  4. Next closes immediatly when starting a planned route
problemandroid 12huawei p30 pro
32 Posts 10 Posters 362 Views
  • Hans Kremers
    Hans Kremers
    Hans Kremers
    For what it ist worth, I'm seeing the same behaviour in a Huawei P20 Pro, Android 10
    After selecting and starting the navigation, the screen goes Black and the Desktop appears
    I tried several routes, all with the same result.
    Starting navigation with the same routes in a Lenovo P11 Pro (Android 12) works fine
    Regards,
    Hans
    Triumph Tiger 800XCa
    Blackview BV6200 / Osmand+
    • Hans Kremers Hans Kremers
      Regards,
      Hans
      @Hans-Kremers Thanks! Tomorrow - Thursday are scheduled for app development so we’ll start the investigation shortly! 🙂
      ASPK 1 Reply Last reply
        ASPK
        ASPK
        ASPK
        Je rencontre exactement le même problème avec mon Samsung S20FE.
        Si je démarre Next, je charge un itinéraire de la bibliothèque, je lance la navigation et l'application se ferme. Si je redémarre une seconde fois, çà fonctionne et je peux ouvrir tous les autres itinéraires sans soucis.
        • Tim  Thompson
          Tim  Thompson
          Tim Thompson
          I tried clearing that app cache and then retried starting the route. That seemed to work. Don't know if it was a coincidence. But for what it's worth.
          • Tim  Thompson
            Tim  Thompson
            Tim Thompson
            #22
            I've upgraded to the latest beta version 3.2.5 - 146. I uninstalled it and reinstalled. Still having the stability issues. In fact, they may have gotten worse. It's now crashing occasionally when going to the menu (upper left) and selecting "Routes". Tried clearing the app cache again. That doesn't seem to be helping (must have been a coincidence before).
            In case it helps...
            • Pixel 5a
            • Android Version 13, Build number TP1A.221105.002
            • MRA Beta Version 3.2.5 - 146
            • Tim  Thompson Tim Thompson
              In case it helps...
              • Pixel 5a
              @Tim-Thompson Remarkable how this very annoying problem exists for a limited amount of users 😞 We will continue researching this coming week! The most annoying part is that we never experienced this issue on any of our Android test devices. We will keep you posted about any progress!
                Tim  Thompson
                Tim  Thompson
                Tim Thompson
                Another thing I noted... If I really get stuck, I try clearing the app storage. Kind of annoying... But one must do what one must do. So far, this step has worked to get past the issue. However, it may as well be a coincidence too.
                Anyway... For what it's worth.
                  @Tim-Thompson Indeed, for what it is worth 😉 The issue needs to be resolved by us. It's as simple as that!
                  Tim  Thompson Òscar 2 Replies Last reply
                    Tim  Thompson
                    Tim  Thompson
                    Tim Thompson
                    #26
                    Just a thought. Is it possible to implement logging to help troubleshooting/capture the issue?
                      Òscar
                      Òscar
                      Òscar
                      @Corjan-Meijerink FYI, I too have stability issues. This version gives me more problems than 3.2.4. Continuous closures.
                      My smartphone:
                      Pixel 6 pro.
                      Android 13
                      Ulefone armor 12
                      Android 11
                      I have problems in both.
                      • https://t.me/MRa_by_b0hd1
                      • YouTube: @demco17
                        Unfortunately the logs do not really indicate where the issue is yet. We hope to get more information in a next version!
                        Mike Whitwam 1 Reply Last reply
                        • Koen VH
                          Koen VH
                          Koen VH
                          Hi, I also have this issue on the tablets S7, S2 and the smartphone A51.
                          I have this fault when I push the start button immediately after loading the route. When I wait some time, several seconds the route is loaded and another start can be pushed.
                          iPhone SE (2020) - Outikel RT3 (Android 12)
                            Mike Whitwam
                            Mike Whitwam
                            Mike Whitwam
                            I have downloaded the new version on Android yesterday and I am having same problems, the unit crashes as soon as I try to start the route. I kept getting a message saying the app had a bug. So deleted the app and re-loaded which seems to have solved the problem. Will re-post if problem comes back.
                            • Tim Thompson Tim Thompson referenced this topic on
                            • MotoCon
                              I just saw there is a 3.2.5 version now. The problem persists however. In fact it has kept me from navigating and testing at all all this time, and it does that on all my devices. I simply cannot start a route, with exception of a few times. More details are already known by Corjan. I just wanted to say that the new version did nothing in this regard.
                                @Con-Hennekens Sad to hear that! This week we will research more 🙂
                                Òscar
                                Òscar
                                Hans Kremers
                                Hans Kremers
                                Michel van Hagen MRA-Founder
                                ASPK
                                ASPK
                                Mike Whitwam
                                Mike Whitwam
                                Koen VH
                                Koen VH
                                Tim  Thompson
                                Tim Thompson
                                Andrew Melton
                                Andrew Melton
                                • Replies in this section
                                • synchroniseren tussen de route app en de beta versie
                                  Evert 1g
                                  Evert 1g
                                • How to change from KM to Miles?
                                  John Matthews 0
                                  John Matthews 0
                                • Miscalculations of distance and time between waypoints
                                  Parantapa
                                  Parantapa
                                • Round trip - How to include a waypoint using the app?
                                • Route navigatie simuleren op Windows pc
                                  Alderweireld Rudi 0
                                  Alderweireld Rudi 0
                                • Split route - how to view all days together?
                                  John Matthews 0
                                  John Matthews 0
