  4. Offline Map Update
Offline Map Update
10 Posts 8 Posters 199 Views 2 Watching
  • GT JWR
    GT JWR
    GT JWR
    app on iPhone is going through a 'mandatory' offline update - how long should this take? It's been well over 30min so far, and no indication it is even doing anything.
    Have closed the app and restarted it as well, no luck.
    Nick Carthew Corjan Meijerink 2 Replies Last reply
    • Nick Carthew Nick Carthew moved this topic from General Discussion on
    • GT JWR GT JWR
      @GT-JWR-0 I moved your post to the closed beta forum.
      • GT JWR GT JWR
        @GT-JWR-0 depending on the amount / size of offline maps you got installed, it can take a while.
        It will finish eventually and we aim to add a visible progress indicator.
        Hubert Thoring UltraStar GT JWR 3 Replies Last reply
          @Corjan-Meijerink : Danke dafür !!
            UltraStar
            UltraStar
            UltraStar
            @Corjan-Meijerink I have tried for several day with the older and now current version. I did not get anywhere. It gets stuck somewhere in never never land.
            • UltraStar UltraStar
              @UltraStar same problem here.
                GT JWR
                GT JWR
                GT JWR
                @Corjan-Meijerink once again, after the update to this latest version, in order to get the Offline Map Update to work, I had to:
                1. delete TestFlight
                2. delete MRA
                3. reboot iPhone
                4. reinstall all (seperately, because downloading all of USA Maps hangs up and does not work)
                Then, and only then, would it once again download and say updated.
                This has happened on each of the last 3 udpates for sure - this is obviously something that is happening with the software.
                MarcM 1 Reply Last reply
                • GT JWR GT JWR
                  2. delete MRA
                  3. reboot iPhone
                  MarcM
                  MarcM
                  MarcM
                  @GT-JWR I didn't need to do all of these, I deleted MRA and reinstalled - it takes only 1 minute - but I know - here's room for improvement
                  • Con Hennekens
                    To add to the discussion...
                    Funny enough over the last few days I actually WAS able to do map updates. Even a corrupted one (by breaking it up halfway) corrected itself within minutes... I cannot imagine anything changed on my own internet infrastructure. Maybe it is an idea for @Corjan-Meijerink to monitor the availability of bandwidth at the downloadserver on regular intervals and see if they differ al lot. The problem might originate from there?
                      @Con-Hennekens sounds unlikely but who knows.
                      Happy to hear it worked for you! I know the implementation of the offline maps should be correct but unfortunately a lot more people experience issues 😞
                      As stated before, we are working on it! This week actually 😉
                      GT JWR
                      GT JWR
                      MarcM
                      MarcM
                      UltraStar
                      UltraStar
                      • Strange translation
                        martin-phogel.de
                        martin-phogel.de
                        10.7k
                      • Undo/Redo tool is hidden
                      • Shared toggle switch
                      • Crazy routing
