  4. Understand auto zoom
14 Posts 6 Posters 5.8k Views 5 Watching
  • Makro
    Makro
    Makro
    Today I noticed missing auto zoom at intersections and roundabouts, so I took a look at the settings πŸ€”
    In Navigation Settings-> Map Layer:
    Zoom Correction seems to be how much the app should zoom at intersections etc , that is, only if the app considers the road to need any zoom. Or what?
    What do the Automatic Zoom Correction icons do?
    Best regards, Makro
    Rob Verhoeff RetiredWingMan 2 Replies Last reply
    • Makro Makro
      @Makro
      Off: we do nothing extra
      Speed icon: based on speed slightly less zoom
      Instruction icon : based on next instruction distance less zoom
      On: we use both! This was default like it was
      MotoCon Makro 2 Replies Last reply
      • Makro Makro
        I would like to see a more detailed explanation of the zoom function and options. For example,
        if I adjust option for zoom correction, does that affect the auto zoom as speed increases / decreases?
        If I manually adjust the map zoom while navigating, does that stop the auto zoom function?
        Thanks
          @Makro
          @Rob-Verhoeff, I doubt that this is correct Rob, I think it sets auto-zoom completely off, only based on speed, only based on instructions, or both. If not completely off, zoom correction and tilt correction are used at the chosen options.
            Thanks
            @RetiredWingMan said in Understand auto zoom:
            Yes, but only when the speed icon or ON icon is selected.
            No, after a few seconds of driving the map will be centered again, and the normal zoom / zoom correction will be active.
              @Con-Hennekens Well, then somebody is wrong, but not me πŸ˜‰
              https://forum.myrouteapp.com/topic/6892/new-update-4-1-3/2?page=1
                @Rob-Verhoeff, okay okay! I stand corrected! πŸ˜‰
                With the addition though, that "less" can also be "more" in the given example.
                Strange though, I can imagine some people would want auto zoom te be off, but then that seems to be not possible.
                  @Makro
                  Makro
                  Makro
                  Makro
                  @Rob-Verhoeff said in Understand auto zoom:
                  @Makro
                  I don't get any autozoom or auto tilt. At least nothing compared to what my old Garmin device was capable of.
                  So, in order to get the most autozoom and tilt in the MRA app, then the 3 settings will have to be like this?
                  • Automatic Zoom Correction=On
                  • Zoom Correction=++
                  • Tilt Correction=++
                  Best regards, Makro
                  • Makro Makro
                    @Makro
                    @Makro. I use Zoom correction = - -.
                    Gives me a wider view. Auto zoom in still works.
                    • Makro Makro
                      @Makro
                      @Makro, With zoom correction on ++ you will always be zoomed in a lot. But the comprehension of the new setting is a bit unintuitive for sure...
                        I do understand the confusion.
                        So the "Automatic zoom correction" was something we did ourselves but did not allow the user to configure. Therefore "on" is the default behavior.
                        The faster you drive, the more the app zooms out.
                        The further away a maneuver is, the more the app zooms out.
                        Those factors add up πŸ˜‰
                        So when driving 130 km/h on a highway while having the instruction to take the exit in 80 km means the app zooms out quite a lot.
                        If you drive fast in the city (70 km/h) but need to take the exit in 1km, the app still zooms out a bit to allow you to anticipate with the speed you are driving.
                        If you only want the app to zoom out based on speed, set it to the speed icon. If you only want to zoom out based on distance to the next instruction, put it on the instruction icon πŸ™‚ By default it is "on" and that does both.
                        The baseline zoom is affected by the zoom correction. The is the normalized zoomlevel upon which all other adjustments are based. So if you want slightly less or more zoom, use that setting. This is always applied.
                          I think the auto zoom out is too powerful 😊
                            @Nick-Carthew πŸ˜†
                              @Nick-Carthew, I guess you were just speeding... A LOT... πŸ˜‰
                              Makro
                              Makro
                              • BΓ©ta to no-bΓ©ta
