  4. Nav app asking me to approve faster routes?
navcarplay
14 Posts 6 Posters 5.0k Views 3 Watching
  • David MP
    David MP
    David MP
    I've been using MRA on my motorcycle for many years with a Garmin satnav; however this year I'm intending to buy one of the 'Apple CarPlay' type devices on the bike which will enable me me to use the MRA Nav appp directly. But over the winter, I'm testing it out in the car before I take the plunge!
    First time out, I had an immediate issue - the Nav kept notifying me that it had found a faster route, and to confirm whether I wanted to accept or dismiss this suggestion. Honestly, it happened every two minutes, and the pop-up was massive, occupying about one-third of the screen. Google Maps has a similar feature, but much less frequent and far less intrusive.
    Can this feature be turned off (ie, just 'accept' or maybe 'dismiss' by default)? I really wouldn't want to be dealing with this on the bike.
    • David MP David MP
      @David-MP hmm, it definitely should not continue to suggest the same fastest route. When dismissing a suggestion, it should not be suggested again. If you however keep driving into a traffic jam and alternatives are available all the time, it might make sense again.
      Anyhow, it does not really take that much space as it just overlaps your ETA information at that moment. Not any more "map" space.
      You can turn it off by disabling the "traffic aware navigation" setting.
      Marinus van Deudekom David MP 2 Replies Last reply
        @Corjan-Meijerink it would be great that by default the plotted route would be followed instead of the other suggesties route
          @Marinus-van-Deudekom I disagree. The feature is only enabled when driving a fastest AB route. So by definition the user wants the fastest possible route.
          If we'd be talking about planned routes, I'd agree with you 😉
            @Corjan-Meijerink it was indeed during a A B route, fastest mode when I was running into a major traffic jam
              David MP
              David MP
              David MP
              @Corjan-Meijerink Thanks very much - that's just what I needed to know. Very helpful too in that I've found a whole new sub menu of settings that I didn't know about!
              I'm very glad I decided to work out all my teething problems in the car over winter before the bike touring season starts!!
                David MP
                David MP
                David MP
                @Corjan-Meijerink So are you saying that if I'm using a predetermined route with lots of waypoints (which will be my norm when bike touring), then I will never be asked the 'change to fastest route?' question between waypoints, even if the 'traffic aware navigation' setting is enabled?
                • David MP David MP
                  @David-MP That is correct! 🙂
                  David MP 1 Reply Last reply
                    David MP
                    David MP
                    David MP
                    @Corjan-Meijerink Hmm, that's not so good then.
                    When I'm on tour I'm typically riding pre-organised routes on my Garmin device, using GPX files with waypoints, created on MRA. The disadvantage of that is that I'm exclusively using downloaded maps, with no live input (Garmin's 'Smart Link' attempt at fixing that was awful); therefore my prime reason for buying the MRA-Navigator app was to fix this problem. Very disappointing to learn that it will be no better than before, and I may as well stick with my Garmin after all.
                    • David MP David MP
                      @David-MP sorry, what is the issue?
                      When driving pre planned routes, we won’t suggested faster routes. We let you stick to the planned routes.
                      That’s what you want right?
                        David MP
                        David MP
                        David MP
                        wrote on last edited by David MP
                        @Corjan-Meijerink Well not necessarily, no... if I'm on a route with, fairly lengthy stretch between waypoints, and there's really bad traffic or a road blockage somewhere in between them, I'd like to have the opportunity of avoiding that. Just thinking of my experience riding in Europe last year!
                        Or, for example, if my route needs to go through a town or city, I'd like to put my waypoints at the outskirts of the town and just let the 'traffic aware navigation' figure out the best way through it.
                        (Just to clarify - my original post in this thread yesterday was about driving the fastest A-B route in my car - ie, not what I would normally be using Nav for.)
                        MotoCon MartinW 2 Replies Last reply
                        • David MP David MP
                          @David-MP, in all honesty, I never found the traffic feature disturbing through any of my scenic rides. Usually scenic rides are not very prone to traffic jams anyway. I would certainly not let myself be put off the MRA app based on experience in not very likely conditions. Try it in reality, on your bike, with real scenic routes. I think you will be convinced! 😉
                          • MartinW MartinW referenced this topic on
                          • David MP David MP
                            @David-MP said in Nav app asking me to approve faster routes?:
                            According to
                            @Corjan-Meijerink said in Nav app asking me to approve faster routes?:
                            there might be a solution: when manually skipping one or more route points while navigating a pre-planned route, the app will calculate the fastest possible route to the next upcoming RP, which means (to my understanding), it temporarily switches to AB mode - and that's where we have traffic aware calculation.
                            If this works, we can add some more RPs in areas where we expect traffic jams, allowing us to "sacrifice" them if we just need to "get out of here".
                            • Koen Keevel
                              Koen Keevel
                              Koen Keevel
                              wrote on last edited by Koen Keevel
                              I had a similar question in this forum : https://forum.myrouteapp.com/topic/9685/snellere-route-tijdens-navigatie-modus
                              The annoying thing is that it advises that it has found a quicker route by 1 minute. That is not really quicker, It would be quicker when it message you if it 5 minutes or more. One minute is (in my opinion) not worth mentioning. 5 minutes or more is.
                              I don't know if it is possible for the user to change the amount of minutes?
                              Would be great though.
                              Koen Keevel
                              Koen Keevel
                              David MP
                              David MP
                              • Real-time traffic
                                Ã’scar
                                Ã’scar
                                Andy Nicholson
                                Andy Nicholson
                              • HERE map not calibrated
                              • Myrouteappstay
                              • Navigatie met DMD tablet
                              • Show on the maps's button
