  4. When I tap the compass, the map rotates and zooms in.
2 Posts 2 Posters 84 Views 2 Watching
  • Corrado Miniati
    Hello,
    In the Destination menu I noticed that when you tap the compass, the map is correctly reoriented with North at the top, but it also performs a very strong zoom-in.
    On a tablet or mobile device it is quite common to rotate the map unintentionally. In those situations, the goal is usually just to restore the correct orientation, not to change the zoom level. As a result, after tapping the compass, it is necessary to manually adjust the map again to return to the previous zoom level.
    In the attached example screenshots, I intentionally rotated the Europe map and then tapped the compass. The map immediately centered on my GPS position and zoomed in almost to the maximum level.
    Is this intended behavior, or could the compass simply reset the map orientation while keeping the current zoom level unchanged?
    Thanks
      Won't be changed 🙂
      • Corjan Meijerink Corjan Meijerink locked this topic
      • Website update - A Photos page, split by your day limit, arrive on time and more
      • reis in concept kopieren
      • Suggestion: Route Auto Name
      • Online map settings
        MartinW
        MartinW
      • Trips, interaction with Clubs
        Andy Nicholson
        Andy Nicholson
      • Globale inhoud van een update en mogelijk wijzigingen.
        Peter 12m
        Peter 12m
      • Club-Event: Incorrect Number of Participants
      • Move Google Maps up the list
        JP d
        JP d
