  4. Unable to calculate route
58 Posts 12 Posters 23.2k Views 5 Watching
  • Aiello antonino
    #21
    Quando c’è stata la nota, dopo il percorso è partito anche se eri offline?
    MotoCon Peter Zehentreiter 2 Replies Last reply
      So if you are in a place where there is no connection, even if there are offline maps, do you risk not being able to follow an itinerary because there is no connection?
      @Aiello-antonino said in Unable to calculate route:
      This is very explicitly NOT the case.
      I will not repeat all that has been said by others, but solely what I said myself earlier:
      It is not phone signal that is the problem here. You are probably too far away from any road for the app to decide where to start. Once you are at your bike or car, it will most likely just work. I get this also sometimes when in my backyard testing things.
      I regularly are confronted with this issue, when testing things from the couch or in my backyard with a too large distance from any road. Lack of GPS signal could probably also cause this, or being on an uncharted road. In reality, where you start a route from within your car or near your bike that is actually ON a road, this will not happen.
      Aiello antonino 1 Reply Last reply
        @Aiello-antonino, another thing to check is if you really have ALL segments of the needed maps offline. Sometimes it happens when a map update is interrupted, that some segments are skipped. So check your maps, and see if ALL needed segments have a checkmark.
          Yes the route started after the information!
          And again the phone is completly offline, no simcard, no wifi.
          BMW R 1250 GS
          DMD-NOR7E 7"
          SPC Universal mount
          Motorola Edge 40 "offline"
          Sena SLR 3
          Sena 50 R
            #25
            @Con-Hennekens As you say, however, it is not always like this, this is my route in Turkey, despite being very far, the 1º WP is igoumenitsa, the trip is calculated despite the ferry, and starting the navigation leaves... Yes, I don't understand what it can depend on, sometimes it works sometimes it doesn't... In the tests done I always had the maps downloaded on the device
            •  IMG_2806.jpeg elemento elenco
              #26
              @Aiello-antonino Like Con mentioned, download Maps again, it could be that it looks like the maps are downloaded but during an interruption while downloading something went wrong with a map.
              In addition, have you set all the way points on the route "panoramic del vette" accurat on the line and did you test the route again?
              BMW R 1250 GS
              DMD-NOR7E 7"
              SPC Universal mount
              Sena SLR 3
              Sena 50 R
                #27
                @Peter-Zehentreiter I haven't moved anything but it works...🤦🏼‍♂️
                  @Aiello-antonino Then everything's fine.
                  Be glad you can at least drive when you feel like it.
                  Here it's freezing cold, slippery as in an ice rink, and there are mountains of snow everywhere.
                  BMW R 1250 GS
                  DMD-NOR7E 7"
                  SPC Universal mount
                  Sena SLR 3
                  Sena 50 R
                    @Peter-Zehentreiter Yes, I'm glad that everything is working... But I wonder why these problems... Also if it were to happen again and I'm in Turkey, for example, what and maybe I'll do this summer... It would be a big problem
                      #30
                      @Aiello-antonino A two-week data pass with 20 GB of data costs €29.95 >>>provider Telekom.
                      Das würde ich machen wenn ich in ein Land Reise wo kein Roaming funktioniert, da eine Internet Verbindung auch anderweitig immer sinnvoll ist.
                      Aber offline Navigation funktionierte bei mir bis dato immer!
                      Oops......Here in english
                      I would do that if I were traveling to a country where roaming doesn't work, as an internet connection is always useful in other ways too.
                      But offline navigation has never failed so far!
                      BMW R 1250 GS
                      DMD-NOR7E 7"
                      SPC Universal mount
                      Sena SLR 3
                      Sena 50 R
                      • Aiello antonino
                        #31
                        Of course I'll get a data SIM, I mean if I find myself in an area where there's no connection whatsoever...
                          You can count on it the internet connection NOT being the culprit.
                          • Aiello antonino
                            I don't know what to say... but I would like to understand exactly what the problem...it works now...not on Sunday...
                              @Aiello-antonino it is a bit warmer and there is no snow? 😆
                              • Aiello antonino
                                #35
                                Sto tornando qui perché è successo di nuovo oggi... cosa fai quando non c'è modo di far calcolare il percorso dall'app quando sei offline?
                                I have all the Italian maps downloaded, I was in an area where there was no signal and the app couldn't calculate the route... I checked all the waypoints before leaving and they were all positioned perfectly, despite all this, suddenly it decides to stop working... I tried it now at home and everything is fine... I don't know at this point if I'm incompetent or if there's some problem...
                                • Aiello antonino
                                  Ti lascio un video
                                  https://youtu.be/hCvR8iuYA3o?si=mL5aY2SrA6D01kmy
                                  • David Rudgley
                                    David Rudgley
                                    David Rudgley
                                    Yep, had this behaviour many times exactly as you have described it @Aiello-antonino with all of the pre-requisites done i.e. Maps updated, routes sync'd, off line mode activated.... I basically solved it by either riding until I got a signal or the app just seemingly sprang back into life.
                                    MRA Gold Planner + App + Navigation Next user
                                    Android Pixel 10 Pro Fold
                                    TomTomGo as backup
                                    KTM 1290 Super Adventure S
                                    Quad Lock + Phone + Carpuride W702
                                    2026 Kawasaki Z900 RS
                                    Beeline Moto II
                                      @Aiello-antonino, If you enable "Offline navigation" from the app's settings menu, does it calculate then? If it does not, I would update/redownload your maps. This message is a clear indications of missing (or corrupt) maps. Can you show us a screenshot of the downloaded Italian map segments?
                                      • Aiello antonino
                                        #39
                                        Of course, and sorry for only replying at this hour, these are the maps. After what happened yesterday, I went to check the maps. The ones for the area I was in, namely Emilia Romagna and Tuscany, were checked. I noticed that 3 maps from northern Italy were missing, but I'm sure I downloaded them because I had downloaded all of Italy the first time I did it, so I don't know why they weren't checked with the flag, so I downloaded them all again...
                                        I tried to enable offline browsing but it still doesn't work.
                                        At home, trying to put it on airplane mode and trying to recreate the conditions, everything worked perfectly.IMG_3057.png IMG_3056.png
                                        • David Rudgley David Rudgley
                                          @David-Rudgley Yes, I understand what you mean, but I take very complex routes, and I don't remember all the turns. Maybe I would start and, until I found the signal, I would have traveled many kilometers, maybe I would have had to turn back. Yesterday I was at the end of the tour in an area where there was no signal for perhaps more than 10 km, a really closed valley, I didn't even have a phone signal, not just an internet signal.
                                          David Rudgley 1 Reply Last reply
                                          • 3
                                          David Rudgley
                                          David Rudgley
                                            Rene van Maanen
                                            Rene van Maanen
                                            Mosimann
                                            Mosimann
                                          • One crash today
