  3. Revert to old icons for way points and waypoint management
38 Posts 13 Posters 18.1k Views 2 Watching
  • MyRoute-app community Offline
    Administrator
    Hello everyone,
    Just jumping in here to share some of the design concerns relating to the wording of "Via" and "Stop".
    First of all, for all international (non-Dutch) purposes we are considering using "Shaping" and "Via" as the only words available to pick from. Additionally, we're not aiming to make this a Garmin-specific feature, but for the initial release this was the easiest to implement. We want to show TomTom and Smartphone users a distinct difference between Shaping- and Via-points as well.
    As for the naming convention and the specific choice to no longer go with "Stop". There's a lot of synonyms for this functionality available, for example some talk about "Stopping points", places that you absolutely have to stop at. Others talk about "Hard points", allegorically expressing how there's points that you won't notice if you skip them as "soft" and points that have to be visited as "Hard". Please understand that we've thought hard about what word would be best fitting and that we remain open to the idea that there are better definitions for these points.
    Linguistically though, the word "Shaping point" and "via point" are of all available words the most accurate. A "shaping point" does exactly that, it generally shapes a route that will be followed by navigation system in a flexible manner. Via points also describe what they are, they are points "via which" you must travel. Explained, this does make sense. But again, we remain open for discussion on this subject.
    Kind regards,
    Timo
    Drabslab 1 Reply Last reply
    • MyRoute-app community MyRoute-app community
      Hello everyone,
      Kind regards,
      Timo
      Drabslab Offline
      Drabslab Offline
      @Timo-Martosatiman-MRA In all honesty, this is a bit trivial in my opinion, I can live with any word as long as it is decently defined and explained. And maybe it is the consequence of a surprise release that there is no detailed release note or documentation available? Or Am I being blind again?
      I would repeat my suggestion for a user managed wiki here but that would also become boring 🙂
      • speedup100 Offline
        speedup100 Offline
        speedup100
        I agree with drabslab that a wiki detailing the changes with release 1.1 would have been useful, for example a mention to say that Stops would now be called Shaping would have saved some confusion, the 1.1 release was just dropped in without any explanations.
        • speedup100 speedup100
          Drabslab Offline
          Drabslab Offline
          @speedup100 said: the 1.1 release was just dropped in without any explanations.
          True, but it was very welcome nevertheless. 🙂
          Change managment is a subject on its own. Documentation is usually one of the last considerations, and has the habit of becoming outdated very fast.
          • Will Brooks Offline
            Will Brooks Offline
            Will Brooks
            Really great to see new features to expand the usability of the software, however, I'm also a little frustrated at this release as a Garmin user. By default it appears that only the start and finish points are set as "announced way points" and all the in between points are automatically "shaping points". I don't like using "shaping points". I know I can go and change each point to get my desired route all as "announced way points" but this is a real ball ache especially on long routes and time consuming. An option to set the default behaviour of points so we have a choice rather than be forced one way or the other would be preferable.
            As a workaround, would I be correct in saying that if I were to just export to GPX1.0 format, all points are automatically "announced way points" as 1.0 doesn't support "shaping points"?
            • Will Brooks Will Brooks
              Nick Carthew Online
              Nick Carthew Online
              @Will-Brooks said: By default it appears that only the start and finish points are set as "announced way points" and all the in between points are automatically "shaping points".
              Please don’t introduce another term for the Stop/Via waypoint argument 🤣
                Will Brooks Offline
                Will Brooks
                Have been playing about and to answer my own question it appears that if I save a route as GPX 1.0 then all points in MRA planner default to "announced way points" or via points - whatever terminology you wish to use 😉
                The Beta GPX 1.1 works well for shaping points on my Garmin XT and behaves as you would expect. The standard GPX 1.1 (Route, track and POI) just draws straight lines, but the old trick of changing the route calculation in the Garmin from fastest to shortest and then back to fastest makes it behave like the Beta GPX 1.1 (One caveat - I've only tried it on a very short simple route with 7 points)
                • Ben Craig Ben Craig
                  I noticed today the the default waypoint icon has changed from a pin to what looks a little bit like a hand. And when you click the way point, the balloon now shows a bunch of redesigned icons which seem to have been lifted straight out of Windows 95 or some other app of that era!
                  The old icon set was more modern, cleaner, and more useful. Is there a configuration setting to revert to the old icons. If not, can there be please? This update has reduced usability and the visual identify of the app, not improved it.
                  FrankS Offline
                  FrankS Offline
                  FrankS
                  wrote on last edited by FrankS
                  #30
                  @Ben-Craig
                  I completely agree with your feedback, espacially regarding lack of usabiliy of the new icons. This is in particular true for the way point icon: the old icon was easy to place exactly on the road where you want to drive, the new icon is always off the route, so that I always need to move the icon on the road after I have placed it.
                  My minimum requirement is to be able to configure in my settings if I want to use the old or the new style. The new style is - my personal opinion - not even pretty, but a very rough design.
                  But most important: Nice looking is not the same as usability! It should be much easier for users to do the most frequent use case which is to plan a route by setting way points where they shall be - not on a minor street next to it!
                  So strong like for Ben's feedback from my end!
                  Freddy
                  • PAD 0 Offline
                    PAD 0 Offline
                    PAD 0
                    I agree that the waypoint icons are very difficult to locate accurately - the finger used to move them hides them. This is plain daft! Other than that, I’m ok with the icons, apart from the final one on ‘more icons’…
                    Firstly the icon is obscure - it’s a bit of a stretch to arrive at ‘skip’ from an image of a Land Rover going up a hill!
                    However, launching us straight back into ‘daft’ territory, is the fact that when the ‘more icons’ icon is selected, the ‘skip’ icon is totally obscured by a black box with the words ‘more icons’ writ large upon it… that only appears after you hit the ‘more icons’ icon!!! THAT is nothing short of pitiful. Thankfully in a laughable kind of way!
                    Nick Carthew 2 Replies Last reply
                    • PAD 0 PAD 0
                      Nick Carthew Online
                      Nick Carthew Online
                      @PAD-0 Turn on “Place Waypoint Button” in the toolkit. This way you have crosshairs to accurately line up the position. 352B128C-7ACA-44E5-90BD-F4DB4FFD5032.png
                      PAD 0 1 Reply Last reply
                      • PAD 0 PAD 0
                        Nick Carthew Online
                        Nick Carthew Online
                        @PAD-0 Click on the route point box after clicking more options and the black box disappears. 92429BD9-706D-4049-A9C8-CFA0F1B34EAF.png
                          PAD 0 Offline
                          PAD 0 Offline
                          PAD 0
                          wrote on last edited by PAD 0
                          #34
                          @Nick-Carthew Thank you for your suggestion, but I have that on already - it would be quite challenging to create routes at all without it I think. What I was addressing was the modification of a route by moving existing waypoints. On a PC, using a mouse, this isn’t an issue, but it’s a real pain on touch screens. Clearly, much bigger markers might be undesirable in some circumstances, so that’s probably not an easy fix. A longer ‘tail’ to the waypoint marker might help? Or use of pin or flag icons? Just enough to avoid the ‘business end’ of the icon being obscured. I should, perhaps, add that I don’t have great, fat fingers by any means!
                            PAD 0 Offline
                            PAD 0 Offline
                            PAD 0
                            #35
                            @Nick-Carthew I do know that, although I find the box needs some coaxing to go away. Question is, why clutter up the app with strings of code, the effect of which are post hoc?
                            • PAD 0 PAD 0
                              Nick Carthew Online
                              Nick Carthew Online
                              @PAD-0 said in Revert to old icons for way points and waypoint management:
                              When moving a route point click the arrowed icon to use the crosshairs and add button. 7932D549-2998-4CFD-AEFD-D289E3C67AFD.jpeg
                                PAD 0 Offline
                                PAD 0 Offline
                                PAD 0
                                @Nick-Carthew Ohhhh! Brilliant! Thank you sir!
                                • PAD 0 Offline
                                  PAD 0 Offline
                                  PAD 0
                                  That’s as in:
                                  For anyone else who might have missed this.
                                  Not altogether ‘intuitive’ but, once pointed out, it’s something I’ll work with very happily indeed.
                                  My interpretation of the UI was that selecting the move icon rendered the waypoint moveable by ‘picking it up’ and moving/placing it by hand (well, finger!).
                                  Will Brooks
                                  Will Brooks
                                  Gary France
                                  Gary France
                                  FrankS
                                  FrankS
                                  speedup100
                                  speedup100
                                  PAD 0
                                  PAD 0
                                  Thomas hanson
                                  Thomas hanson
                                  Robert Purvis
                                  Robert Purvis
                                  Ben Craig
                                  Ben Craig
                                  • Saludo
                                    Bull Tahr
                                    Bull Tahr
                                  • New Zealand Routes
                                    Bull Tahr
                                    Bull Tahr
                                  • The slow death of Zumo...
                                    Bull Tahr
                                    Bull Tahr
