  2. Export assistance
  3. [Export] Garmin
  4. Drive app fails to send GPX file - again...
26 Posts 12 Posters 2.2k Views 4 Watching
  • Mzokk
    wrote last edited by Mzokk
    Try opening a second iteration of the Drive app and then get rid of the first. Then the send to device dialog should appear. I reported this issue (looks like a refresh issue to me?) after Garmin broke the Android Version Prior to 4.29.28. I was asked to send further details but didn't. The Garmin bod said it could not possibly happen.......but I sent screen shots.
    • Thomas Schäfer
      Thomas Schäfer
      Thomas Schäfer
      The older v4.28.14 works
      Freundliche Grüße/Kind regards/Met vriendelijke groeten
      Thomas
      • Guzt
        Guzt
        Guzt
        Everyone is having problems since the Drive app was updated. On my old SE10 iphone I am still running v4.23.32 without any issues.
        Same with the Tread app. There the problems start when your route contains more than 60 routepoints (start and end included).
        Don Stauffer 1 Reply Last reply
        • Charles Boylan
          Charles Boylan
          Charles Boylan
          How do you select an older version of the drive app?
          • Thomas Schäfer
            Thomas Schäfer
            Thomas Schäfer
            https://www.apkmirror.com/?post_type=app_release&searchtype=apk&bundles[]=apkm_bundles&bundles[]=apk_files&s=Garmin+drive
            Thomas
            Charles Boylan 1 Reply Last reply
            • Guzt Guzt
              Don Stauffer
              Don Stauffer
              Don Stauffer
              @Guzt I've been through this before. I recently turned off automatic updates in the Google Play Store, so I hope to permanently stay on V4.29.25. Although my first choice might be to use a USB cable and the MRA Connector application.
              • Thomas Schäfer Thomas Schäfer
                Charles Boylan
                Charles Boylan
                Charles Boylan
                @Thomas-Schäfer
                So you have to pay for a subscription to TotalAV in order to get an older version of Garmin Drive?
                • Guzt
                  Guzt
                  Guzt
                  wrote last edited by Guzt
                  #24
                  Voor android kan je deze gebruiken
                  If you use an android phone, you can use this one to install an older version
                  https://garmin-drive.en.uptodown.com/android/versions
                  • Nick Carthew
                    On the evening of Thursday 12 November, Garmin released an update for Garmin Drive in the App Store, and the app is now working again. Check the Apple App Store and download version 4.29.36 of the app.
                    Op donderdagavond 12 november heeft Garmin een update voor Garmin Drive uitgebracht in de App Store, en de app werkt nu weer. Kijk in de Apple App Store en download versie 4.29.36 van de app.
                    • Thomas Schäfer
                      Thomas Schäfer
                      Thomas Schäfer
                      Thanks for pointing that out; I’ve installed it and it’s working as it used to.
                      Thomas
                      Thomas Schäfer
                      Thomas Schäfer
                      Don Stauffer
                      Don Stauffer
                      Guzt
                      Guzt
                      Charles Boylan
                      Charles Boylan
                      Oscar Perez Lopez
                      Oscar Perez Lopez
                      Kobutex Motorreizen
                      Kobutex Motorreizen
                      Wallace Shackleton
                      Wallace Shackleton
                      • Spoken notes are truncated
                      • Go to Forum from MRA Next (beta)
                      • Automatic optimization of an entire route to find the shortest route in terms of time or distance.
                      • Add waypoints to favorites and management of favorites with Next
                        Parantapa
                        Parantapa
                      • V6 - Track Navigation
                      • Website update - Best order, daylight on your ride, edit several waypoints at once and more
                      • 'Geen adres bekend'
