  4. MRA not getting to my home address?
7 Posts 6 Posters 1.5k Views 3 Watching
  • Ron Z
    Ron Z
    Ron Z
    MRA Next is not finding my home address correctly on a route when I stored it as a Favorite. This is using MRA Next on my iPhone. Any ideas on what else I can try?
    2009 BMW K1300GT
    Garmin zümo XT
    Samsung Galaxy Tab Active 5 w/RAM mount
    2023 BMW R18 Transcontinental
    iPhone 14 Pro Max w/QuadLock mount
    Apple CarPlay in Carpuride W603D w/front-rear cameras
    TomOnTour Rob Verhoeff paul69 3 Replies Last reply
    • Ron Z Ron Z
      TomOnTour
      TomOnTour
      TomOnTour
      wrote on last edited by TomOnTour
      @Ron-Z What is the problem MRA NExt has with your home address? Wrong routing, does it not find the address at all?
      I have done the same thing, like you did and stored a favourite for my home address. As a long term Garmin user it is named HOME 🙂
      But the name doesn‘t matter st all.
      If you go to my favourites and I select my HOME it immediately starts the calculation and I could, if I want to change the routing behaviour to curvy or anything else.
      Greetings
      Thomas
      using iPad Pro (iPadOS 27.2.1) and Macbook Air (macOS 27.2.1)
      • Ron Z Ron Z
        @Ron-Z I can only reproduce this if my physical address is located very far from the road (your saved favorite) and there is no accessible road (according to the Here map) directly leading to my front door.
        • Rob Veerman
          And what if you use the coordinates and then store those?
          • Ron Z Ron Z
            @Ron-Z said in MRA not getting to my home address?:
            hi,
            do you actually need to have it exactly marked?,
            Personnaly, I do have an address near to my home, to use as favourite for when i require MRA to get me there from a particular point. this works for me perfectly.
            K1600 GTL
            iPhone 13 Pro, carpuride 702b
            • Ron Z
              Ron Z
              Ron Z
              After further investigation it appears the HERE data is incorrect for my location. The circled street area in red does not exist:
              The above image is what MRA gave me when I set a route to my location while at my location. Taking a route up to 228th St that does not exist.
              Here is the same image from a HERE map in Garmin BaseCamp:
              The correct layout taken from a TomTom map is correct:
              I've reported the map error to Garmin, so I'll see if it ever gets corrected.
              But MRA does not attempt to come North up Marigold Ave when it should, instead the route takes me to my home address where it doesn't exist on another street. Weird...
              2009 BMW K1300GT
              Garmin zümo XT
              • Ron Z
                Ron Z
                Ron Z
                @Peter-Schiefer Thanks Peter! Just reported.
                2009 BMW K1300GT
                Garmin zümo XT
                TomOnTour
                TomOnTour
                Ron Z
                Ron Z
                  Rob Draaisma 0
                  Rob Draaisma 0
