  2. Routes & Tracks
  3. Import from Google Maps Link?
19 Posts 10 Posters 5.1k Views 2 Watching
  • David Skinnerundefined David Skinner
    Even though I have been using MyRouteApp for some time I have not worked out how to import routes from Google Maps provided as a link rather than in GPX format. Is there a way of doing this? The following link is provided as an example:
    https://goo.gl/maps/F5ohmErDnwjS5t4Y7
    Thanks in advance
    Dave Skinner
    NZ
    @David-Skinner
    Hello David, see this post: https://forum.myrouteapp.com/topic/2766/importing-pois-from-google-maps-overlay/9?_=1668320301406
      @David-Skinner
      @Hans-van-de-Ven-MRA-Master that's not what he's talking about. He wants to import routes (not POIs) from Google Maps using a link. I'm pretty sure that's not possible at the moment.
        Thanks in advance
        Dave Skinner
        NZ
        Hi @David-Skinner.
        This doesn’t answer your question, but the route that you have shared only contains a few waypoints, it wouldn’t be difficult to reproduce this directly in MyRoute-app.
        David Skinnerundefined 1 Reply Last reply
          @Herko-ter-Horst
          aha, ok, I'll just put on my glasses from now on...🙄
            Thanks in advance
            Dave Skinner
            NZ
            Tim  Thompsonundefined Offline
            Tim Thompson
            @David-Skinner said in Import from Google Maps Link?:
            Thanks in advance
            Dave Skinner
            NZ
            Don't believe MRA will do this. I know Scenic has this ability - can import directly from Google Maps and My Maps links.
            Haven't seen any other solution/app that does.
            But, if you are Android only, then Scenic isn't a solution for you at the moment (iOS only). The Android release of Scenic isn't supposed to hit until early next year (according to the developer).
              Hi @David-Skinner.
              David Skinnerundefined Offline
              David Skinner
              @Nick-Carthew It is Nick, but this is just an example and sometimes the routes are much more complex.
              D.
                D.
                Drabslabundefined Offline
                @David-Skinner
                hai,
                Just out of curiosity: why would you import routes from google maps and not make these directly in the MRA Routeplanner?
                • Drabslabundefined Drabslab
                  @David-Skinner
                  hai,
                  Jack van Tilburg
                  @Drabslab
                  Or; why would you make a route yourself in MRA if you got a nice one via a Google link? 😪
                  • Drabslabundefined Offline
                    @Jack-van-Tilburg said in Import from Google Maps Link?:
                    @Drabslab
                    Ah, that makes it clear 🙂
                    I thought that what was meant was to prepare a route in google maps and then download this to MRA
                    • Tim  Thompsonundefined Offline
                      Tim Thompson
                      Or... Maybe you might want to use Google Maps and/or My Maps as a free route planner (or maybe something to augment another planner). It's already been mentioned - somebody could share a Google Maps/My Maps link. If so, would be nice to be able to easly import it.
                      Considering free/alternative route planners... To be honest, I might consider My Maps as a #2 goto - behind Furkot. Scenic's feature to import from Google Maps/My Maps links actually works fairly well.
                      • Tim  Thompsonundefined Tim Thompson
                        Stanisławundefined Offline
                        There is a free tool to quickly convert google maps ling to GPX, whoch could be imported to MRA, maybe it is a solution:
                        (https://www.gpsvisualizer.com/convert_input)
                        Staszek
                          Jack van Tilburg
                          @Stanisław
                          That would be nice. But unfortunately it only works if you have an API Key. 😢
                            @Stanisław
                            @Jack-van-Tilburg I didn't try it recently, pity 😞
                            The same is in case ot Tire application, added to Tomtom.
                            There is a possibility tu use own api key free for limited use but I didn't want to try it.
                            Staszek
                              Jack van Tilburg
                              @Stanisław
                              I think those actions will be too complicated for the average user.
                                @Stanisław
                                @Jack-van-Tilburg For sure... I have moved to MRA with planning and I like it very much, but sometimes someone is sending me simply link to google maps and I have the same problem to open it it MRA.
                                Staszek
                                  Jack van Tilburg
                                  @Stanisław
                                  I have no idea how great the need for this feature is among MRA users.
                                  I'm sure there will be an inventory for Roadmap3 in due course and then users can ask for it.
                                    @Drabslab
                                    @Jack-van-Tilburg, @Tim-Thompson and @David-Skinner, I could suggest to ask in a google forum to implement GPX export, but... yeah.... I think we all would do good to teach people who share Google Maps routes that there are better methods for it 😉
                                    Em Pirundefined 1 Reply Last reply
                                      Em Pirundefined Offline
                                      Em Pir
                                      MyRoute-app taught me that there are MANY flavors of gpx files.
                                      Stanisławundefined
                                      Jack van Tilburg
                                      Drabslabundefined
                                      Em Pirundefined
                                      Em Pir
                                      Tim Thompson
                                      David Skinner
                                        Axel Härtlundefined
                                        Axel Härtl
                                        Roland Busenhartundefined
                                        Roland Busenhart
                                        2.5k
                                      • seizoen afsluitingen
                                        2.8k
                                        Jan Weerheimundefined
                                        Jan Weerheim
                                      • Poi's per rit op meerdaagse reizen
                                      • Doe ik iets verkeerd of...
                                        Michel 71 0undefined
                                        Michel 71 0
