  3. Re-arranging RP's issues
13 Posts 5 Posters 2.1k Views 1 Watching
  • Kenneth de Miranda
    Kenneth de Miranda
    Kenneth de Miranda
    Hi, when using MRA Next (desktop/iPad) and adding a RP to a (long) route I cannot re-arrange that new RP to a different position by drawing it. It wil work when Moror or less on the same page of RP's but if you want to drag it to let's say between the first and second RP it wil not work.
    What I also find is that, in the dektop version at least, if I use the space bar in text edit, it crashes. When I enter the forum though the regular https://www.myrouteapp.com/route/open/7570968 browser version, both issues as mentioned above work fine. So it's only when I use MRA Next (on the desktop/iPad) that these occur.
      Kenneth de Miranda
      Kenneth de Miranda
      ...drawing should be dragging of course ๐Ÿ™‚
      • Nick Carthew
        Your question refers to the MRA RoutePlanner not MRA Navigation Next so I will move the topic to the General discussion area.
        Kenneth de Miranda 1 Reply Last reply
        • Nick Carthew Nick Carthew moved this topic from [Beta] Problems, Bugs and other Issues on
          Kenneth de Miranda
          Kenneth de Miranda
          Kenneth de Miranda
          @Nick-Carthew uhh actually not. It does refer to the MRA Next, as I explained in the description. The issues doe not appear in the regular MRA planner. So, since the MRA Next will be one platform (planning + navigation) it is suited for beta testing as well I presume.
          • Kenneth de Miranda Kenneth de Miranda
            @Kenneth-de-Miranda MRA Navigation Next is a navigation module that is added to the MRA Mobile app. MRA Navigation Next is unavailable for the desktop PC or Mac.
              Kenneth de Miranda
              Kenneth de Miranda
              Kenneth de Miranda
              @Nick-Carthew aha, ok.
                @Kenneth-de-Miranda. The planning module in MRA Mobile is actually an embedded view to the website, so we are speaking about the same thing ๐Ÿ˜‰ . In the mobile view you can double tap the route line in between 2 WP and an extra WP will be placed. Lastly you can drag that point to the desired location
                  Kenneth de Miranda
                  Kenneth de Miranda
                  Kenneth de Miranda
                  @Con-Hennekens now, that is one of the best tips so far ๐Ÿ™‚ did not know that the double tap inserted a RP in the right order. Maybe I should read the manual ๐Ÿ™‚ Thanks!
                  Con Hennekens RetiredWingMan 2 Replies Last reply
                    @Kenneth-de-Miranda, Thanks ๐Ÿ˜‰ The double tap functions like a single click in a PC browser. I think me too learned that here on the forum.
                      @Con-Hennekens but for me a single tap on the route line works also?
                        @StefanHummelink, Well now breaks my clogg... ๐Ÿคฃ You are totally right!
                          @Kenneth-de-Miranda you can also long press a waypoint and then, without releasing, move the waypoint to another location.
                            @Con-Hennekens and for me this has been like this also in the previous app. ๐Ÿ˜‹
                            Kenneth de Miranda
                            Kenneth de Miranda
                              503
                              Bart 9a 0
                              Bart 9a 0
                              465
                            • Statement on map spinning
                              1.8k
                            • MRA 6.0.0 (515) Track bar covered not displayed /// Streckenbalken รผberdeckt nicht angezeigt
                              Barto
                              Barto
                            • MRA Route planner Next
                              peha
                              peha
