  4. Offline Map Update
Offline Map Update
15 Posts 6 Posters 339 Views 1 Watching
  • GT JWR
    GT JWR
    GT JWR
    Offline Map Update is not working - and cannot use offline maps until this is sorted. This issue has been happening for at least the last 4-5 days.MRA - Offline Maps Update Failure.png
    • Corjan Meijerink Corjan Meijerink moved this topic from General Discussion on
    • GT JWR GT JWR
      @GT-JWR-0 offline maps stability is something we will definitely work on. I’d try restarting the app or eventually reinstalling 😞
      GT JWR 1 Reply Last reply
        GT JWR
        GT JWR
        GT JWR
        @Corjan-Meijerink did both, neither worked.
        christopherjknight 1 Reply Last reply
        • GT JWR GT JWR
          christopherjknight
          christopherjknight
          christopherjknight
          @GT-JWR I have the same problem. Additionally, I can't set offline navigation - the switch doesn't work.
          GT JWR Corjan Meijerink 2 Replies Last reply
          • christopherjknight christopherjknight
            GT JWR
            GT JWR
            GT JWR
            @christopherjknight was hoping it was related to the recent beta issue...appears it is not. I've updated my iOS and same issue present.
              @christopherjknight that’s disabled on purpose - we still need to develop that! Will be implemented in the coming weeks 💪
              @GT-JWR the outage of MRA Navigation was completely unrelated to this 🙂
              • Walter Coady
                Walter Coady
                Walter Coady
                Same here, I have reinstalled the app as well.
                  GT JWR
                  GT JWR
                  GT JWR
                  @Corjan-Meijerink any update on a possible resolution?
                  • GT JWR GT JWR
                    @GT-JWR not actively working on this now. A reinstall should have fixed the issues. If not, is your storage by chance full?
                    GT JWR 2 Replies Last reply
                      GT JWR
                      GT JWR
                      GT JWR
                      @Corjan-Meijerink reinstall did not correct it, and there is no issue with storage capacity on iPhone. I will try the delete and re-install one more time.
                        GT JWR
                        GT JWR
                        GT JWR
                        @Corjan-Meijerink - FYI, 2nd uninstall, reboot of iPhone, reinstallation corrected the issue.
                        • GT JWR
                          GT JWR
                          GT JWR
                          @Corjan-Meijerink after yesterdays update to the latest version, once again, the Update for maps was needed - and the same 'Something went wrong' error came up. Rebooting the phone (iPhone 11) made no difference.
                          Had to delete TestFlight and app, reinstall, and the re download all the offline maps I wanted.
                          Painful, time consuming process - is this a bug? Issue happening anywhere else?
                          • GT JWR GT JWR
                            @GT-JWR Not a bug as I also have an iPhone 11. No problems at all with offline maps.
                              I wanted to add a Belgium map for the weekend yesterday, but any additional map can not be loaded until the current one gets an update, but the update did not work.
                              So, I tried this morning, and now I get the error "something is not working".
                              I can not see what I have already downloaded and I can not add anything. 😧
                                GT JWR
                                GT JWR
                                GT JWR
                                @Jörgen exactly what has happened on 2 seperate update occasions. And the only fix was to delete the apps, reboot the phone, reinstall the apps and re download the offline maps wanted.
                                GT JWR
                                GT JWR
                                Walter Coady
                                Walter Coady
                                christopherjknight
                                christopherjknight
                                  Axel Lange
                                  Axel Lange
                                • In het kort......
                                • Route probleem
                                  Jack 13
                                  Jack 13
