  2. Routes & Tracks
  3. Import from Google Maps Link?
19 Posts 10 Posters 5.5k Views 2 Watching
  • David Skinner Offline
    David Skinner
    Even though I have been using MyRouteApp for some time I have not worked out how to import routes from Google Maps provided as a link rather than in GPX format. Is there a way of doing this? The following link is provided as an example:
    https://goo.gl/maps/F5ohmErDnwjS5t4Y7
    Thanks in advance
    Dave Skinner
    NZ
    Hans van de Ven MR.MRA Nick Carthew Tim  Thompson 3 Replies Last reply
    • David Skinner David Skinner
      Thanks in advance
      Dave Skinner
      NZ
      @David-Skinner
      Hello David, see this post: https://forum.myrouteapp.com/topic/2766/importing-pois-from-google-maps-overlay/9?_=1668320301406
        @David-Skinner
        Herko ter Horst Offline
        @Hans-van-de-Ven-MRA-Master that's not what he's talking about. He wants to import routes (not POIs) from Google Maps using a link. I'm pretty sure that's not possible at the moment.
          Thanks in advance
          Dave Skinner
          NZ
          Nick Carthew Offline
          Hi @David-Skinner.
          This doesn’t answer your question, but the route that you have shared only contains a few waypoints, it wouldn’t be difficult to reproduce this directly in MyRoute-app.
          David Skinner 1 Reply Last reply
            @Herko-ter-Horst
            aha, ok, I'll just put on my glasses from now on...🙄
              Thanks in advance
              Dave Skinner
              NZ
              Tim  Thompson Offline
              Tim Thompson
              @David-Skinner said in Import from Google Maps Link?:
              Thanks in advance
              Dave Skinner
              NZ
              Don't believe MRA will do this. I know Scenic has this ability - can import directly from Google Maps and My Maps links.
              Haven't seen any other solution/app that does.
              But, if you are Android only, then Scenic isn't a solution for you at the moment (iOS only). The Android release of Scenic isn't supposed to hit until early next year (according to the developer).
                Hi @David-Skinner.
                David Skinner
                @Nick-Carthew It is Nick, but this is just an example and sometimes the routes are much more complex.
                D.
                Drabslab 1 Reply Last reply
                  D.
                  Drabslab Offline
                  Drabslab Offline
                  @David-Skinner
                  hai,
                  Just out of curiosity: why would you import routes from google maps and not make these directly in the MRA Routeplanner?
                  • Drabslab Drabslab
                    @David-Skinner
                    hai,
                    Jack van Tilburg Offline
                    Jack van Tilburg
                    @Drabslab
                    Or; why would you make a route yourself in MRA if you got a nice one via a Google link? 😪
                    • Drabslab Offline
                      Drabslab Offline
                      @Jack-van-Tilburg said in Import from Google Maps Link?:
                      @Drabslab
                      Ah, that makes it clear 🙂
                      I thought that what was meant was to prepare a route in google maps and then download this to MRA
                      • Tim  Thompson Offline
                        Tim Thompson
                        Or... Maybe you might want to use Google Maps and/or My Maps as a free route planner (or maybe something to augment another planner). It's already been mentioned - somebody could share a Google Maps/My Maps link. If so, would be nice to be able to easly import it.
                        Considering free/alternative route planners... To be honest, I might consider My Maps as a #2 goto - behind Furkot. Scenic's feature to import from Google Maps/My Maps links actually works fairly well.
                        Stanisław 1 Reply Last reply
                        • Tim  Thompson Tim Thompson
                          Stanisław Offline
                          Stanisław Offline
                          There is a free tool to quickly convert google maps ling to GPX, whoch could be imported to MRA, maybe it is a solution:
                          (https://www.gpsvisualizer.com/convert_input)
                          Staszek
                          • Stanisław Stanisław
                            Jack van Tilburg
                            @Stanisław
                            That would be nice. But unfortunately it only works if you have an API Key. 😢
                              @Stanisław
                              Stanisław Offline
                              Stanisław Offline
                              @Jack-van-Tilburg I didn't try it recently, pity 😞
                              The same is in case ot Tire application, added to Tomtom.
                              There is a possibility tu use own api key free for limited use but I didn't want to try it.
                              Staszek
                                Jack van Tilburg
                                @Stanisław
                                I think those actions will be too complicated for the average user.
                                  @Stanisław
                                  Stanisław Offline
                                  Stanisław Offline
                                  @Jack-van-Tilburg For sure... I have moved to MRA with planning and I like it very much, but sometimes someone is sending me simply link to google maps and I have the same problem to open it it MRA.
                                  Staszek
                                    Jack van Tilburg
                                    @Stanisław
                                    I have no idea how great the need for this feature is among MRA users.
                                    I'm sure there will be an inventory for Roadmap3 in due course and then users can ask for it.
                                      @Drabslab
                                      @Jack-van-Tilburg, @Tim-Thompson and @David-Skinner, I could suggest to ask in a google forum to implement GPX export, but... yeah.... I think we all would do good to teach people who share Google Maps routes that there are better methods for it 😉
                                      Em Pir 1 Reply Last reply
                                        Em Pir Offline
                                        Em Pir Offline
                                        Em Pir
                                        MyRoute-app taught me that there are MANY flavors of gpx files.
                                        Jack van Tilburg
                                        Jack van Tilburg
                                        Em Pir
                                        Em Pir
                                        Tim  Thompson
                                        Tim Thompson
                                        David Skinner
                                        David Skinner
                                          Sytze van der Laan
                                          Sytze van der Laan
