  4. Shaping point ignored by app
16 Posts 5 Posters 4.3k Views 2 Watching
  • Steve Jarrell
    Steve Jarrell
    Steve Jarrell
    Can anyone explain to me why my shaping point #22 that was created in the online route editor was ignored by the app? I specifically put this shaping point into my route to take me to the end of town so that I would stop at a restaurant first (via point #23), then the gas station (via point #24), then continue on. Here's a link to the route.
    Thanks!
    Steve
    Online planner:
    Screenshot from DMD T865X when shaping point was skipped
    Steve Jarrell
    Western North Carolina US
    2025 BMW R1300GS
    2025 Can-Am Spyder
    DMD T865-X 8" Tablet
    Garmin XT3
    Adrian Avram MyZ51 2 Replies Last reply
    • RetiredWingMan
      Share a link to the route and make it public and we will try to find the issue.
      Steve Jarrell 1 Reply Last reply
        Steve Jarrell
        Steve Jarrell
        Steve Jarrell
        @RetiredWingMan I did.... click the "Here's a link" in my original post.
        Thanks!
        Steve Jarrell
        2025 BMW R1300GS
        2025 Can-Am Spyder
        Garmin XT3
        • Steve Jarrell Steve Jarrell
          Thanks!
          Steve
          Online planner:
          @Steve-Jarrell are your settings the same as they are in the planner ? I am talking about allowed roads ? When you hit navigate on the phone, drag the bottom bar and check what you have allowed or not allowed there. I think only these settings can modify route while navigating.
          Also you can try navigating "Route as a track", it can be enabled from settings !
          Adrian
          šŸ“±Samsung S24 Ultra with MyRoute-APP (GOLD Lifetime)
          šŸļøHonda NC750X (2021) with AA/CarPlay by CHIGEE Aio-5
          šŸš™Renault Duster with onboard AA/CarPlay Unit
          MotoCon Steve Jarrell 2 Replies Last reply
          • Adrian Avram Adrian Avram
            @Adrian-Avram said in Shaping point ignored by app:
            They always are, since the allowed roads in Navigation pass over from the planner to MRA Navigation. Great platform, isn't it? šŸ˜‰
              @Con-Hennekens said in Shaping point ignored by app:
              They always are
              No they are not ! Because in the planner I could select for example to use Highways and in the app to disable that, and it changes the route !
              I already tried it ...
              Adrian
                They always are
                @Adrian-Avram, yes of course you can change it manually, but then it would be no surprise if the route changes. If you don't change it manually in the app, the allowed roads setting will follow the ones used in the planner (if you use the correct map).
                The real surprise in this case is that the blue route line refuses to go to the shaping point, one way or the other. Something I cannot reproduce by the way. The route in my app seems to follow the desired road without problem.
                • RetiredWingMan
                  I loaded your route. I tried everything I could think of, changed options, used motorcycle and car. Nothing I did caused Navigator to skip wp 22. Is it possible that there was s blockage on the road when you looked at it.
                  • Steve Jarrell
                    Steve Jarrell
                    Steve Jarrell
                    Thanks. Nothing that I know of. I had all avoidances turned off in the app. That's why I was surprised when it ignored my shaping point. I appreciate you looking!
                    Steve Jarrell
                    2025 BMW R1300GS
                    2025 Can-Am Spyder
                    Garmin XT3
                      Steve Jarrell
                      Steve Jarrell
                      Steve Jarrell
                      @Adrian-Avram Thanks Adrian. I will double check but I'm almost sure that my settings are correct. There wasn't anything unusual about that road as far as I could tell (i.e it wasn't a dirt road, seasonal closure, etc.)
                      Thanks!
                      Steve
                      Steve Jarrell
                      2025 BMW R1300GS
                      2025 Can-Am Spyder
                      Garmin XT3
                        Steve Jarrell
                        Steve Jarrell
                        Steve Jarrell
                        @Con-Hennekens That one has me scratching my head for sure. In this case I decided to skip both of the via points as I decided not to make the stops 23 and 24, and this worked just fine and the rest of the route worked flawlessly.
                        Thanks for your input.
                        Steve
                        Steve Jarrell
                        2025 BMW R1300GS
                        2025 Can-Am Spyder
                        Garmin XT3
                          Steve Jarrell
                          Steve Jarrell
                          Steve Jarrell
                          @Con-Hennekens The one other possibility is that I am using the offline mode with the offline HERE maps, and perhaps there's a slight difference between using the online maps with the app for testing and actually navigating using the online ones.
                          I thought at first the perhaps I accidentally passed by the road that the shaping point was on, but looking back at the screenshot there was no symbol in the upper left corner indicating that a shaping point was being bypassed.
                          Steve
                          Steve Jarrell
                          2025 BMW R1300GS
                          2025 Can-Am Spyder
                          Garmin XT3
                            Steve
                            @Steve-Jarrell, yesterday I was planning an entirely different route when I saw something that looked quite similar... There was NO road going to my waypoint on the basemap, but there was on the overlay map. I don't know if this could apply to your case, but thought I would drop it here šŸ˜‰ .
                              Steve Jarrell
                              Steve Jarrell
                              Steve Jarrell
                              @Con-Hennekens Thanks! I'm betting there was something in the offline HERE map that caused the anamoly. I'll watch it closely for a while and see if it happens again.
                              I appreciate your input!
                              Steve
                              Steve Jarrell
                              2025 BMW R1300GS
                              2025 Can-Am Spyder
                              Garmin XT3
                                Thanks!
                                Steve
                                Online planner:
                                MyZ51
                                MyZ51
                                MyZ51
                                @Steve-Jarrell J ran the animation and it followed timeouts as designed. I suppose if one had deliberately turned and took the unplanned route ther’d have been ā€˜revert’ options come up.
                                I always figured that if you designed it on the desktop and emailed the route or QR, the recipient’s app would follow your shaped route, thus overriding any settings they have in their device setup.
                                • MyZ51 MyZ51
                                  @MyZ51 said in Shaping point ignored by app:
                                  You figured correctly, except for that not device settings are honored, but planner settings are. And of course only within the MRA ecosystem. An exported GPX does not contain any planner settings.
                                  Steve Jarrell
                                  Steve Jarrell
                                  MyZ51
                                  MyZ51
                                  • Startpunt wijzigen
                                    Ad V
                                    Ad V
                                    Ed van Klink
                                    Ed van Klink
                                  • Vrienden toevoegen
