  4. gpx not recognized problem
17 Posts 3 Posters 10.7k Views 2 Watching
  • Aiello antonino
    Today MRA from the web is giving me problems, I can download the GPX file, but it is not recognized by any platform, I don't understand why... What's happening? I tried from iPad and iPhone and it doesn't work, I don't have a computer at the moment... It only works if you download the file from the app, in that case the file is correct and is recognized by the other platforms.
    • Aiello antonino
      I don't remember if the figure has always been this one...
      • Aiello antonino
        no solution? does this happen to anyone else?
          @Aiello-antonino I do not recognise the message in the screenshot and I cannot translate what it says.
          Aiello antonino 1 Reply Last reply
            @Nick-Carthew the writing is only the name of the file and the extension of the file itself to note, that is .GPX.CHART
              @Aiello-antonino What is .GPX.Chart and what are you attempting to do.
              Sorry but your question is not very clear.
              Are you saying that there is a problem with a route that is in MRA?
              If you are, then sharing the route to this forum might help find the answer.
              • Aiello antonino
                I AM EXPORTING IT and NOT importing it…can you try to export a file from your collection and check if the extension of your file is like the one in the photo? because I export the file but then when I import it for example in Google mymaps it tells me that the file is not supported, when instead it has always worked…the same thing happens on other platforms too
                • Aiello antonino
                  @King-06 as I wrote in the initial post, yes! I tried from the app and everything works fine! the file is correct!
                  • Aiello antonino
                    @Re-Il tuo pop-up durante l'esportazione assomiglia al mio con .gpx.chart scritto?
                    Can you post a screenshot please?
                    • Aiello antonino
                      @King-06
                      https://youtu.be/5GrHx8_6MIQ?si=FGZ2B9b1mODsYJaT
                      this is my workflow! but i always did it this way! i'm not that young on MRA, i never had this problem, it's only been happening for two days
                      • Rolf Engelsman
                        Rolf Engelsman
                        Rolf Engelsman
                        I can‘t reproduce your problem either. We have the same workflow. Make a support ticket and share the url of your route and make sure the settings are public.
                        BMW R1250RT
                        Ali CarPlay scherm
                        iPhone 16 Pro Max
                        • Aiello antonino
                          @Re-06 questo è il file che viene scaricato, prova a caricarlo in MRA per vedere se funziona!
                          https://drive.google.com/file/d/1oxiAimc9O9w0WejXZp64XzRqPF8OjMoM/view?usp=drivesdk
                          • Aiello antonino
                            I know that there is nothing wrong in my workflow, but the file that is downloaded is not recognized even by MRA if I try to upload it, it is not recognized even by other platforms like Google or Mappite or Kurviger or others
                            • Aiello antonino
                              @King-06 sì! So che il problema è il grafico di scrittura, ma non so perché questo accada! anche se rinomino il file non viene letto correttamente da altre piattaforme, almeno questo succede a me
                              https://www.myrouteapp.com/it/social/route/10252905?mode=share
                              Rolf Engelsman 1 Reply Last reply
                                Rolf Engelsman
                                Rolf Engelsman
                                Rolf Engelsman
                                It seems that I don‘t have the same problem with your route. I don‘t get the double extension.
                                BMW R1250RT
                                Ali CarPlay scherm
                                iPhone 16 Pro Max
                                • Rolf Engelsman
                                  Rolf Engelsman
                                  Rolf Engelsman
                                  I can‘t use your generated .gpx file in MRA or TT GoRide.
                                  MapsMe, Garmin Connect, BMW Motorrad do generate a usable route.
                                  Make a support ticket and let the developers have a look at it.
                                  BMW R1250RT
                                  Ali CarPlay scherm
                                  iPhone 16 Pro Max
                                  • Aiello antonino
                                    @King-06 yeahhhh
                                    finally the right intuition! you're right, I had installed 2 apps to view the gpx, evidently one took over the file management, uninstalled and everything is fine! Thank you so much!
                                    Rolf Engelsman
                                    Rolf Engelsman
                                    • Move a GPS point on the map
                                    • Stopover expiration time notification
