  4. MRA CarPlay mit Remotek One
55 Posts 12 Posters 23.6k Views 7 Watching
  • Thomas Neumeyer
    Thomas Neumeyer
    Thomas Neumeyer
    Silverfox created their own App. With this App you can also control Google Maps.
    • Huibertus
      Huibertus
      Huibertus
      Ja, voor Android maar niet voor IOS
        @Huibertus, of course you can try to buy a BarButtons at https://jaxeadv.com/barbuttons/ but from what I hear he is not very responsive anymore. I have been in contact in the past and have build multiple BBs myself. I would be happy to sell you one (send me a DM if you want to). Yes it is a bit clunky, but it works fine and the buttons are a great fit to gloved fingers.
        On the other hand, it seems counterintuitive to have your phone open, running the MRA app on your handlebar just to be able to operate the carpuride. I think you are better of with a AA/CP device that has a controller, or a phone to replace your carpuride, and a BT controller along with it.
        @Con-Hennekens hi Con, I think you're the AA/CP specialist, not me. I can only see, there are a lot of issues reported wit using AA/CP, especially in combination with a remote controller.
        That's the reason, I decided for a device from DMD incl. one of their remote controllers.
        But unfortunately, the Remote-2 controller model is still not supported by MyRoute-App. Some functions are working, some not, or in an unexpected result.
        Long time ago, I asked here if we can follow in MyRoute-App the the example of DMD: offering a table in UI by which the user can setup, which function should result in the App, by which signal coming from the controller. It should have a default setup, but users can change to their preferences.
        May we can discuss further on in another thread, to prevent hijacking this thread?
        • Guzzist Guzzist
          @Guzzist, Yes, so people can configure their own compatibility. I understand that idea, but problem would be the software DMD (in this case) uses to catch the key presses I think. I really don't know, but it is definitely not my decision to make 😉
          • Huibertus
            Huibertus
            Huibertus
            I purchased the Remotek and it does everything it is supposed to do for me on the iPhone. However, I do not see the results of the control reflected in CarPlay. Reading the comments above, that should be possible. What am I doing wrong, or am I missing a setting?
              @DerRoteBlitz
              Tipp: am Remotek One
              • in der Remotek One mal umstellen zwischen Android und iOS, einfach mal auf iOS stellen und testen
              Tipp: am Handy
              • bei mir ist im iOS die Tastatursteuerung auf Aus gestellt damit geht es sehr gut, vielleicht gibt es sowas auch bei Android
              • bei mir mit iPhone Xr mit iOS 18.4.1
              Einstellungen:
              Bei der Tastatursteuerung Ein stürzt bei mir die MRA immer mal ab. Mit der Einstellung der Tastatursteuerung Aus gehts bei mir jetzt immer sehr gut. War auch ein längerer Test über die vielen Einstellungen der Geräte.
              Huibertus
              Huibertus
              Huibertus
              @Hubert-Thoring said in MRA CarPlay mit Remotek One:
              @Hubert-Thoring How do you do that?
              • Huibertus Huibertus
                @Huibertus, only when phone is active wit MRA app in focus.
                • Huibertus
                  Huibertus
                  Huibertus
                  IPhone is active and MRA app in focus. But still no changes on the Carplay
                  • silberfuchs67
                    silberfuchs67
                    silberfuchs67
                    I do have the same experience. Remotek One activites are not completely shown on a CarPlay device.
                      Bluetooth controllers are, from MRA perspective, never promoted to control CarPlay / Android Auto because that’s not the intended behavior.
                      They are for your phone and the app.
                      Controller CarPlay / Android Auto is a whole different area.
                        #51
                        @Huibertus : That was before the V4.3.6, since then the keyboard control is also set to "On" under iOS ..!
                        Before V4.3.6, the on caused a crash when leaving the navigation, which is now done.
                        • Huibertus
                          Huibertus
                          Huibertus
                          wrote on last edited by Huibertus
                          #52
                          Disappointing. Do I have more functionality when I use an Android?
                            #53
                            Read what you should do under iOS to the arrow keys, and then the iOS instruction and your Remotek One version :Link zu Remote Web
                              #54
                              Hello everyone,
                              The following test is simply intended to show that you can still control a CarPlay display specifically for navigation using the Remotek One. The goal here is to demonstrate that functions like zooming (+/-) and skipping waypoints can be operated directly, as these are the most important features.
                              Although this test was conducted in a car, it should work exactly the same way with a CarPlay display on a motorcycle which is precisely the point here.
                              • MyRouteApp V6.0.0 (532)
                              • Remotek One V2.1.0
                              Zooming in/out and skipping waypoints works very well.
                              Here is an example video from inside a car; it should work just as well on a motorcycle equipped with a CarPlay display.
                              • Klick zum Test Video
                                #55
                                Sorry, now the video is also available, it was still on private.
                                Should go now Link zum Video
                                • 3
                                Mopetenpit
                                Mopetenpit
                                Thomas Neumeyer
                                Thomas Neumeyer
                                silberfuchs67
                                silberfuchs67
                                Huibertus
                                Huibertus
                                DerRoteBlitz
                                DerRoteBlitz
                                  Alderweireld Rudi 0
                                  Alderweireld Rudi 0
                                • Weather as a service
                                • 1 bij app icoontje
                                  Don Stauffer
                                  Don Stauffer
                                  Andy Smith 5
                                  Andy Smith 5
