  4. Extra voices issue on Apple Play
4 Posts 3 Posters 67 Views 1 Watching
  • Larry Stayner
    Larry Stayner
    Larry Stayner
    When connected to Apple play and a turn comes up, I get a pre statement that says" Voice command apple communicate " before it gives the actual turning directions. It then says 'voice command" after the directions. It is like it is speaking a couple of lines of code instead of running them in the back ground. It has done this in the last two beta releases.
    • Larry Stayner Larry Stayner
      @Larry-Stayner that’s very strange. Haven’t heard of this as an issue before.
      Could it be an accessibility setting on your phone?
        It looks like Voice Control is on.
        How do I disable Voice Control on iPhone?
        On the "Accessibility" screen, scroll down to look for the "Side Button" option and tap it. 4. On the "Side Button" screen, under "Press and hold to speak," you have the option to select whether pressing and holding the home button activates Siri or Voice Control or whether it does nothing at all.
        Larry Stayner 1 Reply Last reply
          Larry Stayner
          Larry Stayner
          Larry Stayner
          @Jörgen Sorry it took me so long to respond. The setting you are talking about is set to off.
          Larry Stayner
          Larry Stayner
          • Go to Forum from MRA Next (beta)
          • Website update - Best order, daylight on your ride, edit several waypoints at once and more
          • The waypoint list displays an incorrect calculation of the kilometres.
          • Navigating on NEX
          • Add waypoints to favorites and management of favorites with Next
          • V6 - Track Navigation
          • 'Geen adres bekend'
