s indeed probably just way too long as @Steve-Lynch suggested. A crash is however never a good way of handling errors 😉
          So if the route is indeed too long, we need to handle that case appropriately. I’ll give it a test (with debug info) tomorrow and report back 🙂
            Steve Lynch
            Steve Lynch
            Steve Lynch
            No crash in Android though for me?
            Sorry I was in the planner it does crash in Android Beta.
            • Con Hennekens
              If there is a max to the amount of waypoints, surely that must be a known figure. That does not seem something you would need to find out by trial and error.
              • RetiredWingMan
                Yes, it is a long route. When I ride it in June I'll split to daily rides. For now I'm planning as a single route. I'm surprised about the waypoint being off. I thought I had checked them all. I've noticed that if you switch maps sometimes the waypoints magically move 😞 sometimes I'll switch from Here to Openmaps when the Internet is slow, I find it is quicker updating.
                Con Hennekens Nick Carthew 2 Replies Last reply
                  @Doug-Robinson, It's not the waypoints moving, but the roads... 😉
                    @Doug-Robinson said in Route always crashes:
                    That highlights the discrepancies in each map and shows the importance of using the correct planning map for the device that you use.
                      @Nick-Carthew I don't disagree, since I use the Navigator and eventually MRA Mobile (once offline is working) which maps are downloaded? I don't see a choice. I normally do my planning using the Here maps but if they are not the maps that get down loaded, then I would like to know which maps do get downloaded.
                        I'm fairly optimistic that this issue has been solved in the upcoming update!
                        DerRoteBlitz 1 Reply Last reply
                          DerRoteBlitz
                          DerRoteBlitz
                          DerRoteBlitz
                          Hi, I am currently testing the MRA APP. I am facing nearly the same issue, but when I have only one waypoint... I am searching for an address and want to navigate. The APP calculates the route, I press start and the APP is closing.
                          Today I have had that issue even when the APP is running several minutes, then crashing without any error message.
                          Pixel 7 pro with latest updates.
                          If you need more info please let me know.
                          DerRoteBlitz
                          DerRoteBlitz
                          Steve Lynch
                          Steve Lynch
                            1.1k
                            1.2k
                            Robert Smith 2
                            Robert Smith 2
                            2.2k
                          • Export ---> Save to
                            Dr. Markus Hellenthal
                            1.6k
                          • MRA 6.0.0 (515) Menu black no function /// Menü schwarz keine Funktion
