  4. Android - Cursor Re-center Issue After Waypoint Menu
7 Posts 3 Posters 96 Views 1 Watching
  • Dave J 0
    I have provided a screen capture of what appears to be an issue with the screen position cursor nor reverting back to its correct position after I have used the waypoint menu and tapped outside the menu. Not sure whether this is the intended behaviour?
    Waypoint menu and cursor screenshot
    Using Pixel 6 Pro - Android 13 of 5 Mar 23
    Ducati Multistrada V4 Rally
    iPhone 18 Pro
    CHIGEE AIO-6 LTE
    • Dave J 0 Dave J 0
      @Dave-J-0 Tap the compass to re-centre
        This does indeed seem like intended behaviour. After tapping on a waypoint the camera will focus there and stops tracking your location.
        If you want it to follow you again, simply tap the compass as @Nick-Carthew mentioned.
        Dave J 0 1 Reply Last reply
          @Corjan-Meijerink that does not work with the compass as I am aware of that. This shift appears to be because of the software thinking the menu is still there. If you tap the 3 dots it then allows the cursor to re-centre. I have seen this same issue sometimes when you turn from portrait to landscape and a tap of the 3 dots menu then re-centres again. Appears to have happened with this last version of the software on my Android.
          iPhone 18 Pro
          CHIGEE AIO-6 LTE
          Corjan Meijerink 2 Replies Last reply
          • Dave J 0 Dave J 0
            @Dave-J-0 thanks, I'll have a look 🙂
            • Dave J 0 Dave J 0
              @Dave-J-0 in the next update I made some changes to improve this behaviour 🙂
                @Corjan-Meijerink Brill. Thank you.
                iPhone 18 Pro
                CHIGEE AIO-6 LTE
                • Dave J 0 Dave J 0 referenced this topic on
                • Strange translation
                  martin-phogel.de
                  martin-phogel.de
                  10.5k
                • Undo/Redo tool is hidden
                • Crazy routing
                • Which route is shown?
