  4. Different Default Maps for Routeplanner and Navigation
4 Posts 3 Posters 1.1k Views 2 Watching
  • Next Stop
    Next Stop
    Next Stop
    Hi there,
    Just wondering if an option for setting the default map for the routeplanner different to the actual navigation on the app.
    I like to plan my routes using the "logistics" map as it gives more information, but when actually navigating I like to use the "roads only" as I feel it's more clean cut when glancing down whilst driving.
    I feel like it would be a good option to be able to set these independently
    Cheers
    Martin
    HABVEN aka MrMRA MotoCon 2 Replies Last reply
    • Next Stop Next Stop
      Hi there,
      Cheers
      Martin
      @Next-Stop
      Navigation Next uses the Here-Map. You can use the map overlay you want, but use the Here-map for planning
      • Next Stop
        Next Stop
        Next Stop
        Thanks for the reply, I should have been clearer though😆.
        What I meant is when using the Routeplanner within the Myroute App (Android).
        I tend to do all my planning on my mini tablet and then clip this to car for driving. I like the fact the app is an all in one tool, so much better than most Satnav app out there!
        Cheers!
          Hi there,
          Cheers
          Martin
          @Next-Stop said in Different Default Maps for Routeplanner and Navigation:
          Yes, using the webplanner they are independant, but the app-planner uses the same map-style as the navigation mode indeed. I do not much planning on the device I use for navigating, so it is not a real problem for myself, but I agree with you that it is logical to have seperate map-style settings for the planner and the navigator.
          Next Stop
          Next Stop
