  3. Export 1.2 gpx
Export 1.2 gpx
43 Posts 11 Posters 25.0k Views 4 Watching
  • Robert Bürgisser Robert Bürgisser
    Hello, I read all the posts carefully and I am very grateful for the good tips.
    I come to the conclusion that I have to choose the export variant «Garmin (GPX 1.1)».
    I tested it and saw that I see shapingpoints and viapoints on the Zumo XT, as desired. If I choose the export variant Garmin Zumo (GPX 1.2), I see only the viapoints.
    For testing, I saved the GPX 1.2 variant and opened it in Basecamp. After a recalculation of the route BC tinkers a completely wrong route - and exactly that happens in the device.
    With the GPX 1.1 variant, shaping points and viapoints are present and the route follows the track exactly.
    What advantage does the GPX 1.2 variant have? I see only one serious disadvantage, namely the lack of transmission and visibility of the shaping points.
    @robert-bürgisser
    Hello Robert,
    Gpx 1.2 is a so called inflated route. If you use the 1.2 file turn off recalculation in your Zumo.
    Don’t use it in Basecamp because then you won’t get the route as planned
    • Robert Bürgisser
      Robert Bürgisser
      Robert Bürgisser
      Thanks for the quick reply Hans! Aha, that is a good insight. So I can assume that the route was stored correctly in the device after the export with GMX 1.2.
      I will test both possibilities (1.1 and 1.2) and report.
        @robert-bürgisser
        Yes, you can assume that both files, gpx 1.1 and gpx 1.2, work correctly in the new Zumo. Make sure you transfer the files with the connector or save them as from MRA to your Zumo.
        • 3
        Nick Dawson
        Nick Dawson
        Reinhard-32
        Reinhard-32
        Guzt
        Guzt
        Kevin Buckley
        Kevin Buckley
        Steve Lynch
        Steve Lynch
        Henrik Müller
        Henrik Müller
        Robert Bürgisser
        Robert Bürgisser
        Stefan Trucksäß
        Stefan Trucksäß
        Bepperling
        Bepperling
          Rene van Maanen
          Rene van Maanen
        • One crash today
          Mosimann
          Mosimann
        • Download club route folders
