  4. gpx not recognized problem
17 Posts 3 Posters 10.6k Views 2 Watching
    @Aiello-antonino I do not recognise the message in the screenshot and I cannot translate what it says.
    @Nick-Carthew the writing is only the name of the file and the extension of the file itself to note, that is .GPX.CHART
      @Aiello-antonino What is .GPX.Chart and what are you attempting to do.
      Sorry but your question is not very clear.
      Are you saying that there is a problem with a route that is in MRA?
      If you are, then sharing the route to this forum might help find the answer.
      • Aiello antonino
        I AM EXPORTING IT and NOT importing it…can you try to export a file from your collection and check if the extension of your file is like the one in the photo? because I export the file but then when I import it for example in Google mymaps it tells me that the file is not supported, when instead it has always worked…the same thing happens on other platforms too
        • Aiello antonino
          @King-06 as I wrote in the initial post, yes! I tried from the app and everything works fine! the file is correct!
          • Aiello antonino
            @Re-Il tuo pop-up durante l'esportazione assomiglia al mio con .gpx.chart scritto?
            Can you post a screenshot please?
            • Aiello antonino
              @King-06
              https://youtu.be/5GrHx8_6MIQ?si=FGZ2B9b1mODsYJaT
              this is my workflow! but i always did it this way! i'm not that young on MRA, i never had this problem, it's only been happening for two days
              • Rolf Engelsman
                Rolf Engelsman
                Rolf Engelsman
                I can‘t reproduce your problem either. We have the same workflow. Make a support ticket and share the url of your route and make sure the settings are public.
                BMW R1250RT
                • Aiello antonino
                  @Re-06 questo è il file che viene scaricato, prova a caricarlo in MRA per vedere se funziona!
                  https://drive.google.com/file/d/1oxiAimc9O9w0WejXZp64XzRqPF8OjMoM/view?usp=drivesdk
                  • Aiello antonino
                    I know that there is nothing wrong in my workflow, but the file that is downloaded is not recognized even by MRA if I try to upload it, it is not recognized even by other platforms like Google or Mappite or Kurviger or others
                    • Aiello antonino
                      @King-06 sì! So che il problema è il grafico di scrittura, ma non so perché questo accada! anche se rinomino il file non viene letto correttamente da altre piattaforme, almeno questo succede a me
                      https://www.myrouteapp.com/it/social/route/10252905?mode=share
                      Rolf Engelsman 1 Reply Last reply
                        Rolf Engelsman
                        Rolf Engelsman
                        Rolf Engelsman
                        It seems that I don‘t have the same problem with your route. I don‘t get the double extension.
                        BMW R1250RT
                        • Rolf Engelsman
                          Rolf Engelsman
                          Rolf Engelsman
                          I can‘t use your generated .gpx file in MRA or TT GoRide.
                          MapsMe, Garmin Connect, BMW Motorrad do generate a usable route.
                          Make a support ticket and let the developers have a look at it.
                          BMW R1250RT
                          • Aiello antonino
                            @King-06 yeahhhh
                            finally the right intuition! you're right, I had installed 2 apps to view the gpx, evidently one took over the file management, uninstalled and everything is fine! Thank you so much!
                            Rolf Engelsman
                            Rolf Engelsman
                              Alderweireld Rudi 0
                              Alderweireld Rudi 0
                              Hanza 0
                              Hanza 0
                              Jack 13
                              Jack 13
                            • Weather as a service
                              Spili
                              Spili
                            • 1 bij app icoontje
                            • Map Layers
                              Don Stauffer
                              Don Stauffer
                              Andy Smith 5
                              Andy Smith 5
                            • Lane view in Android Auto
                              denWINNE
                              denWINNE
