  4. MRA not getting to my home address?
7 Posts 6 Posters 1.2k Views 3 Watching
  • Ron Zundefined Offline
    Ron Z
    MRA Next is not finding my home address correctly on a route when I stored it as a Favorite. This is using MRA Next on my iPhone. Any ideas on what else I can try?
    2009 BMW K1300GT
    Garmin zümo XT
    Samsung Galaxy Tab Active 5 w/RAM mount
    2023 BMW R18 Transcontinental
    iPhone 14 Pro Max w/QuadLock mount
    Apple CarPlay in Carpuride W603D w/front-rear cameras
    TomOnTourundefined Rob Verhoeffundefined paul69undefined 3 Replies Last reply
    • Ron Zundefined Ron Z
      TomOnTourundefined Offline
      TomOnTour
      wrote on last edited by TomOnTour
      @Ron-Z What is the problem MRA NExt has with your home address? Wrong routing, does it not find the address at all?
      I have done the same thing, like you did and stored a favourite for my home address. As a long term Garmin user it is named HOME 🙂
      But the name doesn‘t matter st all.
      If you go to my favourites and I select my HOME it immediately starts the calculation and I could, if I want to change the routing behaviour to curvy or anything else.
      Greetings
      Thomas
      using iPad Pro (iPadOS 26.5) and Macbook Air (macOS 26.5.1)
        Rob Verhoeffundefined Offline
        @Ron-Z I can only reproduce this if my physical address is located very far from the road (your saved favorite) and there is no accessible road (according to the Here map) directly leading to my front door.
        • Rob Veermanundefined Offline
          And what if you use the coordinates and then store those?
            paul69undefined Offline
            @Ron-Z said in MRA not getting to my home address?:
            hi,
            do you actually need to have it exactly marked?,
            Personnaly, I do have an address near to my home, to use as favourite for when i require MRA to get me there from a particular point. this works for me perfectly.
            K1600 GTL
            Oukitel RT3
            iPhone 13 Pro, carpuride 702b
              Ron Z
              After further investigation it appears the HERE data is incorrect for my location. The circled street area in red does not exist:
              The above image is what MRA gave me when I set a route to my location while at my location. Taking a route up to 228th St that does not exist.
              Here is the same image from a HERE map in Garmin BaseCamp:
              The correct layout taken from a TomTom map is correct:
              I've reported the map error to Garmin, so I'll see if it ever gets corrected.
              But MRA does not attempt to come North up Marigold Ave when it should, instead the route takes me to my home address where it doesn't exist on another street. Weird...
              2009 BMW K1300GT
              Garmin zümo XT
                Ron Z
                @Peter-Schiefer Thanks Peter! Just reported.
                2009 BMW K1300GT
                Garmin zümo XT
                paul69undefined
                TomOnTourundefined
                TomOnTour
                Ron Zundefined
                Ron Z
                  Lenny Oundefined
                  Lenny O
                • Updated beta! 5.2.1 (486)
                  richtea999undefined
                • Veekeersinfo en omleiden
                • wrong routing
                  ErikMatthezingundefined
                  ErikMatthezing
                • Request login credentials
                • [Suggestion] Mark 'skipped' routepoints in sidebar
                  Yannick_van_Vugtundefined
                  Yannick_van_Vugt
