  4. Route always crashes
12 Posts 6 Posters 196 Views 1 Watching
    Hello, this route always crashes when I try to open it in MRA Mobile. Most of the time I can open for navigation. I'm also able to open for edit. Using a Samsung Tab A7.
    Route:
    https://www.myrouteapp.com/en/social/route/6982505?mode=share
    Steve Lynchundefined Nick Carthewundefined Corjan Meijerinkundefined 3 Replies Last reply
      Route:
      Steve Lynchundefined Offline
      Steve Lynch
      @Doug-Robinson
      That's the first time i've seen a Crash in the iOS Beta.!
      It's a very long route that probably needs splitting into day routes maybe.
      There are many here far more experienced than me at solving problems like this so I'll leave to them.
      You donโ€™t stop riding when you get old, you get old when you stop riding.
        Route:
        @Doug-Robinson Itโ€™s over 3000 miles and several route points are quite a distance from the road. I suggest shortening the route, perhaps split it into daily rides and check the positioning of all route points.
          Route:
          @Doug-Robinson Thanks for sharing! Honestly, itโ€™s indeed probably just way too long as @Steve-Lynch suggested. A crash is however never a good way of handling errors ๐Ÿ˜‰
          So if the route is indeed too long, we need to handle that case appropriately. Iโ€™ll give it a test (with debug info) tomorrow and report back ๐Ÿ™‚
            Steve Lynch
            No crash in Android though for me?
            Sorry I was in the planner it does crash in Android Beta.
              If there is a max to the amount of waypoints, surely that must be a known figure. That does not seem something you would need to find out by trial and error.
                Yes, it is a long route. When I ride it in June I'll split to daily rides. For now I'm planning as a single route. I'm surprised about the waypoint being off. I thought I had checked them all. I've noticed that if you switch maps sometimes the waypoints magically move ๐Ÿ˜ž sometimes I'll switch from Here to Openmaps when the Internet is slow, I find it is quicker updating.
                Con Hennekensundefined Nick Carthewundefined 2 Replies Last reply
                  @Doug-Robinson, It's not the waypoints moving, but the roads... ๐Ÿ˜‰
                    @Doug-Robinson said in Route always crashes:
                    That highlights the discrepancies in each map and shows the importance of using the correct planning map for the device that you use.
                      @Nick-Carthew I don't disagree, since I use the Navigator and eventually MRA Mobile (once offline is working) which maps are downloaded? I don't see a choice. I normally do my planning using the Here maps but if they are not the maps that get down loaded, then I would like to know which maps do get downloaded.
                        I'm fairly optimistic that this issue has been solved in the upcoming update!
                        DerRoteBlitzundefined 1 Reply Last reply
                          DerRoteBlitzundefined Offline
                          DerRoteBlitz
                          Hi, I am currently testing the MRA APP. I am facing nearly the same issue, but when I have only one waypoint... I am searching for an address and want to navigate. The APP calculates the route, I press start and the APP is closing.
                          Today I have had that issue even when the APP is running several minutes, then crashing without any error message.
                          Pixel 7 pro with latest updates.
                          If you need more info please let me know.
                          DerRoteBlitz
                          Steve Lynch
                          • Ik ben benieuwd naar jullie instelling
                            Nomko Nomdenundefined
                            Nomko Nomden
                          • free ride
                            2.3k
                          • How do I follow a track not Navigate it
                          • cant use app just to view map when riding
                          • Reverse route
                          • Does waypoint have to be on Route Line?
                          • Android GO Edition with latest upgrade
                            Michael Doherty 0undefined
                            Michael Doherty 0
