  4. Route recalculation
Route recalculation
14 Posts 6 Posters 4.5k Views 4 Watching
  • ginogino
    ginogino
    ginogino
    As many people suggested, I disabled automatic route recalculation, but the problem is that when I take the wrong road and don't notice it right away, because I don't always look at the display and when I do look at the display, several minutes have passed since I took the wrong turn and travelled several kilometres, it would be advisable and desirable to have a voice alert when you take the wrong road, the classic ‘make a U-turn as soon as you can’. This way, you immediately realise your mistake.
    • ginogino ginogino
      @ginogino You do receive audible instructions if you leave the route. You can also choose to see the original route should you leave it.
      Not sure why you would turn off Automatic recalculation?
      ginogino 1 Reply Last reply
        ginogino
        ginogino
        ginogino
        @Nick-Carthew
        I don't think I've ever heard any audio signals or instructions telling me I've taken the wrong route. All that happens is that the route disappears from the display, along with all the instructions. I didn't specify, but I was talking about navigation on Android Auto.
        On Android Auto, there are no warnings that you have taken the wrong road and with automatic recalculation, if it doesn't realise that you have done so, you can get confused and think you are on the planned route. The last time I had recalculation enabled, it made me drive around a mountain and return to the village where I had taken the wrong road. All it would have taken was a “make a U-turn” warning as soon as I took the wrong road.
          You don't get a message that you have taken the wrong road. Because the road you take is never wrong. There is always a reason for it. A mistake is also a reason.
          With recalculation on, you often get an advice to make a U-turn. I don't use recalculation off. But I can image you won't get any directions at all when you are off-route. You switched it off, therefore it is your responsibility to get back on the route. Not your navigation.
          • M. Schrijver M. Schrijver
            ginogino
            ginogino
            ginogino
            @M.-Schrijver said in Route recalculation:
            Of course it's my responsibility, but what I'm asking is for the navigator to tell me immediately when I've made a mistake, as all other navigators do. I don't think that's an unreasonable request.
              Can I ask why you switched recalculation off?
              In my mind it is a typical thing from the zumo's. In a proper device or app it is unnecessary to switch recalculation off. The function is there to help you.
                ginogino
                ginogino
                ginogino
                Because with recalculation enabled (but also when it is disabled), there is no warning that you have left the planned route, and if you don't notice that the route has been recalculated when you look at the screen again, you mistake the new route for the one you should have taken. Last time, it made me go around a mountain to return to the village where I took the wrong road, adding about ten kilometres to my journey. when all it would have taken was to immediately notify me to make a U-turn within 100/200 metres of where I took the wrong turn. Another time, on an almost figure-eight route, when I took the wrong turn, it recalculated the route, making me take the final part of the route, cutting out a large part of the route I had planned, and since I didn't know the area well, I realised it too late.
                  I have a habit of glancing at the screen after taking a turn, to make sure I went the right way, especially in situations that can sometimes be unclear (like Y splittings in mountainesque areas). That's what the screen is for.
                  • ginogino ginogino
                    @ginogino and you see the original White Line on your screen
                    • Herman Veldhuizen
                      i agree 100% with @ginogino . Its easy to miss an instruction to go left or right because you get so many during a tour. But a very distinctive sound or spoken text of some sort to inform you that you have left the route would be noticed much easier. Like for example the sound you hear when approaching a speed camera.
                      More people in this forum have requested this feature. Of coarse I dont know if this is possible.
                        @Herman-Veldhuizen said in Route recalculation:
                        I think that would be possible when attached to a recalculation. Whenever a recalculation occurs, a sound gets audible. But in my hones opinion, I think that it would drive many people mad 😉 . Next question would be to hear a sound whenever you rejoin a route...
                        Herman Veldhuizen ginogino 2 Replies Last reply
                          @Con-Hennekens But if you nicely follow the route a recalculation is never needed I hope (unless a road closes while driving).
                          Such a sound of coarse should be enabled first in settings if it is wanted.
                          I have seen a brown bar sometimes telling me that a route has been recalculated but I haven't understood yet why or when it is happening.
                          What I have noticed is that the app sometimes sends me back while being on the route (which I also consider a recalculation) when I skip a shaping point but thats another story....
                            ginogino
                            ginogino
                            ginogino
                            @Con-Hennekens said in Route recalculation:
                            Hearing it many times means that you are taking the wrong route many times, so the problem is not the navigator but the driver.
                            Many apps or navigators clearly state that recalculation is being performed, not with a sound that can be easily misunderstood but with a voice alert. I don't see why the myroute app shouldn't do the same.
                            • ginogino ginogino
                              @ginogino, Sometimes detours are deliberate. To be clear, I am not against your suggestion. Merely pointing out it is a good idea to add a possibility of silencing it.
                              ginogino
                              ginogino
