  3. connector
connector
5 Posts 5 Posters 714 Views 1 Watching
  • Eric Sijmonsundefined Offline
    Eric Sijmons
    bij het exporteren van een route krijg ik een fout melding.
    ik heb de connector al eens verwijderd en opnieuw geinstalleerd zonder resultaat, graag hulp. device niet gevonden geeft hij aan. XT is verbonden met usb en herkend door garmin express.
    Nick Carthewundefined Steve Lynchundefined Hans van de Ven MR.MRAundefined 3 Replies Last reply
    • Eric Sijmonsundefined Eric Sijmons
      @eric-sijmons Doesn’t the XT use wi-fi to upload routes?
      • Mark Hamilton 0undefined Offline
        Mark Hamilton 0
        Works for me on my XT through connector as long as I confirm the device (XT) is connected to Garmin Express. If the connection to Garmin Express isn't made then the export fails. I find that the XT can be tempremental in connecting to Garmin Express and sometimes takes a little while.
        I transferred a route this morning (via connector) using both 1.1 and 1.2 Zumo file types - both worked fine.
        I usually transfer the saved files from MyRouteapp to my phone though which has Garmin Drive installed and then transfer (as suggested by @nick-carthew) to XT is easier that way.
        Confirm XT connected image -
          Steve Lynchundefined Offline
          Steve Lynch
          @eric-sijmons
          I agree with everything that Mark said but would just add the following......
          Make sure the sound is on when using the Connector, when the XT actually connects you will hear the standard sound used when you connect or un-connect any device.
          Once you hear that sound, only then should you select the relevant GPX file type from the connector.
            @eric-sijmons
            Heb je de OnRoute motorkaart op een micro sd kaartje staan?
            Mark Hamilton 0
            Steve Lynch
            Eric Sijmons
            • Imported POI files visible in App
            • How to exclude short time road blocks during navigation
            • Geen routeberekening
            • Onbegrijpelijke omweg
              Lex.Kloet.RXundefined
              Lex.Kloet.RX
              Steve 2vundefined
              Steve 2v
            • The route is planned to go the wrong way round the roundabout
            • Routeoptie wordt niet meegenomen
              guenniguenzelsenundefined
              guenniguenzelsen
              1.3k
