  4. MRA and tunnels
MRA and tunnels
24 Posts 12 Posters 10.1k Views 7 Watching
  • Adrian Avram
    Hi !
    In just 29 days I leave from Romania to the Swiss Alps and I am wondering how does MRA behave in tunnels (and I have to pass a lot in Austria) ?
    I want to use the track record function as well, and I was wondering if it works well trough long tunnels, where there is no GPS signal ?
    Thanks !
    Adrian
    • Adrian Avram Adrian Avram
      Hi !
      Thanks !
      @Adrian-Avram I would for obvious reasons avoid positioning route points inside a tunnel and I would also avoid positioning them too close to the exit of a tunnel, the app will need to wake up and get a fix on the satellites again. As the tracking works from the GPS signal, I suspect that you'll see straight lines for the tunnels.
      • Herman Veldhuizen
        mra recovers after leaving the tunnel, but inside the tunnel it behaves chaotic. it sometimes thinks that you are driving backwards, recalculates accordingly , severely effecting the ETA info.
        I have a video showing it if you are interested.
        Tomtom behaves better, i guess it assumes that you drive at constant speed and moves the cursor accordingly.
        Adrian Avram Makro 2 Replies Last reply
          @Herman-Veldhuizen yes, can you put a link to the video here ?
          Thanks !
          Adrian
            Thanks !
            @Adrian-Avram
            https://drive.google.com/file/d/16xe9XEVUoiZR06ej2_fCkQGDLABxxj3Y/view?usp=drivesdk
            The tunnel starts 1min and 25sec into the video.
            Route:
            https://www.myrouteapp.com/route/open/10876313
              Makro
              Makro
              Makro
              @Herman-Veldhuizen said in MRA and tunnels:
              I experienced the same in a Stockholm tunnel recently. It was a bad experience, because I had to take an in-tunnel exit, and since the map didn't keep updating my assumed position, it was hard to know which exit to take.
              So Adrian, you need to look carefully at the map prior to entering a tunnel, so you know if you have to take an in-tunnel exit.
              Best regards, Makro
              • Makro Makro
                @Makro thats what I am afraid of. Thank you for the advice !
                Adrian
                • Guzt
                  Guzt
                  Guzt
                  Swiss Alps? Don't forget to disable roaming on your telephone. When not, you're in for a surprise when you will receive your telephone bill.
                  Rob Verhoeff Adrian Avram 2 Replies Last reply
                  • Guzt Guzt
                    @Guzt said in MRA and tunnels:
                    That entirely depends on what kind of data cap you have with your provider! I don't worry at all 😉
                    • Guzt Guzt
                      @Guzt I had forgotten completely about this aspect ... Thank you for reminding me !!
                      Adrian
                      • nomko
                        Banned
                        Does offline navigation not solve this issue? Or are you even with offline navigation depending on a good/solid/working GPS connection?
                        Guzzist 1 Reply Last reply
                        • Guzt
                          Guzt
                          Guzt
                          Using off line navigation or not, always switch off roaming in Switserland. They have their own telecom rules and are not part of the EU which implicates that the EU roaming agreements don't apply for them. As soon as your telephone makes contact to a Swiss telephone service, costs kick in. To avoid this, use a Swiss eSIM .
                          https://saily.com/download-esim-app/
                          Peter Zehentreiter Rob Verhoeff 2 Replies Last reply
                          • Tony 13
                            Tony 13
                            Tony 13
                            For the roaming you just need to check your contract. O2 does include Switzerland in roaming from the UK
                            https://www.o2.co.uk/help/international-and-network/using-your-phone-abroad/roaming-in-europe-pay-monthly
                            • Guzt Guzt
                              @Guzt However, this is only partially true. For example, Deutsche Telekom's tariffs include roaming in Switzerland and the UK.
                              I can't comment on other providers.
                              BMW R 1250 GS
                              DMD-NOR7E 7"
                              SPC Universal mount
                              Motorola Edge 40 "offline"
                              Sena SLR 3
                              Sena 50 R
                              • Guzt Guzt
                                @Guzt I mentioned this before... That's not entirely true! There are Dutch providers that simply consider Switzerland an EU country. For example, with my Dutch mobile plan, I'm allowed to use 50GB per month from my Dutch data bundle in an EU country (including Switzerland). So you really need to check the terms and conditions of your provider in your own country!
                                • Guzt
                                  Guzt
                                  Guzt
                                  My provider blocks Switzerland just to avoid the possible surprise. I have to activate it or buy a data plan for it. But then, Belgian telecom is so what the most expensive in the EU.
                                  So it is up to Adrian to check this with his telecom provider.
                                  • Guzt Guzt
                                    Time to shop elsewhere 😉
                                    • nomko nomko
                                      @Nomko-Nomden offline navigation depends also on good GPS receive. Means: you don't need roaming/eSIM for Internet connection. But in long tunnels, you will loose GPS - and if there is an exit inside the tunnel, you need to take- MyRoute-App may will not navigate you!
                                      • Herman Veldhuizen
                                        i drove through many tunnels in Norway today, including the 25km long Laerdals tunnel. MRA worked without a glitch inside these tunnels, no spinning, no jumping to roads above the tunnel. This is with the 5.0.3 version. I even had a shaping point inside one of the tunnels and that worked as well.
                                        Guzzist TomOnTour 2 Replies Last reply
                                          @Herman-Veldhuizen ...then you are lucky.
                                          The reasons are:
                                          • Navigation systems can also interpolate their own position from direction and speed. But that only works in straight tunnels.
                                          • In some tunnels are so called beacons installed, by this navigation systems can also calculate the actual position (in GoogleMaps, this option must be activated in settings).
                                          • In other tunnels there may be TunnelSat installed. This is an advanced tunnel GPS system that extends reliable satellite navigation underground, delivering accurate, real-time positioning signal.
                                          It depends on the tunnel operator.
                                          TomOnTour
                                          TomOnTour
                                          Guzt
                                          Guzt
                                          Garry Davis
                                          Garry Davis
                                          Tony 13
                                          Tony 13
                                          Makro
                                          Makro
                                            Alderweireld Rudi 0
                                            Alderweireld Rudi 0
                                          • Weather as a service
                                            Andy Smith 5
                                            Andy Smith 5
                                          • Lane view in Android Auto
                                            denWINNE
                                            denWINNE
