  4. Route could not be calculated
23 Posts 9 Posters 9.3k Views 2 Watching
    @Thomas-Neumeyer Did you save your route after creating it in the app route planner? I might be wrong, but I believe that to use a route offline that was created in the app route planner you would need to save it before using it.
    Thomas Neumeyer
    Thomas Neumeyer
    Thomas Neumeyer
    @Nick-Carthew Yes I saved it.
      @Con-Hennekens I have been using my Samsung tablet. I assume it is native together with the app. I am not using AA or CP at all. Today I gave it another trial. Route planned with planning tool from the app. Not the web version. Connected via hotspot. Route started. Lost connection and app went bananas. I have all required maps downloaded but routing was impossible. I thought the app is switching automatically to off line routing? Stopping the app and restart helped. Still not happy. Web based route planning works like a charm but. This I can state. But navigation next not really good.
      @Thomas-Neumeyer said in Route could not be calculated:
      app went bananas
      That is a nice description, but not really informative. Can you elaborate?
      There is an option in de settings that says "Navigate routes as tracks" (or similar in English). Is that enabled? Disable it and try again. Tracks can only be calculated online, but the app should make an approximation and throw a message about that.
      No, it will always throw a message to ask if you want to go online or offline.
      Thomas Neumeyer 1 Reply Last reply
        app went bananas
        Thomas Neumeyer
        Thomas Neumeyer
        Thomas Neumeyer
        @Con-Hennekens Bananas means that the app told, route can not be calculated, tried to recalculate, route can not be calculated, tried to recalculate, route can not be calculated and so on. I stopped it then. To be honest in this situation in an area without knowing where you are this is quite let’s say bad. Even the OEM app and arrow navigation is able to recalculate. As far I remember in the live blog from the developer it was stated that it switches to offline mode automatically. But I have to admit that I am not 100 % sure. Today I navigated with a A to B navigation. Was working fine except that there were the „original“ bright blue lines to see. But not following the street just straight lines. But I am sure this can be disabled somewhere in the settings.
        Thomas Neumeyer
        Thomas Neumeyer
        Joce-Doubs
        Joce-Doubs
        • Custom POI color and icons
        • F004 MRA Navigation Error
          12.3k
        • A11 Making the Algorithm More Visible – Overview and Planner File
        • File / Creation date
          Robineke
          Robineke
        • F003 POI Folder & group missing in the app
        • F005 Menu covered
