  3. Average Speed
Average Speed
7 Posts 5 Posters 2.6k Views 1 Watching
  • John Foster 0
    John Foster 0
    John Foster 0
    The app calculates arrival time at WayPoints using , I assume an average speed.
    Can this speed be altered? if so how do I do this. I am planning some routes for Vintage Motorcycles and wish to reduce the average speed used.
    • John Foster 0 John Foster 0
      @John-Foster-0
      Hi John, no this is not possible
      John Foster 0 1 Reply Last reply
        @John-Foster-0
        John Foster 0
        John Foster 0
        John Foster 0
        @Hans-van-de-Ven-MRA-Master
        Hi Hans, thanks for the reply.
        Can you advise how the app calculates the arrival time for each way point?
        Thanks John
          Thanks John
          Steve Lynch
          Steve Lynch
          Steve Lynch
          @John-Foster-0
          This link is for the Here Map API that may shed some light on the things it considers in its estimated time calculations.
          https://developer.here.com/documentation/routing/dev_guide/topics/resource-type-dynamic-speed-info.html
          In my experience the Here Map on my Garmin XT is usually pretty accurate.
          You donโ€™t stop riding when you get old, you get old when you stop riding.
          John Foster 0 David cu 2 Replies Last reply
          • Steve Lynch Steve Lynch
            @John-Foster-0
            John Foster 0
            John Foster 0
            John Foster 0
            @Steve-Lynch , thanks for that. It appears that it is a function of whatever map you choose to use ?
              @John-Foster-0
              David cu
              David cu
              David cu
              @Steve-Lynch said in Average Speed:
              This link is no longer available (it currently redirects to https://www.here.com/docs/ ). You can find the page referred to on the Wayback Machine at
              https://web.archive.org/web/20230923145703/https://developer.here.com/documentation/routing/dev_guide/topics/resource-type-dynamic-speed-info.html
              • Kendra
                Kendra
                Kendra
                That makes sense. Average speed calculations can vary a lot depending on whether stops and delays are included, so it's good to understand how the app handles it. It helps make route timing estimates a lot more realistic.
                Kendra
                Kendra
                David cu
                David cu
                Steve Lynch
                Steve Lynch
                John Foster 0
                John Foster 0
                • F038 Keeping track โ€“ knowing where everything is โ€“ shared and linked R/T
                  1.0k
                • Webapp-icoon
                • Trip - ๐ŸŒ™ Where do you sleep?
                • Groeten uit Alphen aan den Rijn
