  3. Average Speed
Average Speed
7 Posts 5 Posters 2.2k Views 1 Watching
  • John Foster 0undefined Offline
    John Foster 0
    The app calculates arrival time at WayPoints using , I assume an average speed.
    Can this speed be altered? if so how do I do this. I am planning some routes for Vintage Motorcycles and wish to reduce the average speed used.
    • John Foster 0undefined John Foster 0
      @John-Foster-0
      Hi John, no this is not possible
      John Foster 0undefined 1 Reply Last reply
        @John-Foster-0
        John Foster 0
        @Hans-van-de-Ven-MRA-Master
        Hi Hans, thanks for the reply.
        Can you advise how the app calculates the arrival time for each way point?
        Thanks John
          Thanks John
          Steve Lynchundefined Offline
          Steve Lynch
          @John-Foster-0
          This link is for the Here Map API that may shed some light on the things it considers in its estimated time calculations.
          https://developer.here.com/documentation/routing/dev_guide/topics/resource-type-dynamic-speed-info.html
          In my experience the Here Map on my Garmin XT is usually pretty accurate.
          John Foster 0undefined David cuundefined 2 Replies Last reply
            @John-Foster-0
            John Foster 0
            @Steve-Lynch , thanks for that. It appears that it is a function of whatever map you choose to use ?
              @John-Foster-0
              David cuundefined Offline
              David cu
              @Steve-Lynch said in Average Speed:
              This link is no longer available (it currently redirects to https://www.here.com/docs/ ). You can find the page referred to on the Wayback Machine at
              https://web.archive.org/web/20230923145703/https://developer.here.com/documentation/routing/dev_guide/topics/resource-type-dynamic-speed-info.html
              • Kendraundefined Offline
                Kendra
                That makes sense. Average speed calculations can vary a lot depending on whether stops and delays are included, so it's good to understand how the app handles it. It helps make route timing estimates a lot more realistic.
                Kendraundefined
                Kendra
                David cuundefined
                David cu
                Steve Lynch
                John Foster 0
                  3.3k
                  Massimo Cardoneundefined
                  Massimo Cardone
                • Hi, new UK based user.
                  richard 3vundefined
                  richard 3v
                  stuart marrittundefined
                  stuart marritt
