  4. Waypoint insertion
Waypoint insertion
12 Posts 4 Posters 3.2k Views 2 Watching
  • Sanktjohanser
    Sanktjohanser
    Sanktjohanser
    Route planning: It would be nice if, when adding a waypoint to an existing route, it weren't placed at the end of the list as is currently the case, but rather intelligently integrated into the route. This is already implemented in the myrouteapp.
    Regards, Heinrich
    • Sanktjohanser Sanktjohanser
      Regards, Heinrich
      @Sanktjohanser, the method is: click ON the routeline between the two waypoints you want it in between (the crosshair turns into a waypoint symbol d0149869-8389-4f94-9910-54562fb2e01d-image.png ). Then drag that waypoint to the desired location.
      Sanktjohanser 1 Reply Last reply
        Sanktjohanser
        Sanktjohanser
        Sanktjohanser
        This procedure does not work in the route planner on the iPad.
        TomOnTour Nick Carthew MotoCon 3 Replies Last reply
          TomOnTour
          TomOnTour
          TomOnTour
          @Sanktjohanser
          it works if you use a mouse or a pen with your iPad 🙂
          Greetings
          Thomas
          using iPad Pro (iPadOS 27.2.1) and Macbook Air (macOS 27.2.1)
            @Sanktjohanser said in Waypoint insertion:
            Double tap on the route line to add a new sequential route point, you can then drag it to a new position.
              Sanktjohanser
              Sanktjohanser
              Sanktjohanser
              @Nick-Carthew
              Double-tapping the route creates a new waypoint, but again with the last number on the waypoint list.
                @Nick-Carthew
                @Sanktjohanser If you are using the website route planner, double tapping on the route line does work, zoom in to make sure you are accurately double tapping on the route line.
                If you use the mobile app route planner, a long press on the route line adds a new sequential route point.
                  @Nick-Carthew
                  @Sanktjohanser
                  Here’s a short video showing the double tap on my iPhone:
                  https://drive.google.com/file/d/1lP2QXt_iXp2c5itmeHZzZkRz8--RyyDp/view?usp=drivesdk
                    Sanktjohanser
                    Sanktjohanser
                    Sanktjohanser
                    @Nick-Carthew
                    Thank you very much for the info.
                    Sometimes the correct number assignment works, but not always. Maybe I'm still doing something wrong.
                    However, I don't think the software has handled this very well. In the app, you can simply add a new waypoint during navigation, which is then incorporated into the route guidance.
                      @Nick-Carthew
                      @Sanktjohanser The double tap does take a little practice. The website route planner that you are using is not specifically designed for touch screens. In my opinion It has been adapted well. You also have the option of using a mouse with your iPad.
                      • TomOnTour TomOnTour
                        @Sanktjohanser
                        Greetings
                        Thomas
                        This post is deleted!
                          @Sanktjohanser, That's crucial information you left out 😉
                          Correct answers have been given.
                          TomOnTour
                          TomOnTour
                          Sanktjohanser
                          Sanktjohanser
                            Rory Burke
                            Rory Burke
