  4. Search on iPhone and see results
9 Posts 6 Posters 1.2k Views 5 Watching
    is it only me having problems to add an address or to search for something?
    The input frame is ok to use, but the results are difficult to read, only line by line. I can not close the input keyboard to see more results. And I can not move the results up to see more.
    Is it the same at yours iPhone?
    Rob Verhoeff GT JWR Hubert Thoring Con Hennekens 4 Replies Last reply
      @Jörgen Yes, you would think so. However, I believe your search query isn't quite finished yet. If you first click on 'Fertig' after entering your search query, you'll suddenly see that the search results are readable. A matter of interpretation?
        GT JWR
        GT JWR
        GT JWR
        @Jörgen not only that, I have also run into (on many occasions on the web planner) where the search window is smaller that the number of characters needed to display the correct search address and the full address is not displayed. For example, pick out a big chain company that has numerous locations - especially within a large city - and try to discern the correct address you are looking for - not easily done. Definately room for improvement of the search function.
          @Jörgen : nein bei mir gehts so wie es soll 👋
          • Dirk Kevin K.
            Dirk Kevin K.
            Dirk Kevin K.
            Goog mornig @Jörgen ,
            Please tip on "Fertig". 😊
            iPhone 15 Pro (iOS 18.4.1)
            iPad Pro (iPadOS 18.4.1)
            MyRoute-APP (5.1.0 - 462), All-Lifetime)
            Honda NC750S DCT / Carpuride W502 / Garmin XT
            BMW F800R / Carpuride W702B / Navigator VI
            SENA 50S / Cardo Packtalk Edge
              @Jörgen, the behavior on Android is not much different. The keyboard obscures the search results. It would be nice if the results window could be made a bit higher, so that at least 2 or 3 of the results are visible without hiding the keyboard. I consider your point very valid indeed.
                @Jörgen
                Gibt man zB Kiel ein , zZ ja in Laboe, und drückt dann Fertig kommt doch alles was man sucht bzw. was MRA für Kiel bietet..!
                If you enter e.g. Kiel, zZ yes in Laboe, and then press Done comes everything you are looking for or what MRA offers for Kiel ..!
                Suche:
                Fertig getippt
                  @Jörgen
                  Suche:
                  Fertig getippt
                  @Hubert-Thoring, yes but that had already been established. Like I said, it would be nice if not the complete list got obscured by the keyboard.
                    It would be nice and helpful if you could move the result windows up and down with the two lines ( = ) as you wish.
                    I do not need map view in this moment and if yes you could move the result window away.
                    GT JWR
                    GT JWR
                    Dirk Kevin K.
                    Dirk Kevin K.
                    • Vergrendel scherm zet alles op z'n kop
                    • Hallo, wéér een nieuwe gebruiker !
                    • How to delete favourites?
                      Tom.Fox
                      Tom.Fox
                      3.0k
                    • MRA 6.0.0 - 515 Carplay folder twice
                      Jörg Neudert
                      Jörg Neudert
