<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[When I tap the compass, the map rotates and zooms in.]]></title><description><![CDATA[<p dir="auto">Hello,<br />
In the Destination menu I noticed that when you tap the compass, the map is correctly reoriented with North at the top, but it also performs a very strong zoom-in.<br />
On a tablet or mobile device it is quite common to rotate the map unintentionally. In those situations, the goal is usually just to restore the correct orientation, not to change the zoom level. As a result, after tapping the compass, it is necessary to manually adjust the map again to return to the previous zoom level.<br />
In the attached example screenshots, I intentionally rotated the Europe map and then tapped the compass. The map immediately centered on my GPS position and zoomed in almost to the maximum level.<br />
Is this intended behavior, or could the compass simply reset the map orientation while keeping the current zoom level unchanged?</p>
<p dir="auto"><img src="/assets/uploads/files/1794320644861-1.jpg" alt="1.jpg" class=" img-fluid img-markdown" width="1233" height="2670" /><br />
<img src="/assets/uploads/files/1794320655451-2.jpg" alt="2.jpg" class=" img-fluid img-markdown" width="1324" height="2866" /></p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.myrouteapp.com/topic/12545/when-i-tap-the-compass-the-map-rotates-and-zooms-in.</link><generator>RSS for Node</generator><lastBuildDate>Sun, 15 Nov 2026 00:31:36 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/12545.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 10 Nov 2026 14:24:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to When I tap the compass, the map rotates and zooms in. on Tue, 10 Nov 2026 14:26:20 GMT]]></title><description><![CDATA[<p dir="auto">Won't be changed <img src="https://forum.myrouteapp.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=06c51928fc7" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:1.4em;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
]]></description><link>https://forum.myrouteapp.com/post/88763</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/88763</guid><dc:creator><![CDATA[Corjan Meijerink]]></dc:creator><pubDate>Tue, 10 Nov 2026 14:26:20 GMT</pubDate></item></channel></rss>
