  3. connector
connector
5 Posts 5 Posters 1.3k Views 1 Watching
  • Eric Sijmons
    Eric Sijmons
    Eric Sijmons
    bij het exporteren van een route krijg ik een fout melding.
    ik heb de connector al eens verwijderd en opnieuw geinstalleerd zonder resultaat, graag hulp. device niet gevonden geeft hij aan. XT is verbonden met usb en herkend door garmin express.
    Nick Carthew Steve Lynch HABVEN aka MrMRA 3 Replies Last reply
    • Eric Sijmons Eric Sijmons
      @eric-sijmons Doesn’t the XT use wi-fi to upload routes?
      • Mark Hamilton 0
        Mark Hamilton 0
        Mark Hamilton 0
        Works for me on my XT through connector as long as I confirm the device (XT) is connected to Garmin Express. If the connection to Garmin Express isn't made then the export fails. I find that the XT can be tempremental in connecting to Garmin Express and sometimes takes a little while.
        I transferred a route this morning (via connector) using both 1.1 and 1.2 Zumo file types - both worked fine.
        I usually transfer the saved files from MyRouteapp to my phone though which has Garmin Drive installed and then transfer (as suggested by @nick-carthew) to XT is easier that way.
        Confirm XT connected image -
          Steve Lynch
          Steve Lynch
          Steve Lynch
          @eric-sijmons
          I agree with everything that Mark said but would just add the following......
          Make sure the sound is on when using the Connector, when the XT actually connects you will hear the standard sound used when you connect or un-connect any device.
          Once you hear that sound, only then should you select the relevant GPX file type from the connector.
            @eric-sijmons
            Heb je de OnRoute motorkaart op een micro sd kaartje staan?
            Mark Hamilton 0
            Mark Hamilton 0
            Steve Lynch
            Steve Lynch
            Eric Sijmons
            Eric Sijmons
              Marten Wiersma
              Marten Wiersma
            • Trips in Commercial Clubs?
            • Exporting GPX
              smfollen 0
              smfollen 0
              guenniguenzelsen
              guenniguenzelsen
            • Storage of tracklogs
            • Where do I find Studio?
            • Route calculation between newly added POIs on the map
