  3. Import route-track GPX 1.2 differs from original route
7 Posts 2 Posters 1.6k Views 1 Watching
  • Richard van Erp 1
    Richard van Erp 1
    Richard van Erp 1
    For display reasons only I want to hide the shapingpoints and see the via points only. Knowing that it is not possible to hide shapingpoints I did the following: Save as GPX 1.2 (Route, Track, POI) and import as route-track. When I look at the route it has many deviations to the original route. When I import as track the track is exactly equal to the original route. It only doesný the display the via points (obviously) but that is what I'm aiming at. what could be the reason that the import as a route gives so many deviations and as a route-track it is exactly the same as the original drawn route? I would like to use the route-import because what is displaed is exactly what I'm aiming at.
    Greetings,
    HABVEN aka MrMRA 2 Replies Last reply
    • Richard van Erp 1 Richard van Erp 1
      Greetings,
      @Richard-van-Erp-1
      Hi @Richard-van-Erp-1 please share the url from the route here, so we can have a look. Make sure it is set to public
      Richard van Erp 1 1 Reply Last reply
        Greetings,
        @Richard-van-Erp-1
        If you save a route as gpx 1.2 you save a route track with via points.
        If you then import it again and convert it to a route, you do indeed have a chance of deviations.
        If you transfer your route as gpx 1.2 to your Zumo (the newer versions), you will only have the via points on your route. Then turn off the recalculation.
          @Richard-van-Erp-1
          Richard van Erp 1
          Richard van Erp 1
          Richard van Erp 1
          @Hans-van-de-Ven-MRA-Master
          Hi Hans,
          The URL to the original drawn route is ;
          https://www.myrouteapp.com/nl/social/route/8053718?mode=share
          I did not any conversion, only import the as GPX 1.2 saved route as a route. Or do you mean that importing as route that the conversion take place automatically?
          Greetings,
          Richard
          P.S.
          I used one of your routes as inspiration for this route...;-)
            Hi Hans,
            Greetings,
            Richard
            P.S.
            @Richard-van-Erp-1
            Thanks for using one of my routes as an example 👍
            The imported route is calculated, based on the formation and waypoints included in the route. Since there are no formation points in the gpx 1.2 route, the route is calculated based on the via points and that's what you see
              @Richard-van-Erp-1
              Richard van Erp 1
              Richard van Erp 1
              Richard van Erp 1
              Thanks Hans. Your explanation makes good sense.
              I originally thought that saving a route als GPX 1.2 was a track with via points, zo that when you again import it it is still a track with the via points shown. But it appears to be a calculated route with the via points.
                @Richard-van-Erp-1
                If you import the gpx 1.2 in your Zumo then you only see the viapoints
                Richard van Erp 1
                Richard van Erp 1
                • Map lock
                  tfdahazellgmail.com
                  tfdahazellgmail.com
                • Beta abonnement
                  BMW1300GSA
                  BMW1300GSA
                  2.3k
                  Gerard van der Veer
                  Gerard van der Veer
                • Uitnodiging
                  Hans Kremers
                  Hans Kremers
                • SilverFox Controller C2
