  4. Different Default Maps for Routeplanner and Navigation
4 Posts 3 Posters 896 Views 2 Watching
  • Next Stop Offline
    Next Stop Offline
    Next Stop
    Hi there,
    Just wondering if an option for setting the default map for the routeplanner different to the actual navigation on the app.
    I like to plan my routes using the "logistics" map as it gives more information, but when actually navigating I like to use the "roads only" as I feel it's more clean cut when glancing down whilst driving.
    I feel like it would be a good option to be able to set these independently
    Cheers
    Martin
    Hans van de Ven MR.MRA Con Hennekens 2 Replies Last reply
    • Next Stop Next Stop
      Hi there,
      Cheers
      Martin
      @Next-Stop
      Navigation Next uses the Here-Map. You can use the map overlay you want, but use the Here-map for planning
      • Next Stop Offline
        Next Stop Offline
        Next Stop
        Thanks for the reply, I should have been clearer though😆.
        What I meant is when using the Routeplanner within the Myroute App (Android).
        I tend to do all my planning on my mini tablet and then clip this to car for driving. I like the fact the app is an all in one tool, so much better than most Satnav app out there!
        Cheers!
          Hi there,
          Cheers
          Martin
          @Next-Stop said in Different Default Maps for Routeplanner and Navigation:
          Yes, using the webplanner they are independant, but the app-planner uses the same map-style as the navigation mode indeed. I do not much planning on the device I use for navigating, so it is not a real problem for myself, but I agree with you that it is logical to have seperate map-style settings for the planner and the navigator.
          Next Stop
          Next Stop
          • Rondrit maken lukt niet
            Rob Vonk
            Rob Vonk
          • Questions and suggestions
            Mike wiruth
            Mike wiruth
