  4. Route not transferring to Zumo XT
20 Posts 7 Posters 5.9k Views 2 Watching
  • Karl Foley
    Karl Foley
    Karl Foley
    Hi folks,
    Am away in Europe in 2 weeks and having issues with routes.
    I have created a simple route from home to the sea, here in Ireland, to see if you can see any issues.
    https://www.myrouteapp.com/route/open/11453511
    I create the route in MRA webpage, then on my phone app download (gpx 1.1), export and open in G-drive.
    It sends the file, with "Saving item 1of 1 to trip planner, Calculating 0%", but does not progress.
    On the XT, it has the title, but no information inside and hence cannot convert to a trip.
    XT is fully up to date too, the three points are on roads and all avoidance are off.
    Any major issues with my route above ?
    Thanks
    Karl.
    nomko 1 Reply Last reply
    • Bouke Ent
      i just did download you route and send it as gpx 1.1 to my xt. both route and track are on xt and route looks the same as your route. conclusion for me route is ok. i use iphone with non beta myroute app and garmin drive. my xt is also up to date. maybe you can try to give XT hard shutdown en restart (no reset)
      • Karl Foley Karl Foley
        Hi folks,
        Thanks
        Karl.
        Banned
        @Karl-Foley said in Route not transferring to Zumo XT:
        What phone app are you refering to? The Garmin Drive App? Of MRA Next app?
        I don't have any issues downloading routes from my Next app to my Garmin Zumo XT(1).
        When i open a route, i share it through de Drive App which sends it to my XT(1) and no issues to be noted.
        I have my phone connected using bluetooth and a hotspot with my XT(1).
        • Karl Foley
          Karl Foley
          Karl Foley
          Thanks both.
          Thanks for trying my test route. Must be some other issue
          Nomko - Just using my-route app and Garmin drive, not next navigation.
          Why do you mention hotspot ? Is Bluetooth the only communication needed to transfer a route ?
            Thanks both.
            Banned
            The MyRopute App on your mobile phone? Tha is the MRA Next app.
            I have my mobile phone connected to my Garmin Zumo XT using Bluetooth and hotspot.
            The hotspot is for having a (mobile) internet connection for the XT through me mobile phone.
            No, you can use wifi as well. At home i have my XT connected to my home network. I connect my XT to a poweradaptor and have it updated through my wifi network at home for example. During rides i use the hotspot connection on my mobile phone to have internet on my XT so i can receive (traffic) information for instance.
            Uploading GPX files from yopur mobile phone to your XT can be done through wifi or through Bluetooth.
            • Karl Foley
              Karl Foley
              Karl Foley
              Fixed - I did a full reset on my XT. Cleared all user data, re-setup and connected to my phone again.
              Files transfer quickly but more importantly - calculate & convert to Trips when asked.
              Thank you folks for checking my file. Cheers
              Side question - to make sure the XT travels along the route I decided - avoidances set to No tolls/motorways, transfer to a Trip, have plenty of waypoints and have Navigation off-route-calculation set to "off" ? is this the correct setup, without the XT deciding on a quicker/faster route and adjusting it ?
              • Karl Foley
                Karl Foley
                Karl Foley
                False hope. I successfully transferred one route, left it for a while and the same error (no calculation) on another route.
                Looks like I have to reset & setup the XT each time to transfer a route successfully, for the XT to calculate it. Anyone seen this before ?
                  Banned
                  What kind of reset did you do? A soft reset or a hard reset back to factory standards? The last reset works most of the times fixing strange issues i noticed.
                  Back to standard factory settings and then AS A FIRST!!! install all updates. And then start setting up the device to your own wishes and needs.
                  • Karl Foley
                    Karl Foley
                    Karl Foley
                    I did a "delete data and reset settings", with no updates (as I am at work). Routes initially load up fine. But after a few tests, back to no transfers.
                    When at home later, I will do a reset again and then install all updates, and see what happens with transfers after that.
                    will report back. Thanks again.
                    at least I know the GPX files work and are good, so that eliminates that part.
                    • nomko
                      Banned
                      Make sure to use the 1.1 gpx file not the 1.2.
                      • Bouke Ent
                        did you check if all your maps are good. i had 3 months ago that update did not went ok and i had to reinstall maps with garmin express.
                        • Karl Foley
                          Karl Foley
                          Karl Foley
                          wrote on last edited by Karl Foley
                          Hi. Did a full reset. All updates installed. Two routes loaded fine. Then turned It off.
                          It seems that when it's turned off and back on again it doesn't like to transfer.
                          I tried the route I posted above, known good route, but no luck.
                          Kinda lost - any other options.
                          • Reinhard-32
                            Reinhard-32
                            Reinhard-32
                            Are all maps (CityNavigator 2026.20 north and south) propper installed and ticked on.
                            Please check it in the settings on your ZumoXT.
                            I have imported your route in my ZumoXT without any problems.
                            Kindly regards
                            Reinhard
                            Montana 700i and Mac
                            Karl Foley 1 Reply Last reply
                            • Reinhard-32 Reinhard-32
                              Karl Foley
                              Karl Foley
                              Karl Foley
                              @Reinhard-32 yep, all ticked and up to date.
                              Even my simple route posted above won't transfer. It probably will if I do a full reset and setup again. But that's not workable.
                              Baffled
                              • Karl Foley
                                Karl Foley
                                Karl Foley
                                Well - the maps are ticked - properly installed?? How do I uninstall and reload them ?
                                Bouke Ent 1 Reply Last reply
                                  you can not uninstall but you can reinstall via garmin express.
                                  you also can try to remove bleutooth connection and reinstall garmin drive.
                                  also it is good to try to set gpx file off route direct on xt in gpx map. if then the xt sees the new file and can calculate that it has somthing to do with transfer by garmin drive or bleutooth
                                  • AWDC LAO
                                    Before starting your trip, always upgrade, update, reset, control, restart ... your software, iOS, maps, layers, devices, headset, trackers, batteries, tires.... and finally yourself and your mind.
                                    • Karl Foley
                                      Karl Foley
                                      Karl Foley
                                      Hi folks, looks like I have it fixed. I had all the following maps ticked - CN EUROPE NTU (FOURSQUARE), TOPO EUROPE CENTRAL, TOPO EAST & WEST, CN EU NTU (PARKOPEDIA), EUROPE DEM, CN EUROPE NTU (NORTH & SOUTH).
                                      So I cleared them all, restarted the XT, added just the North & South and it worked fine. But would not create a Trip until I added the Foursquare item (which has the POI).
                                      So looks like that was the issue, or one map was corrupt. I don't need the Topo maps. I may test it out after the trip, to see what ones are causing the issue, but ok for now.
                                      Thanks folks for testing out y orig route
                                      cheers
                                      K
                                      • Skellum
                                        Skellum
                                        Skellum
                                        wrote on last edited by Skellum
                                        On the Garmin XT, you should not have more than one routable set of Maps ticked - ie., Only the CN North & South, or there will always be issues when trying to load and run your routes on the unit.
                                          cheers
                                          K
                                          @Karl-Foley I hope that it works out fine for you because Foursquare is a known problem starter
                                          Skellum
                                          Skellum
                                          Reinhard-32
                                          Reinhard-32
                                          Karl Foley
                                          Karl Foley
                                          • test Myroute APP
                                            1.9k
                                          • F001 POIs Adding from selection is not possible
                                            Hubert Thori
                                            Hubert Thori
                                          • A03 POIs Show collection fixed on map
